Using Kynar 30AWG for 120VAC
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8709
    I saw this and
    Granted this looks like a homebrew and at least 30AWG wire should fuse on its own if it shorts out...
    • 31284
    Re: Using Kynar 30AWG for 120VAC
    that's fine,
    the conductor is rated for 300v, the insulation breaks down at 2000v
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8709
      Most kynar 30AWG wire has "no spec" by UL for voltage, granted, kynar is fairly tough, hard to scrape the insulation. But it's much thinner than any other UL listed wire.
      UL does spec 105°C for max temperature which is probably good enough.
      Military spec kynar wire is good for 300V at least however. Not sure what the difference is other than 135°C.
      Now the question is whether it's good enough for 220VAC... now that is pushing it.
        • 31284
        data
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8709
          Yeah, "no voltage rating" is the key words that I see on many spec sheets - it's not rated for voltage like other wire. The conductor itself will handle 300V but who knows how close the other potential is... Usually these wires are used for less than 50V typically so nobody cares too much.
          I did not know typical wire wrapping Kynar wire were silver plated, thought it was tin. Nice, supposedly these should be pretty good for its diameter for RF.
            https://jaguarind.com/kynar-wire-tefzel-wire-wrap/
            • redwire
              • 3912
              It would be OK as long as there is a suitable fuse to prevent a fire hazard from over-current glow or melting.
              #30 AWG can carry around 1A max. before the insulation heats up too much, 105C, and 10A for 30 seconds before melting like a fuse.
              It's dangerous here because a hot wire would melt the electrical tape, transformer bobbin, and using #30AWG for protective earth-ground is forbidden in electrical codes.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8709
                Fortunately (???) the black wire isn't being used for chassis ground but rather as a common point tie. Whether one is allowed to share the main ground tie (green wire) with the thin black wire is acceptable, but it's probably okay.
                I think the maximum "normal" current flow is around 20mA or so estimated, so nowhere near the current limit fortunately. So unless something bad happens, the gauge is fine. Unfortunately no fuse or power switch on the primary -- it's a homebrew.
                Might have to add a fuse, but seems like one would need a fuse of 200mA or less or so, else the wire may fuse before the fuse. And those milliamp fuses are expensive...
                  • 31284
                  Originally posted by redwire
                  Iusing #30AWG for protective earth-ground is forbidden in electrical codes.
                  your codes are a joke though,
                  i was just watching a video where a guy has a hotdog grill - explosed metal grill&rollers etc.
                  and it only had a 2pin plug!!!
                  https://www.youtube.com/watch?v=CFILmL1E2U8
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8709
                    At least it's not a coffee-cutor...
                      • 31284
                      but the handheld elements have a handle and are obvious.
                      besides, you have to unplug them before moving them because of the heat.
                      the hotdog thing, you have to touch it to remove the food.
                      and you DONT EXPECT the metalwork to be live - but it could with no fucking earth wire!!
                      i find it strange, because my line of work - amusement equipment,
                      all u.s. origin stuff has literally every exposed bit of metal earth-bonded - even hinges have a braid running to them.
                      yet this METAL cooking device does not even have a 3pin plug!!
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8709
                        Then again, common toasters have 2-prong plugs too... or do they not?
                          • 31284
                          not in europe they dont.
                          the rule is simple, if there is any exposed metal then it must be earthed.
                          • redwire
                            • 3912
                            Earth-ground was added to North American electrical codes, for outlets, plugs, many appliances in 1962.
                            I don't know if Europe ever had ungrounded outlets or appliances. UK seems to have many different plugs.
                            1970's product that hot dog cooker. Newer ones have an on/off switch with the lid. I remember it made terrible tasting hot dogs if there was power-line sine-wave distortion, a slight net DC offset gave you some zinc flavour. Yuck.
                            Another product of the era was a baby bottle warmer, with two mains electrodes in a cup base and you fill with water. The water boils and warms the baby bottle.
                            But hard water did not do much (Ca, minerals low conductance) so you had to add a little salt or baking soda and if you put in too much you had 15A flowing through a boiling froth that was pretty scary loud. They were not safe.
                            • RJARRRPCGP
                              • Jul 2004
                              • 6304
                              Was that a cheap hot dog cooker?!
                              I don't like the sound of the mention of on/off switch with the lid. What I picture, is something that's cheap! (A good chance that they're from a Chinese company whose name I never even heard of!)
                              (if you mean the switch on the lid!)
                              ASRock B550 PG Velocita
                              Ryzen 9 "Vermeer" 5900X
                              Arc A770 16 GB
                              eVGA Supernova G3 750W
                              Alienware AW3423DWF OLED
                              • PeteS in CA
                                • Aug 2005
                                • 3583
                                • USA, Unsure of Planet
                                I sure do not love the soldering on the power cord wires (IIRC, White = Neutral is US usage).
                                PeteS in CA
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8709
                                  Yeah pretty sure it's a homebrew versus a low quantity(and quality?) build, the solder job is indeed crappy, and if you only have blue and black 30AWG Kynar®, blue and black 30AWG Kynar gets used.
                                    • 31284
                                    big clive has been playing with the old hotdog electrocutors recently!
                                      The company claimed that it is ETL approved, I doubt it very much.
                                      https://www.amazon.com/dp/B000HK20BA...l_huc_continue
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8709
                                        Interesting, it's only 280W, so less than a toaster.
                                        I don't know, I suppose the US now having GFCIs pretty much standardized, that's probably why the appliance manufacturers can leave it ungrounded. *shrug*
                                        But this homebrew actually has a grounded 3-prong plug surprisingly enough, unlike my old tube tester... it has a 2-prong plug and a metal chassis...
                                        • wnlewis
                                          New wire for my RDE3340 Whirlpool electric range
                                          by wnlewis
                                          OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                          This is a Whirlpool RDE3340 electric range.
                                          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                          Where may I find parts...
                                          01-08-2025, 11:21 PM
                                        • emeskay
                                          Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                                          by emeskay
                                          We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                                          08-06-2024, 07:13 AM
                                        • technicalspecialist
                                          Vintage fan repair, copper wire question
                                          by technicalspecialist
                                          I currently have a customer's vintage fan on the work bench to repair.
                                          It uses an induction motor with 4 poles. One of the poles is open.
                                          I couldn't find the break so i cut off the original wire.
                                          I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                                          I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                                          The enamelled copper...
                                          03-16-2023, 12:54 PM
                                          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                          by sam_sam_sam
                                          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                          12-16-2023, 08:39 PM
                                        • kalemaroni
                                          Dell DC Brown wire
                                          by kalemaroni
                                          There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
                                          08-26-2025, 10:10 AM
