Re: newbie needs help w/Electrolytic caps (washing machine)
of course!
AEG Lavamat L725500
circuit board is EWM 2100
I am gettting an "E52" message which means there's a problem with the motor. If you'd like, you can see the problem there. The motor tests good according to those instructions.
https://www.manualslib.com/manual/73...page=36#manual
The long story is that we moved apartments. After the move, I got error message E52. I explored and found four wires to the motor and tachometer sensor had been cut in the move. I reconnected the wires, the machine did two loads, and then died.
Since the motor tested good, I'm assuming there's a circuit board problem.
thanks again to everybody!
My problem is that my wife is running out of patience, and wants to buy a new washer, etc., etc.,.....
of course!
AEG Lavamat L725500
