Kind of a different question...
    • Jul 2011
    • 6070
    Re: Kind of a different question...
    Originally posted by eccerr0r
    If you plug it into a GFCI outlet, short the case of the laptop to ground, and it trips, then you know you have a problem...
    This is a great point I would not have thought about doing this to find out if you had an issue with stray voltage on a device to do this to find if it is going to be an issue or not
    switching power supply that only have a two wire connector I find is a little stupid in my estimation because of what you have experienced that you might feel a tingling sensation on a metal part of the device is not acceptable in my book
    Yes this might be a little off topic but I have also seen this happen as well
    You can also have this on air conditioning compressor that have an issue with the varnish breaking down on the windings and leaking voltage into the oil and when it first starts happening it sometimes not enough to trip some GFCI outlets but when it gets worse then it will trip the GFCI outlet that someone has a bad grounding pin or has cut off the grounding pin on the power supply cord
      • 31283
      actually it can kill you.
      if your working outdoors on an aluminium ladder fixing something that is powered like this then it's enough current to throw you off.
      i have had several shocks like that from tv antenna's and a sat dish!!
      fucking 2 wire mains cords mean the "earth" on the cables is 340v relative to the ground the ladder is standing on!!!
      • motormayhem
        Lenovo T460 Only Charges on One Charger
        by motormayhem
        Laptop Question
        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
        05-12-2023, 01:46 PM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • flat-earther
        ASUS X54H laptop thinks it's always charging even with charger unplugged
        by flat-earther
        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
        Windows also shows ''Plugged in'' when charger is not connected.
        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
        If I let battery run out and say it has 3% Windows will...
        06-24-2025, 09:32 AM
      • Johndill
        Dell Inspiron 7567 LA-D993P odd charger issue
        by Johndill
        Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
        There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
        I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
        Here are the tested scenarios:
        1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
        2. With the laptop off, plug in charger (LED says on) & the front charging...
        11-16-2022, 10:55 PM
        ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
        Highly Integrated Narrow VDC Battery Charger for Notebook Computers
        The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
        for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
        Narrow VDC applications where the system power source is
        either the battery pack or the regulated output of the charger.
        This makes the max voltage to the system equal to the max
        battery voltage instead of the max adapter voltage. Operating
        at lower system voltage can improve...
        11-05-2024, 04:43 PM
