newbie needs help w/Electrolytic caps (washing machine)
  • glutton4punishment
    • May 2013
    • 81
    Re: newbie needs help w/Electrolytic caps (washing machine)
    Originally posted by R_J
    Does this "washing machine" have a model number? does the board have a part number? attach pictures of the complete board, both sides.
    of course!
    AEG Lavamat L725500
    circuit board is EWM 2100
    I am gettting an "E52" message which means there's a problem with the motor. If you'd like, you can see the problem there. The motor tests good according to those instructions.
    https://www.manualslib.com/manual/73...page=36#manual
    The long story is that we moved apartments. After the move, I got error message E52. I explored and found four wires to the motor and tachometer sensor had been cut in the move. I reconnected the wires, the machine did two loads, and then died.
    Since the motor tested good, I'm assuming there's a circuit board problem.
    thanks again to everybody!
    My problem is that my wife is running out of patience, and wants to buy a new washer, etc., etc.,.....
      • May 2013
      • 81
      Compared to a new one of same UF value and same voltage
      I don't have new ones to compare to
      I do not think so I test a lot of capacitor and to me those ESR value look high
      No argument here
      ( one note if you get any reading over 0.30 [ on UF values less than 470 UF ] I would check it with a new one of a brand name capacitor to know for sure weather or not its reading is high or not or if in doubt)
      If this was a 220uf cap and it reads 445uf then there is something really wrong with those capacitors
      No, they were 220 reading 230, or about 5% off
      And if they are 470uf capacitors then I would question weather those capacitors are any good any way
      Here is my rule about ESR values ( that are used in Switching Power Supply ) ( in other devices it depends on what type of device it is if I have this opinion on it or not —> if it has a timing circuit or a micro controller in it then I have the same opinion as I do about switching power supply )
      If the capacitor is a non well known manufacturer I replace on site
      I don't have time to order online and get delivery of high quality caps.
      If the capacitor is more than 10% higher in ESR value of a new one it gets replaced even if it is a well known brand
      If it has a value less than 10% I might change them any way
      if the device is older than 5 years old or if it being used 24 hours a day and 7 days a week 365 days a year or the device sit around for long periods of time not being used and I am have issues with the device I replaced them
      This is just my opinion
      merci!
        • 31250
        resolder the white 4pin connector,
        the joints are cracked - i can see the ghost-rings in the foto!
        (s177-s180)
          • May 2013
          • 81
          (s177-s180)
          done
            • May 2013
            • 81
            OK, I took out the large transistor, which I didn't know if it was a transistor, a triac, a mosfet, or whatever else looks like that.
            It tested bad, so I bought a new one.
            I'll report the results later
            • petehall347
              • Jan 2015
              • 4440
              • United Kingdom
              #26
              what is written on it ?
              • petehall347
                • Jan 2015
                • 4440
                • United Kingdom
                #27
                check your previous repair
                  • May 2013
                  • 81
                  BTB16
                  The store had a BTA16, which they said was interchangeable
                    • May 2013
                    • 81
                    I don't know what you mean here.....
                    • petehall347
                      • Jan 2015
                      • 4440
                      • United Kingdom
                      #30
                      • petehall347
                        • Jan 2015
                        • 4440
                        • United Kingdom
                        #31
                        BTB16 is a triac .
                        http://www.circuitstoday.com/how-to-test-a-triac
                        • R_J
                          • 9607
                          You say the part tested bad, In what way was it bad? shorted, open, If it is a BTA16 was either A1 or A2 shorted to the gate?
                            • 31250
                            be carefull,
                            i think the difference between those triacs is one has an isolated tab and the other can be live!
                            • R_J
                              • 9607
                              I would guess that if the triac shorted from A1 to A2 the motor would run and not shut off.
                              Does the plug going to the motor have 6 or 7 wires?
                                • May 2013
                                • 81
                                After putting in the new triac, I still got the same error code, motor problems.
                                I went back over all my work and retested the motor. It tested fine. But this time I started from the beginning, reading the motor resistances from the connection at the front of the machine, where it plugs into the front panel.
                                There was a problem, inifinite resistance with one of the wires. So I go back to the motor, pull of the wire loom connector to the motor. The motor read fine.
                                So I start testing the wiring loom. Sure enough, one wire read infinite resistance.
                                That ONE wire that must have been hanging by a thread the first time I reconnected the 3 other disconnected wires.
                                The machine ran fine through two loads, and then the wire got disconnected from the loom connector. BUT, it looked fine! I guess that it was held in place by the insulation, so that it looked OK, but the copper wire had been disconnected within the connector.
                                So I kept getting error messages, thought that it must have been the circuit board.
                                Thanks to all who offered their help
                                • petehall347
                                  • Jan 2015
                                  • 4440
                                  • United Kingdom
                                  #36
                                  well done in finding the break and fixing it
                                    • May 2013
                                    • 81
                                      • Jul 2011
                                      • 6070
                                      I have seen this type of problem with any type of connection to connectors to circuit boards
                                      Especially if the wire are thin this happens more often
                                      Or
                                      Connectors to circuit board cracking soldering joints
                                      • clearchris
                                        • Dec 2013
                                        • 687
                                        You really can't go wrong with that rule. I generally don't even bother troubleshooting before replacing all the caps if the board is more than a few years old. Don't trust the tester, they don't always test at the voltage they are used at on the board. Just doing that covers almost 80% of fixes. Caps go out that often.
                                        • juergenb
                                          Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                                          by juergenb
                                          i am asking for some Help.
                                          I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                                          The Motor didn´t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                                          So i got a few of these from Banggood.
                                          I swapped the motor and now i have a new fault condition.
                                          In a working Frother you would press the start button, it will light red and work for a few minutes.
                                          If you press longer it will light blue and just mixup the milk.
                                          With the new Motor it just starts...
                                          03-23-2021, 11:24 AM
                                        • sbt123
                                          charnwood w821 mini wood lathe motor problem
                                          by sbt123
                                          hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                                          10-27-2024, 03:43 AM
                                        • Soulzink
                                          Samsug washing machine. Power supply DC41-00189a board issue
                                          by Soulzink
                                          I am trying to fix a samsung washinmachine power supply main board.
                                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                          The power supply board reference is the following: DC41-00189a
                                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                          04-19-2025, 06:26 AM
                                        • mikey5791
                                          Help identify this motor
                                          by mikey5791
                                          Hi all forum members,
                                          Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
                                          Correct me if i am wrong on the initial test.
                                          Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
                                          11-24-2023, 07:54 PM
                                        • Per Hansson
                                          Motor run capacitor physical size vs voltage rating & measurements?
                                          by Per Hansson
                                          (TL;DR skip the first paragraph)
                                          I encountered my first dead motor run capacitor at a customer this week.
                                          For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                                          (Unless a servo motor makes more sense that is).
                                          But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                                          The pump would run but sometimes trip the 10A breaker.
                                          I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                                          Then it could...
                                          09-20-2020, 06:32 AM
