Kind of a different question...
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    I'll try to describe this as best as I can ... but ...
    My laptop is a MacBook Pro and therefore, the casing is made of metal ... aluminum I believe ... but when it's plugged into the charger and I rub my fingers ... or glide them ... across the metal by the trackpad, I feel like ... an electrical vibration? I don't know what to call it other than that, but when it's just running on the battery and not plugged into the charger, it doesn't do it.
    Anyone know what that is or how I can make it stop? I want to say it's a bad ground maybe?
    Thoughts?
    sigpic
    • 31137
    Re: Kind of a different question...
    lol
    2pin charger is it?
    welcome to modern switching psu design.
    the mains input is connected to the 0v lead to the laptop via a ceramic cap!!!
    i'v said in a lot of threads that these fucking supply's should have a ground-pin on them!
    if you think that's bad, i was almost thrown off a ladder by this bs design,
    i was working on a tv antenna and the coax was live from a tv with a switching psu and 2pin power cable.
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      Originally posted by stj
      lol
      2pin charger is it?
      Why as a matter of fact ...
      So is there any way to fix it other than trying to find a power supply designed to work with a MBP that is properly grounded?
      And why am I feeling that buzzing sensation? Is it because I'm more grounded than it is?
      .... and because you were on the ladder or touching the antenna mast which was touching the ground, your difference of potential was severe enough to feel that? Assuming of course that's the problem ...???
      sigpic
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        lol
        2pin charger is it?
        I just did a test and was rubbing the metal then I took my feet off the carpet and it stopped ... so I think I answered my own question as to WHY ... but as to how to fix it???
        sigpic
          • 31137
          you need to ground the psu or the laptop
          because here 340vdc hurts more than your 168v!
          • petehall347
            • Jan 2015
            • 4429
            if its 2 pin mains plug try it the other way .
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              That didn't work
              sigpic
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                I've always been curious as to why the UK and Australia and so many other countries use 240 as their standard voltage.
                sigpic
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  OK, grounding the PSU would be easier I would think, since its plugs are millimeters away from the ground port on the outlet ... but where would I connect it to? The internal shielding?
                  sigpic
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    You need a three prong plug from the wall to the PSU and change the coupling internal to the PSU from the ground output of the laptop wire to the ground pin you just added...
                    A lot of work, yes. And more wire.
                      • 31137
                      simple,
                      when you have a real man's electrical supply you run everything at half the current for the equivelent wattage.
                      so your cables, switches, breakers etc are cheaper and more compact.
                      you just need to be more carefull with the design of sockets etc in relation to clearances and insulation.
                      at 230v a KW uses about 4A, you need 8A for the same power.
                      so i have a 2.4KW kettle that boils real fast.
                      you would need about 20A for that - and very thick heavy cable.
                      • EasyGoing1
                        Shock Therapist
                        • Sep 2016
                        • 977
                        simple,
                        sigpic
                        • EasyGoing1
                          Shock Therapist
                          • Sep 2016
                          • 977
                          simple,
                          In case you missed it ...
                          sigpic
                          • EasyGoing1
                            Shock Therapist
                            • Sep 2016
                            • 977
                            Could you ummm ... elaborate a little on this ... "change the coupling internal to the PSU from the ground output of the laptop wire to the ground pin you just added"
                            Sounds like you're saying that all I need to do is connect the ground pin from the outlet to the ground of the laptop via the PSU... did I interpret that correctly?
                            I mean that seems like the logical thing to do ... where else would one connect the earth in a circuit?
                            sigpic
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Ultimately whichever pin, most likely the negative pin output, needs to be connected to earth ground. The capacitor that currently sits there should be disconnected from the power rail that it's currently connected to.
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                So I did a little poking around and apparent Apple makes ... or use to make ... a three prong extension cable that you would swap out with the two prong attachment on the PSU and apparently this metal round disc is where the ground wire would connect to
                                My PSU has that on it... I'm thinking this might be a real simple fix... time to fire up the 3D printer.
                                sigpic
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  As always, devil's in the details...
                                    • 31137
                                    but is that stud actually earthed, or just for strength?
                                    • EasyGoing1
                                      Shock Therapist
                                      • Sep 2016
                                      • 977
                                      Well, Hre is a photo of the extension cables that I guess Apple use to sell ... notice there are metal contacts where it would be straddling that metal disc ...
                                      I don't have a USB-C breakout board or cable or I'd check to see if there is continuity between it and the ground on the cable.
                                      sigpic
                                      • EasyGoing1
                                        Shock Therapist
                                        • Sep 2016
                                        • 977
                                        Either way, thats going to be my point of entry for my custom cable connector that im working on...
                                        sigpic
                                        • motormayhem
                                          Lenovo T460 Only Charges on One Charger
                                          by motormayhem
                                          Laptop Question
                                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                          05-12-2023, 01:46 PM
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • Johndill
                                          Dell Inspiron 7567 LA-D993P odd charger issue
                                          by Johndill
                                          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                          Here are the tested scenarios:
                                          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                          2. With the laptop off, plug in charger (LED says on) & the front charging...
                                          11-16-2022, 10:55 PM
                                          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                          Narrow VDC applications where the system power source is
                                          either the battery pack or the regulated output of the charger.
                                          This makes the max voltage to the system equal to the max
                                          battery voltage instead of the max adapter voltage. Operating
                                          at lower system voltage can improve...
                                          11-05-2024, 04:43 PM
