Advice on ESR and Capacitance meters
  • Agent24
    I see dead caps
    • Oct 2007
    • 5085
    • New Zealand
    I'm thinking of buying these, obviously without them my diagnostic method is limited to either:
    1) Is it bulging/leaking?
    2) Is it a Fuhjyyu?
    Any recommendations on what I could get?
    Are kits better or do they require expensive equipment to calibrate?
    -David VanHorn
  • larrymoencurly
    • Oct 2004
    • 960
    Re: Advice on ESR and Capacitance meters
    I bought an original Bob Parker ESR meter kit (red LEDs), and it didn't need calibration, except for the low battery voltage. The instructions were very good, with the troubleshooting section listing lots of common mistakes, including the one I made (mix-up of resistor color bands). The only thing I didn't like was the insulator that went between the PC board and battery -- it was just a piece of corrugated cardboard that I thought might allow a short, so I replaced it with a piece of bare PC board material.
    • Krankshaft
      • Jan 2007
      • 2328
      On the Blue ESR meter it needed both low battery voltage calibration and resistance calibration for the ESR readings. They included a 1% tolerance resistor and you had to adjust the POT to match it's resistance.
      I'm sure the Dick Smith version had that too since the design changes on the blue board from the DS are subtle.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5085
        • New Zealand
        So the blue meter is recommended?
        -David VanHorn
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          my first choice.
          i have several of the early dick smith kits.still fine after heavy use.
          the blue is just pretty.same unit.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5085
            • New Zealand
            Does the Blue version have the protection diodes or is it only the Dick Smith kit which has these?
            I was under the impression the Blue version does not...
            -David VanHorn
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              you can add the diodes to either.
              i didnt as i use mine to check batteries.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5085
                • New Zealand
                Wait, what?
                The manual for the MK-I Dick Smith version says
                "Protection: Sooner or later this meter
                will find itself connected to an unexpect-
                edly charged capacitor (or worse), so
                some protection has been built in. D3
                D4, D5 and D6 are strategically placed
                to prevent destructive voltages from
                finding their way back to the microcon-
                troller; D4 also limits the test voltage to
                0.6V peak."
                Looking at all 3 manuals for MK-I, MK-II and Blue they all use these diodes in similar places on the schematic...
                Are these the same ones you are talking about?
                -David VanHorn
                • Krankshaft
                  • Jan 2007
                  • 2328
                  The meter will take up to 50 volts I believe with it's integral protection.
                  They're talking about hefty high amperage diodes to save the meter from being connected to a charged line filter for example.
                  I installed my own set of back to back high amperage diodes on the output of the Blue once however it caused fluctuations in the meters output so I removed them.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Wait, what?
                    0.6V peak."
                    Not the same diodes.
                    There is a mod to add protection against connecting to undischarged high volt caps.
                    I added them to my MK-II and it works fine.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5085
                      • New Zealand
                      How does one go about adding that mod then?
                      -David VanHorn
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Read page 12 under "Heavy Duty Protection".
                        https://cdn.badcaps-static.com/pdfs/...323c887511.pdf
                        Those diodes are fairly big.
                        You'll need to be creative to get them inside the unit.
                        Just barely fit in the MK-II. Dunno how you'd get them into the blue one.
                        - Dr Seuss
                        • Toasty
                          • Jul 2007
                          • 4171
                          Inline 100-200mA fuse.
                          veritas odium parit
                          • Krankshaft
                            • Jan 2007
                            • 2328
                            The IN5404 diodes mod can be done with the Blue.
                            You solder them to the solder side of the PCB right where the output probes solder in.
                            I was able to bend them in such a way that they fit and the board would reinstall into the casing.
                            I guess a fuse would add too much ESR? That does seem like the simpler solution. But I'm sure there's a reason that the diode method was developed.
                            • Toasty
                              • Jul 2007
                              • 4171
                              Fuse does not add to much ESR. It is compensated for when you setup/calibrate the unit and zeroed every time you use it. It is ahead of those protection diodes on 1 of the the incoming leads. If you hit a too highly charged cap, it pops, saving the meter from the inrush high current. Low current was chosen so that it would fail quickly, saving the meter. The diodes do their part on low charge ones.
                              I want to try a MOV at some point to further protect, but that's an experiment for another day. The fuse solution works for me.
                              I went with a small glass pigtail fuse, but a pico fuse would do just as well.
                              Toast
                              veritas odium parit
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                What is the response time of a fuse compared to the response time of a diode?
                                I dunno, I didn't look it up, but
                                I'm pretty sure a fuse burning open is considerably slower than a diode begining to conduct.
                                Also don't have to keep track of spare 'oops' fuse[s].
                                Another consideration is if you use a 120v fuse and hit a cap charged to 450v or something the current can arc right through the fuse body.
                                I put my diodes on the back side of the lead jacks so they are between the PCB and the cap under test.
                                MOV idea sounds interesting.
                                Last time I did anything like blowing a meter was back in the 80's anyway.
                                It's just fun dinkin' around with the toys, um, I mean test equipment.
                                - Dr Seuss
                                • lucky13
                                  • Aug 2007
                                  • 412
                                  After pondering on the Blue ESR meter for a long time, I finally bought the ESR-Micro from Russin Mike. I like it very much. The only thing is the leads. They are not your test probe length and style (i.e., removable). However, it is very small and compact.
                                  I use the alternate mode to read the capacitance & ESR and it is so good to see both w/o using two different meters.
                                  Look into it.
                                  • ecking767
                                    • Oct 2009
                                    • 492
                                    Hello, I just purchase The Blue ESR meter kit and it was easy to assembly and to calibrate. Its have an easy to read chart and so I was testing caps with-in an hour. There is nothing I will change on this setup, the test leads are OK for now. It works great. hope this help you in your decision
                                    • Toasty
                                      • Jul 2007
                                      • 4171
                                      @ ecking767 -
                                      >>There is nothing I will change on this setup,<<
                                      You should consider putting in the back-to-back diodes for protection, unless you're going to use it to check batteries.
                                      Toast
                                      veritas odium parit
                                      • ecking767
                                        • Oct 2009
                                        • 492
                                        Toasty- I have a printed label on my meter saying " dis-charge caps" so I don't make a costly mistake and burn out my esr meter. So I not going to make any changes. Thanks for the advise !!
                                        • Ady2017
                                          SMD fuse soldering advice please
                                          by Ady2017
                                          Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
                                          11-07-2025, 12:03 PM
                                        • DCJack
                                          B&K 707 tube tester. I need help.
                                          by DCJack
                                          Hi everyone!
                                          I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
                                          Initially I noticed that I was not getting the red on-light to turn on, but it...
                                          03-05-2024, 05:05 PM
                                        • jaco2d
                                          Hisense calibration
                                          by jaco2d
                                          Hi i recently purchased a Hisense u7hqtuk TV, there is 2 different version of this set, the UK, Europe one and the America one, i have the UK and Europe version.
                                          I have searched for calibration for the TV but i can only find it for the America one which has 1000 nits, the version i have has got 600 nits so the calibration settings will not work.
                                          Has anyone got this TV and managed to get good picture setting for it or can anyone find a link to the calibration settings?
                                          The picture is good enough but if possible i would like to get the best possible picture settings for the...
                                          09-20-2023, 12:20 PM
                                        • Junkrepair
                                          Calculating ESR from tan delta -- tan delta's dependence on capacitance
                                          by Junkrepair
                                          I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                                          I found this nice little description of the conversion:
                                          Calculating capacitor ESR from Tan(delta)
                                          https://forum.digikey.com/t/calculat...-from-tan/2633
                                          It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                                          06-12-2023, 02:45 PM
                                        • SwedishDiesel
                                          Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
                                          by SwedishDiesel
                                          Howdy folks,
                                          I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
                                          10-30-2021, 12:47 AM
