Advice on ESR and Capacitance meters
  • Agent24
    I see dead caps
    • Oct 2007
    • 5086
    • New Zealand
    Re: Advice on ESR and Capacitance meters
    That's a good idea but unfortunately it still won't protect against accidents. Personally I think I would also add the diodes if I wanted to make sure
    -David VanHorn
    • Toasty
      • Jul 2007
      • 4171
      hmmmm...
      $1 worth of diodes or $80 worth of meter? Let me think on that....
      veritas odium parit
      • cloepula
        • Sep 2009
        • 49
        I m using a esr micro from Mike Klykov. Measure esr from 0.01 ohm to 160 ohm, and capaciti from 1 to 60000 microfarad. Verry good instrument for a not to manny money. Came with bateries inside and i m usin him for over a year and batteries are still ok. Came with manual and completly assembled, and in manual you can find a most common capacitor esr aproximate values. I think was 100$ with postal charges, and arive to me in four days, instrument was 55$ i think and postal charges was 45$.
        • cloepula
          • Sep 2009
          • 49
          And shure, when dealing with caps, always be shure thet the caps are discharged, for your,caps, and meters safety.
          • Ady2017
            SMD fuse soldering advice please
            by Ady2017
            Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
            11-07-2025, 12:03 PM
          • DCJack
            B&K 707 tube tester. I need help.
            by DCJack
            Hi everyone!
            I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
            Initially I noticed that I was not getting the red on-light to turn on, but it...
            03-05-2024, 05:05 PM
          • jaco2d
            Hisense calibration
            by jaco2d
            Hi i recently purchased a Hisense u7hqtuk TV, there is 2 different version of this set, the UK, Europe one and the America one, i have the UK and Europe version.
            I have searched for calibration for the TV but i can only find it for the America one which has 1000 nits, the version i have has got 600 nits so the calibration settings will not work.
            Has anyone got this TV and managed to get good picture setting for it or can anyone find a link to the calibration settings?
            The picture is good enough but if possible i would like to get the best possible picture settings for the...
            09-20-2023, 12:20 PM
          • Junkrepair
            Calculating ESR from tan delta -- tan delta's dependence on capacitance
            by Junkrepair
            I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
            I found this nice little description of the conversion:
            Calculating capacitor ESR from Tan(delta)
            https://forum.digikey.com/t/calculat...-from-tan/2633
            It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
            06-12-2023, 02:45 PM
          • SwedishDiesel
            Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
            by SwedishDiesel
            Howdy folks,
            I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
            10-30-2021, 12:47 AM
