Apple 85W MagSafe Power Adapter - blown - help with components
  • bastyani
    • Apr 2021
    • 6
    • Slovenia
    Hi, I have an 85W MagSafe Power Adapter, Model No: A1343, worked ok,
    then suddenly dead. Opened it up and there are a few components blown.
    Two resistors and a chip.
    You can see more on the attached pictures.
    Unfortunately I can only read the few last characters on the chip - an N on the top and 3261 or 5261 on the bottom (can't rally tell, the character is halfway visible but most probably is a 5261). The chip is blown right on the position where the model/type is printed. The resistors are also hard to tell.
    Can anyone of you experts tell me if it is possible to source the right chip and the resistors and replace them? All other seems ok. Another question is why this happened?
    Will it hipoteticaly work if those things are changed or is there a problem somewhere also and they will be blown up again?
    Thank you for your help!
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Apple 85W MagSafe Power Adapter - blown - help with components
    Find out the Schematic check the pic
    • bastyani
      • Apr 2021
      • 6
      • Slovenia
      Hi techtiger,
      thanks for the schematic. As I can see the IC34 is not the same? It has 14 pins, the chip on my board has 16 pins...
      • bastyani
        • Apr 2021
        • 6
        • Slovenia
        Maybe instead of the DAP013F it is the DAP015D?
        • PeteS in CA
          • Aug 2005
          • 3583
          • USA, Unsure of Planet
          My guess is that the 3-pin power device near those two blown resistors, probably a MOSFET, is shorted. If it is a shorted MOSFET, the blown IC may be in its Gate circuit and was exposed to high voltage when the MOSFET shorted Drain to Gate. The resistors look like low value current sense resistors in the Source circuit. The surge of current when the MOSFET shorted Drain to Source fried the resistors, and may have vaporized some of the trace connecting the resistors to the source, damage that would need to be repaired.
          PeteS in CA
          • ACS-Repair
            • Feb 2021
            • 204
            One thing to keep in mind here is that by piecing this back together you may be at risk of it blowing up again in the near future and potentially causing a fire. Think about whether the risk is worth just replacing it.
            • bastyani
              • Apr 2021
              • 6
              • Slovenia
              Hi guys, thank you for the replies!
              Thanks "PeteS in CA" for a thorough explanation. I was sure there must be something else wrong that blew the IC and the resistors... I will also check the MOSFET. I am also a little worried about the "vaporized traces", hopefully I will be able to fix them. Any idea on the resistors values?
              Thanks "ACS-Repair"! I know that, and that's why (if I manage to fix it) I will only use it as a "backup" under supervision.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Could we see a few pictures of the top-side of the adapter where the components are? That should help us determine what that MOSFET is doing. It's clearly on the primary side, as the presence of the Source resistors suggests. But whether it's used for the APFC circuit (if there is even one) or the switching device for the PS, that's what we need to know.
                Generally, these adapters won't blow from an overload on the secondary side, but could blow from over-temperature, high voltage spikes / dirty power from the lines, or also if the main input bulk cap has failed... which could be the case here if this adapter is old and/or was used a lot and/or has APFC.
                As long as the correct replacement parts are used and fuse is rated properly, it's extremely unlikely for these adapters to cause a fire. Now if it was any cheap Amazon/eBay/AliExpress "replace power" adapter, I would be worried about those even when new out of the box. But this genuine one is made by Lite-On, and Lite-On doesn't half-ass their stuff when it comes to safety and fire-hazards. So I wouldn't be worried about the adapter once repaired... so long as we can find out what went wrong and why.
                • bastyani
                  • Apr 2021
                  • 6
                  • Slovenia
                  Hi momaka!
                  Yes, of course! The top side had a lot of "silicone" in there and it was really time consuming to put it all out. You have to go slowly and carefully to not damage any of the components.
                  P.S.: someone knows if this "silicone" is there just to "hold" the components or is it something more "special" and maybe has increased thermal conductivity to spread the heat around more evenly??
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Thanks!
                    Looks like your APFC circuit MOSFET has likely bit the dust. So replacing the burned resistors and the IC likely won't solve the problem.
                    First step would be to remove all components that might be affected. This means the big cap and the three TO-220 components (2x MOSFETs and 1x diode) mounted on the heatsink shown in this picture:
                    https://www.badcaps.net/forum/attach...5&d=1618132438
                    For the big cap, you will need to check its capacity and ESR. APFC circuits typically blow when these reach end-of-life and go high-ESR / open-circuit. For the MOSFETs and diode - check for short-circuit on pins. In addition to that, check the input fuse, bridge rectifier, and NTC (if there is one... though there usually is.) All of these could have been taken out when the APFC MOSFET blew. In other words, time to heat up your soldering iron and start removing parts. Unfortunately, that's the only way to fix this fault... and for a power adapter like this, it may not be worth it, unless you're doing it for an educational experience.
                    A little bit of both, actually.
                    That is, the adapter will work OK without it but may run justly a tad bit warmer internally. And if you drop it, it may not be as resistant to shock as before. But either way, it's *not* that important that you replace this silicone.
                    • cheeky2
                      Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                      by cheeky2
                      This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                      I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                      Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                      06-15-2025, 05:12 AM
                    • zlr8r
                      HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
                      by zlr8r
                      Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
                      To begin with, this laptop was dead-dead.
                      Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
                      • am getting white power led
                      • 5-long-flashes on CAPS Lock and NUM lock
                      • then, fan full speed
                      • CPU heats up some (smaller die PCH, does not)
                      • always constant black screen no matter what's tried
                      • no USB recognition
                      • no HDMI output
                      this is as far as I can get with it and not sure where to inspect next ?
                      I tried...
                      03-27-2024, 03:13 PM
                    • reessi
                      20v / 2A SMPS for a Battery Charger - Explanation of Blown Resistors Please..
                      by reessi
                      My friend asked me to replace the wire going from this SMPS 20v adapter to the charger for a 18v Lithium Battery for a drill.
                      The cable had frayed and been touching, as a result the 5 Paralleled R200 (0.2 ohm) resistors had blown O/C, they are connecting the main -ve rail to the output wire.
                      The output was jumping around 13v and dis-appeared when a load like the charger was connected, they measured 900ohms.
                      I experimented by replacing at first a single 0 ohm and then a 2.2ohm in and the output was restored at 21.62v and 21.65v respectively...
                      08-22-2024, 08:12 AM
                    • VitalComputing
                      Chuwi HeroBox blown components
                      by VitalComputing
                      Hi everyone,
                      I have a Chuwi HerBox that has a number of blown components that I am having difficulty identifying. No schematic available.
                      The fault is that the HDMI port does not really function properly, video looks shaky and has lines. The box boots fine on VGA, so I think the problem is isolated to the HDMI.
                      The section below is the only section that seems to have damage to three components.
                      1. Blue Arrow = I think this was a capacitor (as it is connected to ground) that blew clean off the board.
                      2. White Arrow = I think this is...
                      05-28-2023, 02:48 AM
                    • duwane
                      Apple 85W MagSafe Power Adapter - blown - help with component identification
                      by duwane
                      Hi All.
                      I have an Apple 85W MagSafe Power Adapter (Model No: A1343) that has a blown power MOSFET (Q050 - Infineon IPP60R299CP - - all 3 pins dead short). When the FET blew it took out an SMT resistor, as well as possibly vaporizing an entire capacitor and its pad (see attached photos). Hopefully that will be all that is blown, but until I can replace the FET and the other physically damaged components I can't tell.
                      The burned resistor and cap in question are located underneath the large main cap (as seen in 2nd and 3rd images).
                      Is anyone able to measure...
                      06-02-2022, 10:35 PM
