Hotpoint FDW60 Flextronics module
  • frontshop
    • Sep 2012
    • 6
    • uk
    Hi I might be in the totally wrong place here but any help would be gratefully appreciated. Over here in the UK I have discovered numerous dishwashers that are catching fire the problem is starting with the Flextronic timer module that over a period of time seems to be carbonising and eventually catching fire, while searching for people having similar problems I came across this link in Australia
    http://spares.bigwarehouse.com.au/pr...cts_id=1649782
    If you go to this post they say the module burnt: Ariston L64 A143206 power circuit board 2010-12-28 16:51:03
    As I mentioned before I am trying to uncover all incidents with this component if anyone is aware of others that have had similar problems please let me know.
    I have posted a blog that gives further info regarding this
    http://dishwasherfire.blogspot.co.uk/
    Thank you for your time
    master hoarder
    • May 2008
    • 12175
    Re: Hotpoint FDW60 Flextronics module
    That's crazy!
    Thanks for posting. Will keep an eye out if I see any of the mentioned dishwasher brands.
    • joshnz
      • Feb 2011
      • 969
      • New Zealand
      was it running a cycle at the time?
      My pc
      CPU : AMD PHENOM II x4 @ 3.5Ghz
      MB : ASUS M4A89TD PRO USB3
      RAM : Kingston ValueRAM 16gb DDR3
      PSU : Cooler Master 850W Silent Pro
      GPU : ATI Radeon HD 6850
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        And I thought the infamous Jenn-air Dim display was the worst appliance electronics fail around here...
        sigpic
        (Insert witty quote here)
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          around here hotpoint=g.e.
          seems some ge dishwashers are recalled due to fire.
          same issue?
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Lots of Whirlpool brand dishwashers here catch fire.
            Our last Whirlpool started stinking, and didn't wash well. A week after I gutted it, that same exact model was recalled!
            Our current KitchenAid (made by Whirlpool (sigh!)) had the soap dispenser solenoid catch fire (melted, and smoked). That shorted out and burnt up the damn control board too. Costs over $150 for a new control board!
            Muh-soggy-knee
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              Another website, about how Whirlpool (makes KitchenAid) ignores these DANGEROUS issues!
              http://kitchenaidfire.com/
              Click the "Whirlpool Customers with Concerns" button to see ALL the complaints!
              Muh-soggy-knee
                master hoarder
                • May 2008
                • 12175
                I guess we will be leaving our old dishwasher alone then. My parents have been wanting to change it for a while now since it's fairly old. I say old and proven, though. Will try to convince them to leave it. Not like anything is wrong with it either. They are just watching too many crappy renovation shows on HGTV. IMO, "stainless steel" appliances are overrated.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Agreed.
                  Ours is "stainless steel"
                  Muh-soggy-knee
                  • frontshop
                    • Sep 2012
                    • 6
                    • uk
                    Hi, No it had completed the cycle I have found that the connections are overheating and carbonising until it eventually ignites. The dishwashers are generally 4 to 5 years old before eventually setting on fire...
                    • seanc
                      • Nov 2008
                      • 1319
                      Yes, there seems to be a common pattern where the other components such as soap dispenser solenoid will fail and cause the control boards to fail, either by popping a component or fire.
                      My friend has my old FDW60 and I've told him about this issue. It's about 8 years old at this point having been used heavily, almost non-stop in a home with a lot of people.
                      The saving grace might be that for the last few years the tablet dispenser has never been used, because the lid gets stuck if you close it.
                      I wonder if the solenoid gets stuck trying to open the dispenser and the board overheats.
                      Interestingly I became aware of this issue because an SDW60 (slimline) at a company I visited was making an interesting 'hot' smell - so it got turned off. Whatever the issue was it must have been fixed because it's in use again.
                        master hoarder
                        • May 2008
                        • 12175
                        Ah nothing new and unexpected about that then. I've seen this happen in many other appliances. My uncle's electric boiler, for example, melted the power switch in a similar fashion until the breaker tripped.
                        Those connectors always seem to cause trouble in high current applications. In my opinion, they should NEVER be used for high current.
                        The worst I've seen (and had to fix) was in an ACHI Pro-SC rework station. There, the Chinese used screw terminal connectors and stranded wire. Now this would have been fine if they cared to tin the ends of the stranded wire before screwing it on the connectors - but they didn't. Result: lots of heat. In fact, there was so much of it that the main screw terminal block that hooks up all of the power wires melted. The ACHI Pro-SC being a 240V station, you can imagine the bang this thing made when live shorted to ground. I was actually there when that happened.
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          Even if impossible to understand, the label of a control unit on the last video looks like it says
                          "MADE IN CHINA" at 1:59.
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • frontshop
                            • Sep 2012
                            • 6
                            • uk
                            Thankfully after many phone calls to Hotpoint Indesit I have finally forced a recall, I was interested to find that GE who used to own Hotpoint also issued further recalls on the same day. you can read my full story here http://dishwasherfire.blogspot.co.uk/ please keep safe and never use timers on white goods especially at night
                            • cheapie
                              null
                              • Jul 2010
                              • 849
                              I once had an APC UPS (Back-UPS ES 350) that died thanks to a connector of the same type melting. It ran fine on battery, but the outlets shut off when AC was connected.
                              More on topic, I have a recalled Bosch dishwasher. I wonder if it's a similar board causing the problems. I called a repair shop, and they said they would order the part and call me when it got in. They still haven't called me back after about a month and a half...
                              • frontshop
                                • Sep 2012
                                • 6
                                • uk
                                Hi Cheapie
                                Bosch have performed several recalls in the UK with the same problem, relay burning out on the control board!
                                • RJARRRPCGP
                                  • Jul 2004
                                  • 6304
                                  Looks like most "Bosch" stuff is meh Chinese stuff.
                                  Arc A770 16 GB
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    Do you know the affected model numbers on those by any chance?
                                    I know my sister has a Bosch dish washer that she bought only a few years ago. Will be visiting her this summer so would like to check that.
                                    • frontshop
                                      • Sep 2012
                                      • 6
                                      • uk
                                      Hi All,
                                      You can check your Bosch model here
                                      http://www.bosch-home.com/us/support...er-recall.html
                                      There is a list of the current UK model recalls here
                                      http://www.itv.com/news/2013-03-15/d...ch-dishwasher/
                                      The list of machines was too long to copy and paste!!! I think over in the USA you will probably have different model numbers.
                                      Best regards
                                      www.dishwasherfire.blogspot.co.uk
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        Thanks for the info.
                                        Looks like affected models only include dishwashers made between 1999-2005, so my sister's won't be in that list (I think she got it around 2009 or 2010).
                                        • AlexVG
                                          Replacing the WiFi module on a vacuum cleaner iROBOT i7
                                          by AlexVG
                                          I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
                                          I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
                                          (This board does not respond, only the LEDs light up in a circle.
                                          The liquid damage is catastrophic and restoration is impractical).
                                          (I bought this board to get the WiFi module and camera).
                                          The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
                                          If...
                                          10-22-2024, 07:20 AM
                                        • repair-it
                                          TOSHIBA DLP 52HM95 How to reset timer module on bulb
                                          by repair-it
                                          I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                                          Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                                          10-11-2023, 07:18 PM
                                        • m1ch43lzm
                                          70mai Dash Cam A510 - help identifying connector on camera module
                                          by m1ch43lzm
                                          Hi everyone
                                          I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
                                          The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
                                          I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
                                          05-11-2025, 06:02 PM
                                          Light that has a bug zapper in bottom section of light fixture the LED light module took a crap but the zapper still works
                                          So I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
                                          The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
                                          You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line...
                                          09-07-2024, 07:26 PM
                                        • DriversScrew
                                          Omnitronic TUNA-NET Internet Radio - M1088 Module - any information or software?
                                          by DriversScrew
                                          I've got an Omnitronic TUNA-NET internet radio with an all in one module built around an esp32. The module must be a M1088 from ALD Ltd.
                                          The device shows only a white display screen pulsing every second. Seems to have some kind of boot issue. All voltages and the pcb thermal signatures look good.
                                          Any information about the M1088 module, schematics or firmware would be helpful....
                                          10-04-2025, 04:33 PM
