Kind of a different question...
    Re: Kind of a different question...
    Bottom line, you need to ground the exposed metal of the computer to the AC safety ground, and to add safety, plug the AC adapter into GFCI outlet.
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      You mean one of those outlets they put in bathrooms?
      sigpic
        • 31283
        the metal in the socket bit is probably just for strength.
        meter the resistance between that stud and the macbook body with the charger connected.
        • EasyGoing1
          Shock Therapist
          • Sep 2016
          • 977
          Big goose egg ... but I can still connect a wire to it on the inside of the PSU and use it as my point of entry.
          sigpic
            • 31283
            maybe you can just replace the 2pin socket with a cloverleaf style
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8706
              if it's a true ground pin why doesn't #%&*$ offer a 3 prong head for that charger?
              But even if they do, where's that Y capacitor? Is it in the head?
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8706
                The magic smoke leaked out of this one ... https://www.badcaps.net/forum/showthread.php?t=94756 seems that round button is connected somewhere.
                  • 31283
                  no, they are just using the backing to secure a thermal fuse.
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    That's a good idea ... I'll have to see what I'm dealing with once I get the PSU apart. The default configuration of the PSU is an adapter with just two prongs sticking out... no power cable at all... and the PSU is so big and heavy, plugging it into a power strip that way is useless.
                    sigpic
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      You might be right ... unless this wire is coming from the transformer ...
                      sigpic
                      • TechGeek
                        Computer Geek
                        • Jan 2015
                        • 2254
                        Can confirm that the metal stud is grounded. Connect a grounded Apple charger cable to it and your problem should be solved.
                        Permanently Retired Systems:
                        Kooky and Kool Systems
                        sigpic
                        • EasyGoing1
                          Shock Therapist
                          • Sep 2016
                          • 977
                          I'm not so sure about that. This PSU is from a 2019 MBP and when I did a continuity check between the metal stub and the chassis of the laptop, I got nothin.
                          sigpic
                          • TechGeek
                            Computer Geek
                            • Jan 2015
                            • 2254
                            As in infinite resistance or 0 resistance?
                            sigpic
                            • petehall347
                              • Jan 2015
                              • 4448
                              • United Kingdom
                              #34
                              might be worth asking apple what to do ..or maybe first ask if you should be feeling electricity on the metal parts .
                                • 31283
                                apple: "that's not electricity your feeling, it's euphoria from the joy of owning apple"
                                  Use your AC Volt meter to measure the Voltage between AC outlet ground and the metal part of the Macbook.
                                  Plug the Macbook power supply into the GFCI outlet then use your AC Amp meter between outlet ground and the metal part of the Macbook to see how much current you are seeing.
                                  • EasyGoing1
                                    Shock Therapist
                                    • Sep 2016
                                    • 977
                                    This is how much Apple Euphoria I'm getting from my laptop right now... that's from the ground port on the wall socket and the part of the laptop where I often rest my palm.
                                    sigpic
                                    • petehall347
                                      • Jan 2015
                                      • 4448
                                      • United Kingdom
                                      #38
                                      now test the current .
                                      • EasyGoing1
                                        Shock Therapist
                                        • Sep 2016
                                        • 977
                                        im getting ZERO for amperage
                                        sigpic
                                          • 31283
                                          your meter is not showing it right - i'v seen that with flukes before, i think they filter out high frequency stuff.
                                          • motormayhem
                                            Lenovo T460 Only Charges on One Charger
                                            by motormayhem
                                            Laptop Question
                                            I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                            A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                            05-12-2023, 01:46 PM
                                            NVDC charger configuration...
                                            11-05-2024, 03:28 PM
                                          • flat-earther
                                            ASUS X54H laptop thinks it's always charging even with charger unplugged
                                            by flat-earther
                                            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                            Windows also shows ''Plugged in'' when charger is not connected.
                                            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                            If I let battery run out and say it has 3% Windows will...
                                            06-24-2025, 09:32 AM
                                          • Johndill
                                            Dell Inspiron 7567 LA-D993P odd charger issue
                                            by Johndill
                                            Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                            There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                            I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                            Here are the tested scenarios:
                                            1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                            2. With the laptop off, plug in charger (LED says on) & the front charging...
                                            11-16-2022, 10:55 PM
                                            ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                            Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                            The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                            for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                            Narrow VDC applications where the system power source is
                                            either the battery pack or the regulated output of the charger.
                                            This makes the max voltage to the system equal to the max
                                            battery voltage instead of the max adapter voltage. Operating
                                            at lower system voltage can improve...
                                            11-05-2024, 04:43 PM
