There is something seriously wrong with my house.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: There is something seriously wrong with my house.
    I lived in a place built in the 1930's for a while.
    Had the knob and tube crap going on.
    It was driving me nuts trying to figure out why a different fuse blew every time the coffee pot and microwave were used at the same time.
    Come to find some moron wannabe electrician (way before I moved there, probably in the '50's or 60's) did some rewiring, added a sub-panel with screw-in fuses, and managed to put the whole house on ONE circuit with four 30 amp fuses in SERIES.
    Mann-Made Global Warming.
    - Dr Seuss
    • Bookworm
      • Nov 2007
      • 123
      I _think_ you can still use aluminum - but it's only for exterior ground, because of the thermal expansion/contraction issue.
      Mainly, you use aluminum there because the oxidated cable is less resistant to current than oxidized copper - But you have to screw it TIGHT.
      The house I'm in now had similar wiring problems. Idiot electrician replaced all the two prong, ungrounded, outlets with three prong grounded outlets - claimed that he couldn't GET the two prong outlets. (I found three boxes in two minutes at the local Home Depot).
      Anyway - the bulk of the wiring in the house has been replaced - I did the sheetrock repairs myself
      • pentium
        • Mar 2006
        • 2778
        Yeah, you need to secure aluminum wire properly or it likes to fail at the ends.
        Find Nedry!
        Check the Vending machines!!
        <----Computer says I need more beer.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          In the states it hasn't been legal to install aluminum wire (in new construction) for over 20 years but there is no requirement to remove it if it's there.
          That makes for problems in remodeling and repair because connecting the new (legal) copper wire to existing aluminum wire is sometimes unavoidable. (Short of tearing the house down.)
          They have come up with this chemical you put into regular twist-on connectors that prevents the copper to aluminum reaction/connection problems.
          I wasn't too sure about that idea at first but it's UL listed so happy days.
          - Dr Seuss
          • zandrax
            Hit and miss
            • Dec 2007
            • 1157
            • Italy
            I think the real concern is metal corrosion due to coupling metals with different electrochemical potential: aluminuim (used in cables) acts as an anode and copper (used in outlets and most connections) as a catode, corroding the former.
            Perhaps this special paint should conduct electricity while blocking any contact between metals.
            Zandrax
            Have an happy life.
            • Bookworm
              • Nov 2007
              • 123
              #26
              PCBonez - what makes you announce that with finality? As far as I know, we have no nationwide electrical requirements. National Electric Code isn't a _National_ electric code. that's just the name of an organization that charges for access to their recommendations.
              I _know_ you aren't supposed to use aluminum _wire_ in houses down here, but even new construction often has aluminum grounding wire. (not all. I think it's just easier for people to take the 'easy to corrode' copper route)
              Zandrax - it might be a connector filled with an anerobic gel, which will seal off any oxygen. Most corrosion requires chlorine or oxygen in order to advance. (I've been cleaning silver with potash and aluminum foil, so I'm aware of some of the corrosion issues )
              • Krankshaft
                • Jan 2007
                • 2328
                Bookworm:
                They replaced 2 with 3 prong?
                No way my house has that too. All three prongs even on the old BX outlets.
                It was built in the early 50s and has BX wire man that stuff is horrible the insulation will crack if you even look at it wrong.
                I've replaced more of it then I'd like to admit. There is no way I'd ever replace it all too much wall cutting.
                It seems like I'm ok in my situation though since the outlets are grounded to the box and the BX sheathing is grounded to the outlet box which grounds out at the service panel.
                Not sure if the electrical code thinks thats ok though. But I didn't do it.
                I hate wall patching I just ruptured an old galvanized drain pipe while using a manual hand snake in December .
                I had to tear out the wall and replace from the sink to the threaded cast iron fitting with PVC. A huge chisel and a 3 pound hammer to cave the old galvanized pipe in onto itself to get it out of the threaded cast iron hub threads that haven't been moved in 50+ years aren't going to budge without some heavy coaxing.
                Patching was a mess its easy if you have sheetrock walls I have sheetrock with plaster on top . So I had to reuse the original pieces and don't get me started on sanding .
                • Bookworm
                  • Nov 2007
                  • 123
                  #28
                  Yes - originally 2 prong non-polarized, replaced with 3 prong polarized.
                  Once I did some ground testing, and got some WEIRD results, the landlord had them come out and replace the wiring itself - now I have good grounds
                  • RJARRRPCGP
                    • Jul 2004
                    • 6301
                    If your radio acts that strange (the power blips often) and you continue to use it without rewiring, there's a good chance of a house fire!
                    I saw news on a newspaper about a major house fire recently, because of what likely is a wide electrical system problem. It said an elderly woman was experiencing a light switch acting strange then sometime after, heard something and went downstairs and to her, appeared an oven was on fire, thus called to report an oven fire, but after the fire department came, someone of the fire department said that the fire is coming out of the basement and the panel was on fire. Also, the transformer on the power pole was on fire, too!
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • pentium
                      • Mar 2006
                      • 2778
                      It seems that the radio issues are isolated to the area I live.
                      For some reason, radio waves simply can not enter the valley even though the surrounding hills are the same no matter where you are in town.
                      We have a cell tower less than three kilometers from us and from my room I can't get a signal unless I lay it flat on my table.
                      Find Nedry!
                      • hardwareguy
                        • Jun 2006
                        • 405
                        There are a couple ways to deal with aluminum wiring..... remove the aluminum or use hydraulically crimped on pigtails (The AMP Copalum system).
                        AL/CU devices are a joke but better than stuff rated for copper only.
                        Be CERTAIN to follow instructions EXACTLY..... connections must be very secure and special preparations to the conductors, including sanding the oxide layer off and adding antioxidant compound should be done carefully.
                        The general way to make a somewhat reliable connection between Al and Cu wire (or Al and Al) when specialized connectors are not available is to do the following:
                        Strip the wires normally.
                        Sand the oxide off the Al wire
                        Coat the Al wire in antioxidant compound. (Penetrox A is recommended)
                        Tightly twist the wires together in such a way that they will be further tightened when the wire nut is applied.
                        Fill the inside of the wire nut up to the end of the metal threads inside with antioxidant.
                        For more info visit http://www.inspect-ny.com/aluminum/aluminum.htm
                        • Wizard
                          • Mar 2008
                          • 2296
                          #32
                          Yes, don't scoff. House fires is what you don't want.
                          My minimum: PULL ALL aluminum wirings out apd put copper in.
                          Cheers, Wizard
                          • arneson
                            • Sep 2005
                            • 1267
                            #33
                            They started digging up every street on this poor little island here.
                            Putting in sewers.
                            Company came down this main street to mark underground utilities.
                            Then the crew came in to start the dig and pipe laying.
                            This is a street with about 300 large mansions, most with yachts in the backyard.
                            The first shovel hit the dirt
                            and imediately crossed the power line phases to the entire neighborhood.
                            It was mismarked.
                            The result was 240 into every house on the 120 lines.
                            Not only did everything in every house blow up, but each of the yachts plugged into shorepower were also blown.
                            People were actually running out the front door carrying smoldering appliances.
                            It was better than a lightning strike.
                            Jim
                            • Wizard
                              • Mar 2008
                              • 2296
                              #34
                              LOL poor them, what the reason to keep yachts landbound plugged in?
                              One note, don't continue using aluminum wiring even have used "appoved" wirenut to copper stubs and aluminum wiring. Must have this done with AMP copalum system and I have read that you cannot simply get them, you have to call trained tech to do this as AMP will not allow anyone to use it unless AMP-trained techs to use it.
                              One apartment we lived in was alum wiring and I had to fix a bad connection because the outlet was warm because of this.
                              The easiest way is simply pull out the alum wiring and put copper wiring in instead.
                              I can't stress this enough, if you don't know the house well, get wirings CHECKED OUT. I counted about 3-4 houses burned in 40KM drive and I have seen about 4-5 fires caused by electrical faults in nature all right here in our city within and around it.
                              And in late 1980's there was 2 BIG fires that razed historic 3 floor buildings in the downtown, both were electrical issues. They were very unique in nature. Sigh.
                              Cheers, Wizard
                              • willawake
                                Super Modulator
                                • Nov 2003
                                • 8457
                                • Greece
                                #35
                                yachts at the marina are plugged into shorepower to keep the batteries charged (at least). otherwise if people are on board can run everything of shore power. running generators pisses people in next boats off.
                                • arneson
                                  • Sep 2005
                                  • 1267
                                  #36
                                  True Will.
                                  The gen set is about the only thing that didn't blow.
                                  Shortly after seeing this happen I came home to find my front yard all multicolor spraypainted and twenty colored flags posted.
                                  Yes the power in my neighborhood is underground, and checking the main panel, it's copper except for the main ground, in a thirty year old house.
                                  I keep large APC UPS's on almost everything in every room.
                                  When the power goes out, half my stuff stays on.
                                  Jim
                                  • willawake
                                    Super Modulator
                                    • Nov 2003
                                    • 8457
                                    • Greece
                                    #37
                                    there should have been protection at the shore power box. they can sue the marina (hmmmm.....is that possible or is berth space availability so limited nobody dares)
                                    anyway insurance should cover
                                    large yachts have all sorts of stuff like frequency converter
                                    maybe there is small units for the small yachts which usually have zilch.
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      #38
                                      got a weird one to troubleshoot.
                                      a steel plant in town has a crane that has killed 4 vfd's on the same motor.
                                      they are always killed the same way.
                                      shorted rectifiers on r.
                                      i suspect a loose connection somewhere.
                                      these are not cheap to fix as everything is in a fuji igbt/rectifier brick.
                                      • arneson
                                        • Sep 2005
                                        • 1267
                                        #39
                                        Design deficiency?
                                        Jim
                                        • shelby5041
                                          clock radio / radio lifespan?
                                          by shelby5041
                                          hi
                                          ive got a modern digital clock radio approx 15yrs old
                                          my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                          since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                          the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                          it uses very little power just a few watts i would imagine that may have something...
                                          09-14-2024, 03:30 AM
                                        • SolomonMan
                                          Antenna...
                                          by SolomonMan
                                          All,
                                          I recently moved to a very rural area. I am about 25 miles from the nearest urban settings (2 separate College Towns). 45-50 miles from a Urban City (Toledo Ohio)
                                          There was a Omni-directional Wineguard Antenna (amplified) that was mounted on the house originally. Came with the house. Center of the top of Roof a few feet from Chimney on a 4 foot pole. The 75 ohm line went from the roof down 2-3 stories to the small Wineguard amplifier and then it split to the living room and master bedroom. Currently a Very simple setup.
                                          Since we moved in, 8 years ago,...
                                          10-05-2023, 02:37 PM
                                        • praveenramavath
                                          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                          by praveenramavath
                                          Hello All,
                                          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                          https://www.hifivision.com/threads/m...-screen.98243/
                                          Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                          04-26-2025, 09:08 AM
                                          HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                          09-12-2024, 02:00 PM
                                        • Omron
                                          Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
                                          by Omron
                                          Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
                                          My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
                                          - Tried to unplug radio and plug it back in into power,
                                          - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
                                          - Tried to hold 3,6 while turning it back on and then pressing 1,2...
                                          05-23-2024, 01:27 PM
