Will This Work?
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    Will This Work?
    I want to use these inexpensive 18650 battery chargers but if you accidentally connect the battery in reverse polarity, the charger fries in less than a second. Picture 1 shows the normal operating mode of the charger and the reverse connection NO NO and picture 2 shows what I am thinking might protect the charger from reverse bias damage while still allowing enough current to flow when the batter is connected properly for normal charging.
    Will it work?
    sigpic
    • Jul 2011
    • 6070
    Re: Will This Work?
    I would check the cut out voltage to the 18650 and make sure that it does not go any higher than 4.2 volts
    Other than that you should be ok
      • 31289
      Re: Will This Work?
      you may want to look at the input polarity on your diagram!
      btw:
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        Re: Will This Work?
        btw:
        Yeah, that was a diagram mistake I saw it after I posted.
        sigpic
          Re: Will This Work?
          If you look at the internal circuit of the 4056, you will see what gets damaged when battery is connected in reverse.
          https://cdn.badcaps-static.com/pdfs/...47c5c03bfe.pdf
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8711
            Re: Will This Work?
            I wonder if the LT LTC device can withstand the reverse connected battery better than the chinese TP device?
            BTW, despite their base part numbers, it looks like they are not pin compatible...
            • R_J
              • 9624
              Re: Will This Work?
              Is this of any use to you? http://blog.deconinck.info/post/2017...ity-protection
              There is also this board https://www.hotmcu.com/tp4056-micro-...ion-p-176.html
              • petehall347
                • Jan 2015
                • 4450
                • United Kingdom
                Re: Will This Work?
                might be easier to adapt a battery holder that is foolproof .
                  • Jul 2011
                  • 6070
                  Re: Will This Work?
                  I have a charger that supposedly has that feature and it works HOWEVER there is a catch to this and if you DO NOT follow this to letter it will burn this feature out and will not work any more
                  When you have the battery hooked up one way do not reverse the polarity for at least 5 minutes or you will burn it up
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    Re: Will This Work?
                    Are you thinking this MOSFET that appears to be directly in the line of fire in a reverse polarity scenario? I'm thinking those series resistors probably put on a nice light show as well ... ???
                    sigpic
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      Re: Will This Work?
                      I'd LOVE to see a picture of such a battery holder for 18650's .. I can 3D print whatever I need, but I can't imagine any mechanical way to prevent someone from accidentally plugging the batterys in backwards unless it had some kind of mechanical means like a contact that breaks loose when the lid is up then maybe an LED indicating incorrect insertion ... where the contact cant be made until the lid it closed but beyond that Ive tried to think of a way to do it mechanically and I just cant think of a way that is also simple to implement.
                      sigpic
                      • EasyGoing1
                        Shock Therapist
                        • Sep 2016
                        • 977
                        Re: Will This Work?
                        Originally posted by R_J
                        THIS WAS A GOOD FIND!!! It's almost the same circuit I came up with except for the addition of the PNP transistor which is very elegant and I love how the TP4056 sees NOTHING when the batter is connected incorrectly... this is clean!
                        So I did look at those boards before, but they are technically designed to be made into backup USB chargers for like cell phones when you're camping or whatever and you need to charge your cell phone, you would use your fully charged 18650's connected to that second board you listed .... and yes you can charge 18650's with those boards, there was something about it that I didn't like when I initially looked at them ... and I can't remember what it was now ... but tackling this TP4056 problem has been a back burner "moby dick" pursuit of mine for like two years now ... will be nice to get it behind me.
                        Thank You!
                        Mike
                        sigpic
                        • petehall347
                          • Jan 2015
                          • 4450
                          • United Kingdom
                          Re: Will This Work?
                          https://www.thingiverse.com/thing:3531895
                            • 31289
                            Re: Will This Work?
                            that junk wont work on flat-top cells.
                            • petehall347
                              • Jan 2015
                              • 4450
                              • United Kingdom
                              Re: Will This Work?
                              never said it would .
                                • 31289
                                Re: Will This Work?
                                but flat-top cells are the only ones that are decent - unless you weld your own protection-kit to them.
                                all the comercial cells with a nipple on the + are complete shit - mostly ending in "fire" yet with not enough real capacity to actually cause one!!
                                • brethin
                                  • Dec 2008
                                  • 1907
                                  Re: Will This Work?
                                  I have recycled over 10,000 18650 batteries, flat tops are no better than nipple. In fact the nipple tend to be better when using then in chargers and banks. I have had 0 fires.
                                  • Dev Goose
                                    Help Needed: Reverse Polarity Issue on HP EliteBook 840 G4 – Where Do I Begin?
                                    by Dev Goose
                                    Hi everyone, I recently acquired an HP EliteBook 840 G4 (6050A2854301-MB-A01) that I'm hoping to bring back to life. I'm fairly new to laptop repairs but eager to learn and willing to put in the effort to understand and fix this. Any advice or guidance would mean a lot!
                                    What Happened
                                    The issue started when the laptop was accidentally plugged in with reverse polarity. Before this incident, the laptop would show a power/charging light whenever it was plugged in. However, now it's completely unresponsive—no lights, no power, nothing. I've been doing some research and understand
                                    12-13-2024, 03:13 AM
                                  • exerion5000
                                    DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
                                    by exerion5000
                                    Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
                                    below normal, as if it were operating in an extreme energy...
                                    10-15-2023, 02:12 PM
                                  • spleenharvester
                                    Reverse engineering of 18650 4-channel tester
                                    by spleenharvester
                                    Hi friends
                                    I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                                    05-04-2025, 02:43 AM
                                  • double_DD
                                    HP Thunderbolt dock G2 - "fixing" it so it can work without original HP charger?
                                    by double_DD
                                    Hi guys,
                                    I do hope this is not off-topic.
                                    I have this mentioned HP dock which is half-defective, as it sometimes work and sometimes not. But that's not my main issue at the moment.
                                    I don't have any more original HP charger, and I would like to "fix" the dock so I can use it without it. Has anyone tried it, or maybe does someone know how to effectively bypass the "comm" pin of the charger?
                                    Maybe someone has a schematic that would be useful? There are markings on the board that say P&Q 2019 CM-4 94V-0 E162264, but when I try searching...
                                    09-10-2024, 05:16 AM
                                  • ktmmotocross
                                    asus FX506LI display goes half black when charger is attached and when laptop start or in bios. on battery in windows work ok
                                    by ktmmotocross
                                    Have this weird problem with asus FX506LI thats display goes half black when charger is attached and from start untill u pout charger in and pull it out. then display like switch to other mode and works ok.
                                    I try to shut sown nvidia gpu but it is still the same. there is no bios menu to power down nvidia card. it taped display so i want my options before i pull it out
                                    Asus FX506LI-HN227T
                                    SN-M4NRCX0S90516C...
                                    01-02-2024, 11:23 AM
