Replacing a choke coil
  • appiah4
    • Dec 2018
    • 8
    • Turkey
    I acquired a Socket 7 motherboard not long ago.. Aside from a few missing capacitors, it also has a broken coil choke. It seems to me a ferrite bead of 12mm external 8mm diameter with a 12 loop copper coil around it..
    I don't know how to determine (or guesstimate) the rating of this part, where to source it, and whether there are any suitable modern replacement component types for it as this type of component seems to be rather rare in supply and totally not used on newer parts (so something else must be used in its place?)
    Can someone advise me on what to replace this with?
    • 30951
    Re: Replacing a choke coil
    if you get the datasheet for the driver chip, it may have an example schematic with the values of the inductors.
    • appiah4
      • Dec 2018
      • 8
      • Turkey
      The chip in question is a TL494CN; I believe this is the correct datasheet to check? https://cdn.badcaps-static.com/pdfs/...88cd5e8891.pdf
      I'm not exactly electronics literate so if you could point out where I should look, it would be extremely useful..
      • drussell
        • Nov 2014
        • 144
        The 494 is a generic PWM controller chip. It can be used for all sorts of different applications with completely different topologies. The datasheet isn't going to tell you anything useful about the implementation on your board.
        What model of motherboard is it?
        I probably have one here I can take a look at and figure it out for you, though the actual value isn't likely to be super critical as long as it is high enough to filter appropriately.
        • appiah4
          • Dec 2018
          • 8
          • Turkey
          It is a PCChşps/Elpina M534 VXPro+
          Can you tell me the cap ratings of EC12 and EC17 as well if possible?
            The Inductor looks to be used for Buck converter (see how the Inductor and the diode are connected to verify), not for filtering so you need to get the correct one otherwise the output Voltage will not be correct.
            Look at the application circuit of that 494 spec sheet.
            Page 17 has the inductance calculator but you need to know many requirement info to come up with the correct inductor.
            BTW, what is the color of that TOROID Ferrite/or Iron powder core? Light Blue? Gray?
            • PeteS in CA
              • Aug 2005
              • 3578
              • USA, Unsure of Planet
              I think that toroid is a Micrometals powdered iron core, this part number.
              PeteS in CA
              • appiah4
                • Dec 2018
                • 8
                • Turkey
                I looked at the inductor application and saw there was no definite value as well.. The tiroid is light blue on one side and on the interior suface, pale green on the other side and the exterior surface if that makes sense.
                I guess *assuming* that I can source this I can reuse the wire to wrap 12 coils around it and it should work?
                The closest affordable part I have found is this: http://tr.aliexpress.com/item/TR10-8...777238179.html but it has 14 coils instead of 12.. I guess I could unwind two of the coils and use it as such? Sorry if these are stupid questions, I am really in way over my head here..
                This is probably going to be too much work for a generic PCChips motherboard..
                • PeteS in CA
                  • Aug 2005
                  • 3578
                  You could reuse the wire, if the varnish isn't scraped and the wire shorting to anything.
                  PeteS in CA
                  • appiah4
                    • Dec 2018
                    • 8
                    • Turkey
                    What are the chances of frying a cpu if I blindly replace with the choke from aliexpress I linked above? The relevant controller chip is on the CPU VRM after all.. But the part seems fairly identical, just 14 coils instead of 12 so likely 10-15% higher inductance?
                    • llonen
                      • Sep 2014
                      • 495
                      • hampshire
                      That rather depends upon whether as previously mentioned this is being used as part of a buck converter, draw out the circuit around the inductor and discrete components around it. And or put up some high resolution pictures from both sides of the board in that area.
                      • appiah4
                        • Dec 2018
                        • 8
                        • Turkey
                        Happy to oblige with pictures..
                          master hoarder
                          • May 2008
                          • 12168
                          • Bulgaria
                          This IS a buck converter and it is for the CPU.
                          A lot of old motherboards used a 494 PWM controller for the CPU VRM / buck converter - mostly lower-tier boards like ECS and PCchips. They did that even as late as the Pentium 4 (Northwood) era. In any case, if you see a TL494/DBL494 on a PC motherboard, it is VERY LIKELY for the CPU VRM (and very likely, you have an ECS motherboard, as they -loved- using those TL494 designs for some reason.)
                          Well, don't blindly replace it.
                          Make sure the replacement inductor has at least the same core size as yours and the wire thickness is the same. If those match and the core type matches (powder iron or ferrite), then the extra 2 turns (and thus slightly higher inductance) shouldn't be that much of an issue.
                          That said, instead of unwinding this replacement inductor and winding it back with the old wire, you could instead just unwind 2 out of the 14 turns to make it 12 turns again.... Though again, the slightly higher inductance shouldn't hurt that much. After all, this is a TL494 buck regulator running at a fairly low switching frequency (probably 20-40 KHz, if even that much).
                          • appiah4
                            • Dec 2018
                            • 8
                            • Turkey
                            Well, the old one seems to be around 7.5mm internal and 12.5mm external diameter and roughly 5mm width, with an iron powder core. The one on aliexpress is a T50-52, so checking up on that standard it should be 7.7mm, 12.7mm and 4.8mm respectively, pretty much a good equivalent I would think.. I will just buy it and solder it on. What can go wrong I doubt I would damage a test CPU (and I do have more than enough 166MMXs to go around).. Fingers crossed, order placed, I will let you know in a month's time.
                              master hoarder
                              • May 2008
                              • 12168
                              • Bulgaria
                              I think it will be fine too. 8.3 uH sounds about right anyways. Modern motherboards with their high frequency switching VRMs typically use 1 uH inductors or lower (that is, 1R0 or lower, like R47, R22, etc.) And in the mid-2000, I think most CPU VRM circuits used slightly bigger inductor values typically around 1 to 4.7 uH. So again, I think 8.3 uH is about right for this board with its slow switching TL494.
                              Besides, if you have too high of an inductance, the worst that can happen is low voltage to the CPU. But if the inductance is too low (way lower than the circuit expects), you can damage the CPU. So in your case, I think you're safe, as 8.3 uH is a fairly high inductance for a buck regulator.
                              Anyways, keep us posted how it goes.
                              • FZG
                                Sony BVM1410PM (CRT Monitor) - Coil Choke Replacement
                                by FZG
                                Hello there, helpful forum people!
                                I am in the process of fixing an old (ca. 1990) Sony BVM1410PM CRT monitor and need some help. The PSU board of this monitor had failed and I had to replace quite a few capacitors and other parts but now - with my limited knowledge - I ran into a wall.
                                On the board there is a coil choke that has failed (tested with inductance meter) and I don´t know what to replace it with. According to the device´s service manual the part in question is a "Coil, Choke 525 uH (Sony P/N: 1-459-643-11)".
                                The original part...
                                05-10-2023, 11:54 AM
                              • bauto601
                                KDM 480W PSU upgrade succes! (opinions?)
                                by bauto601
                                Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                A "nice" YoungYear unit? - Badcaps
                                The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                12-26-2023, 03:05 PM
                              • chth96
                                How can I test coil whether it is really broken or not?
                                by chth96
                                I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
                                I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
                                I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
                                I want to replace this round black fuse and unidentified coil if it got broken.
                                02-20-2024, 01:07 AM
                              • waterchill
                                What part is this coil from a MacBook A2681 ?
                                by waterchill
                                Hi everyone
                                I'm struggling to point out what part is this? It is a coil, but the parameters say: 10OHM - 50% - 1A - 0.05Ohm
                                So it is a coil with 0201 dimensions, 1A max current, 0.05ohm resistance but what is 10ohm? For a coil we need specs like 1uH or so.
                                IAny ideas? It is from a MacBook A2681
                                Thank you...
                                08-08-2024, 01:46 AM
                                A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                                by momaka
                                More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                                And a shot of the label:...
                                01-26-2022, 03:26 AM
