newbie needs help w/Electrolytic caps (washing machine)
  • glutton4punishment
    • May 2013
    • 81
    Howdy!
    The main problem is that the agitator/spin motor doesn't run (front loader, AEG/Electrolux). The water pump, and all other electronics seem to work, and it goes through the error diagnosis on the control panel.
    I checked the motor values, and it seems to be OK.
    I looked over the MB, and I didn't like how the MB looked at the attachment points of the motor to the wiring harness, so I cleaned them up.
    As I looked around more, I noticed on one soldered lead of a cap had a brown coating around it. (No, not glue). I took a picture AFTER I had cleaned it up a bit, you can still see some of the coating. I took measurements of that cap printed values are ELNA, 220 uF, 35V. The meter said 228 uF, Vloss = 2.1%, ESR=0.69.
    OK, I thought, it looks like maybe it leaked, but the values look OK. It's about impossible to see the cap side of the board, the cap doesn't have enough clearance to see underneath it.
    Since there's only 4 electrolytic caps on the board, I thought I'd check the others out, too.
    Next two caps with the same printed value as above (ELNA, 220 uF, 35V) read:
    445 uF, Vloss = 12%, ESR = .66
    447 uF, Vloss= 12%, ESR = .69
    Now for the last cap, printed value of LETON, 10uF, 400V, the meter reads:
    DIODE Uf = 699mV, C= 10.2 uF!!
    BTW, according the map of the circuit board, all the caps are in the power supply section, not in anything controlling the motor.
    So, I'm confused as to why the motor is the problem, but the caps in the power supply seem to be the troublemakers.....
    Thanks!
    • May 2013
    • 81
    Re: newbie needs help w/Electrolytic caps (washing machine)
    I'm uploading the pics to Drive right now, one moment's patience, please!
      • May 2013
      • 81
      after 20 minutes of not being able to upload pics, I guess newbie needs help with that too
      • diif
        • Feb 2014
        • 6978
        • England
        Click Go Advanced below, then the paperclip.
        Have you checked the brushes on the motor ?
        Did you remove those caps from circuit to test ?
          • May 2013
          • 81
          BTW, no caps are bulging.
            • May 2013
            • 81
            Originally posted by diif
            Click Go Advanced below, then the paperclip. OK, will do
            Have you checked the brushes on the motor ? No, will do.
            No, will do.
              • May 2013
              • 81
              https://drive.google.com/open?id=0B7...dTRDhRQVlSSVp3
              https://drive.google.com/open?id=0B7...YyRWJMRTkxTUo0
              https://drive.google.com/open?id=1e7...fxcNyUywqES2nD
              https://drive.google.com/open?id=1NU...lXJVLCp8LZpV-C
              • petehall347
                • Jan 2015
                • 4440
                did you check the triacs ? and also motor wires ?
                • petehall347
                  • Jan 2015
                  • 4440
                  last pic bottom left looks like bulging cap
                    • May 2013
                    • 81
                    naw, it's just the angle.
                      • May 2013
                      • 81
                      click go advanced below, then the paperclip.
                      Have you checked the brushes on the motor ? brushes are good
                      did you remove those caps from circuit to test ?
                      i took them out of circuit and they test good
                        • May 2013
                        • 81
                        I tested the motor wires, all good
                        I DON'T KNOW WHERE THE TRIAC IS.
                        There's one non SMC transistor (3 legs) attached to a heat sink.
                        When I attached it to a multi-component tester, I got readings of hFE=56.0K and uf = 546 mV
                        After that, I retried, and I got "resistor" of 71 ohm between points a & b, and 267 ohms between b & c.
                        WTD?
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          Here is a FAQ on how to upload pics, or do you get any errors when you try to?
                          https://www.badcaps.net/forum/showthread.php?t=1868
                          • petehall347
                            • Jan 2015
                            • 4440
                            WTD?
                            maybe it doesnt use triacs for switching then . most i have worked on have a row of them on the main board .
                              • May 2013
                              • 81
                              thanks very much for that!
                              Since the caps ended up not being the problem, I'm not going to reload the pics.
                                • May 2013
                                • 81
                                re: the triacs, there are 4 of these white cubes on the board....each, it seems, has 5 connections to the board.....are these triacs?
                                  Great Sage é½Šå¤©å¤§č–
                                  • 31248
                                  those are fucked,
                                  they are internally leaky leading to high uf readings.
                                    • May 2013
                                    • 81
                                    Originally posted by stj
                                    those are fucked,
                                    I took them out of circuit, and then they read ok
                                      • Jul 2011
                                      • 6070
                                      Compared to a new one of same UF value and same voltage
                                      I do not think so I test a lot of capacitor and to me those ESR value look high
                                      ( one note if you get any reading over 0.30 [ on UF values less than 470 UF ] I would check it with a new one of a brand name capacitor to know for sure weather or not its reading is high or not or if in doubt)
                                      If this was a 220uf cap and it reads 445uf then there is something really wrong with those capacitors
                                      And if they are 470uf capacitors then I would question weather those capacitors are any good any way
                                      Here is my rule about ESR values ( that are used in Switching Power Supply ) ( in other devices it depends on what type of device it is if I have this opinion on it or not —> if it has a timing circuit or a micro controller in it then I have the same opinion as I do about switching power supply )
                                      If the capacitor is a non well known manufacturer I replace on site
                                      If the capacitor is more than 10% higher in ESR value of a new one it gets replaced even if it is a well known brand
                                      If it has a value less than 10% I might change them any way
                                      if the device is older than 5 years old or if it being used 24 hours a day and 7 days a week 365 days a year or the device sit around for long periods of time not being used and I am have issues with the device I replaced them
                                      This is just my opinion
                                      • R_J
                                        • Jun 2012
                                        • 9607
                                        Does this "washing machine" have a model number? does the board have a part number? attach pictures of the complete board, both sides.
                                        • juergenb
                                          Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                                          by juergenb
                                          i am asking for some Help.
                                          I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                                          The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                                          So i got a few of these from Banggood.
                                          I swapped the motor and now i have a new fault condition.
                                          In a working Frother you would press the start button, it will light red and work for a few minutes.
                                          If you press longer it will light blue and just mixup the milk.
                                          With the new Motor it just starts...
                                          03-23-2021, 11:24 AM
                                        • sbt123
                                          charnwood w821 mini wood lathe motor problem
                                          by sbt123
                                          hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                                          10-27-2024, 03:43 AM
                                        • Soulzink
                                          Samsug washing machine. Power supply DC41-00189a board issue
                                          by Soulzink
                                          I am trying to fix a samsung washinmachine power supply main board.
                                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                          The power supply board reference is the following: DC41-00189a
                                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                          04-19-2025, 06:26 AM
                                        • mikey5791
                                          Help identify this motor
                                          by mikey5791
                                          Hi all forum members,
                                          Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
                                          Correct me if i am wrong on the initial test.
                                          Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
                                          11-24-2023, 07:54 PM
                                        • Per Hansson
                                          Motor run capacitor physical size vs voltage rating & measurements?
                                          by Per Hansson
                                          (TL;DR skip the first paragraph)
                                          I encountered my first dead motor run capacitor at a customer this week.
                                          For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                                          (Unless a servo motor makes more sense that is).
                                          But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                                          The pump would run but sometimes trip the 10A breaker.
                                          I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                                          Then it could...
                                          09-20-2020, 06:32 AM
