Panasonic Inverter Refrigerator model NR-BY602XS - suddenly not cold overnight
  • petehall347
    • Jan 2015
    • 4439
    • United Kingdom
    Re: Panasonic Inverter Refrigerator model NR-BY602XS - suddenly not cold overnight
    Originally posted by beetle1303
    Based on this sensor specs, I believe the 2 sensors I tested measuring at 1.58kOhm at ~26-28c, and 5.8kOhm at 0c should be working normally.
    On the overload protector - how do I determine if it tripped open due to over-voltage or not?
    that thermal looks broken ...
    • R_J
      • 9588
      Check the resistance between pins 1 & 3, it should check like a short. It trips with excess current not voltage.
      • beetle1303
        • Jul 2019
        • 279
        • Singapore
        Could you put this original picture somewhere so I can make some tests with it?
        (Obviously you would need to use some other website if you get the error above here...)
        Here's the link for 1 such pic that caused this error: https://we.tl/t-lLIq3zXP41
        ** I just did a resized from 15mb to 4mb, then it loads OK.
        • beetle1303
          • Jul 2019
          • 279
          • Singapore
          Originally posted by stj
          i suspect the motor may have a bad phase or drive line,
          if it hums then the electronics are trying to run it.
          we need board pics.
          Here are the controller board pics, and connectors diagram.
          • beetle1303
            • Jul 2019
            • 279
            • Singapore
            The resistance between pins 1 & 3 is 3.2 ohms.
            Noted your correction, important for my education, thank you.
            Presumably, if the compressor draws too high current, the temperature rises above the limit and trips open this protector, and cut off the power to all 3 terminals of the compressor?
            In my case, the voltage among all 3 terminals were 160VAC soon after powered up, does this mean the compressor is not overloaded?
            • beetle1303
              • Jul 2019
              • 279
              • Singapore
              #26
              If it tested resistance of 3.2 ohms across pin 1 & 3, does it mean still good? If not, how to determine it's still functional?
              • petehall347
                • Jan 2015
                • 4439
                • United Kingdom
                #27
                try putting your meter leads together then deduct the reading from 3.2 .
                have you tried fast freeze function ?
                • beetle1303
                  • Jul 2019
                  • 279
                  • Singapore
                  #28
                  Weird.. Now it reads 0.7 ohm, and touching the 2 leads together reads 0.5 ohm.
                    • 31190
                    the + end of the bridge rectifier is darker, marker pen, soot, burn mark??
                    • petehall347
                      • Jan 2015
                      • 4439
                      • United Kingdom
                      #30
                      so it is really 0.2 ohms which seems good
                      have you tried fast freeze yet ? it should bypass the thermostat .
                      • beetle1303
                        • Jul 2019
                        • 279
                        • Singapore
                        #31
                        I think it's shadow from the camera phone. This pics is clearer, look normal.
                        • beetle1303
                          • Jul 2019
                          • 279
                          • Singapore
                          #32
                          You meant the Fast Freeze button on the fridge? Yes, it has no effect on the evaporator.
                          I should clarify, that the fridge is always power down. Each time I did some checks, or taking measurements, I would power it up for like 5- 10 minutes, then I will power down the fridge.
                          The longest I have left it power up is ~30 minutes, and still no cool air at all..
                          • beetle1303
                            • Jul 2019
                            • 279
                            • Singapore
                            #33
                            I insulated the 2 wires (brown and blue) and power up without the overload protector just to confirm if the circuitry is working - and compressor not starting up as expected.
                            Then I put everything back per normal, power up and rerun the Self Diagnostic one more time (which I have done multiple times), and paid really close attention to the indicator displays at the door panel - OMG!
                            2 of the indicator lights blinked a few times then went off. I waited for a minute or so, nothing happened and all the indicator display lights were off. I have done this a few times and it always the same outcome.
                            I was thinking since the outcome is nothing lighted up - so the fault should be the at the end of the flowchart:
                            • Faulty compressor motor.
                            • Compressor lock.
                            Now, looks like it is at #4:
                            • Defect of control PCB.
                            • Communication error between IC1 & IC201
                            So I guess I just have to source for a working controller board!
                              • 31190
                              or fix the board?
                              • beetle1303
                                • Jul 2019
                                • 279
                                • Singapore
                                #35
                                The board looks like tropical rain forest to me...
                                Are you able to point it out where do I start checking?
                                  • Jul 2011
                                  • 6063
                                  OK
                                  I have repaired VFD drive before
                                  This has to have a IGBT module some where on that board more than likely there is a heat sink on top of it post the part number of it
                                  Try reading the voltage on terminals 1 and 3 / 2 and 3 / 1 and 2 on the compressor terminals
                                  The voltage readings should be very close to each other
                                  If you can not get a stable reading then try read the input voltage at board if you do not get a stable reading there then you have some problem at IGBT module
                                  • beetle1303
                                    • Jul 2019
                                    • 279
                                    • Singapore
                                    #37
                                    The only one with heatsink is this giant one labelled IMP301 on the board. The only IGBT I can see but without heatsink is MIP414MD.
                                    The 3 compressor pins all has resistance of 9.4 ohm between them. When powered up, all has around 160.3-5 between them.
                                    I have powered up the fridge, and turned on the quick freeze function, and the freezer control to max. The compressor started up with normal low temperature, low vibration and low humming sound. After about 30 minutes, it became quite hot (but not too hot to touch) with medium pitch whining sound, but vibration remained low.
                                    The inlet and outlet tubes to and fro the compressor both feel slightly hot and slightly cold respectively. Evaporator fan is running. Can feel the refrigerant flowing through when placing fingers onto the evaporator coil, but not cold at all.
                                    I gave the compressor a few bangs with a gloved fist, the whining pitch seemed to have lowered, then returned to same level after a short while.
                                      • 31190
                                      maybe you could use 3 lamp bulbs in parallel to the compressor coils to see if all 3 are being driven.
                                      • beetle1303
                                        • Jul 2019
                                        • 279
                                        • Singapore
                                        #39
                                        I would, if you could kindly draw me diagram on how to wire them up, and presumably using 40w-100W incandescent bulbs?
                                        I should expect to see these bulbs flickering indicating varying power driving the compressor?
                                          • 31190
                                          you could wire them so one end of each lamp is joined, and the other end is hooked to the V,W & U signals like in the diagram,
                                          that would be pins 7,9 & 11
                                          • SuperAman
                                            Hitachi Refrigerator R-Z270AUN7KV not cold.
                                            by SuperAman
                                            Hi, I have a Hitachi Refrigerator R-Z270AUN7KV. The fridge is on the bottom and the freezer is on the top. My problem is no matter what setting (1-9) the freezer is, the fridge is not getting cold but the freezer is always cold. I have tried all combination of settings for the fridge (Min, Mid, Max) but nothing. Fridge is always hot now. Before it would sometimes do this but now always fridge is hot. I believe the service center peeled some of the foil from the thermostat and that seemed to help a few years back. I replaced the thermostat recently and it worked off and on for a few weeks but now...
                                            10-29-2020, 02:01 AM
                                          • x_orange90_x
                                            by x_orange90_x
                                            01-29-2025, 09:24 PM
                                          • Gentian
                                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                            by Gentian
                                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                            03-06-2023, 07:07 AM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
                                          • eccerr0r
                                            A modified sine wave inverter + a grid tie inverter?
                                            by eccerr0r
                                            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                            Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                            08-31-2023, 09:14 PM
