Help
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Help
    Having problem with a Matti automatic car battery charger. (Matti automatic 12V, 7A)
    The charger is not working. Here is the PCB and schematic view for the device.
    Already checked the BT152, BC557 and TL431 and they are fine. D1,2,3 are fine too. The first VDR checked ok. As for the R11 which according to schematics is also a varistor/ thermistor (why its named R11 is a bit confusing) I'm getting very low resistance, around 57 ohms.
    I attached two pic for R11 and need help identifying its properties, values and whether is really a varistor or a resistor. As you see it has two colors, brown at bottom and orange at top. There is also a small ( grayish / green ) dot as of the sec pic.
    Thanks a head for help and any further ideas of further troubleshooting would be appreciated.
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Re: Help
    With some further testing R11 seems to be a NTC thermistor. But is the value of 66ohms right????.
    I can see its responding to temp change but drop of resistance as temp rise (getting closer to bench light bulb).
    Ant help appreciated.
      • 31011
      Re: Help
      what exactly is wrong?
      from that diagram, if you push the button in, you should get 12v at the output.
      if you dont, i'd start by testing your transformer.
      • tibd
        • Oct 2014
        • 189
        • Sweden
        Re: Help
        Well the only button is for the manual/ automatic, the on/off button here is not present.
        I'm getting no reaction when bat attached for charging, no led lit. Usually the red lit first until its fully charged then green led lit.
        As for the transformer, it's providing 12 and 24 v at secondaries according to attached pic. I also get 12VAC at terminal according to pic but 0v at terminal tested against each other.
        What's wrong?
          • 31011
          Re: Help
          if the red button is missing, add one - then see if pressing it in make the output turn on.
          if not, your scr's are suspect.
          if it does then you need to look at the transistors.
          • tibd
            • Oct 2014
            • 189
            • Sweden
            Re: Help
            Transistor BC557c (PNP) both checked ok.
            Thyristor BT152 600r , how do you test it?
            TL431 is fine.
            As you see the original schematic isn't mine, I downloaded it from some finish site. I think the on off button (as of its drawn in red) wasn't there from the beginning, may be its a work around as the word by the button mean "force to download" ( google ). Will try using the auto/man button and see if it works. Thanks for support.
              • 31011
              Re: Help
              fastest way to test the scr's is to just short the colector and emiter on t2 to turn them on.
              • tibd
                • Oct 2014
                • 189
                • Sweden
                Re: Help
                as for the BT152,
                I shorted the gate with anode which turned on connection between Anode and Cathode, Is it so you mean. Here's a bit of the datasheet.
                  Re: Help
                  This charger will not put out any Voltage unless it hooked up to the a working that still have enough Voltage to start the circuit, it is made so that if the battery Voltage is too low (bad batteries) the charger will not try to charge the batteries.
                  It is also pulse charging circuit, not clean DC output.
                  The Voltage from the good battery is used for running the circuit (T, T2, IC, etc.) to to turn on the SCR.
                    • 31011
                    Re: Help
                    or you jump-start it with the (missing) button.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4951
                      • New Zealand
                      Re: Help
                      It's impossible to say if the resistance is correct without checking against another, known working unit or seeing the datasheet. But it's more likely for a thermistor to fail open circuit than drift in value.
                      The fact that it changes at all suggests it's probably OK, and you don't know what the characteristics of it are anyway, so even if it was faulty it's not like you could do anything about it...
                      -David VanHorn
                        • 31011
                        Re: Help
                        it has nothing to do with the missing output anyway, it will just change the current and phasing slightly.
                        • CapLeaker
                          Leaking Member
                          • 8146
                          Re: Help
                          Or the problem is something real simple and the wire inside the battery clamp broke off. That red jumpstart button in the diagram is not there inside the charger. It is something you can put in in order to test it. I've dug out "expensive" chargers out of the recycling that only this was the case. In any case, this charger won't do squat, unless you add that red marked button or a jumper wire like it is in the schematic, or you add a half decent battery that has more than 10.5V.
                          • tibd
                            • Oct 2014
                            • 189
                            • Sweden
                            Re: Help
                            Thanks everyone.
                            As simple as stated above the charger seems working with a bat that at least supply 11v. Turns out the battery I tested upon was almost dead.
                            The device working fine, no part was changed (p.s nothing was defective).
                            Thanks again for all help.
                              Re: Help
                              Thanks for feedback, sometime it is good to understand how the circuit works before trying to troubleshoot the problems that are not there to begin with.
                              • nmbb
                                Can not find Model/Value of Thermistor.
                                by nmbb
                                Machine: Autoclave.
                                Brand/Model: SANYO MLS-3780
                                Manual: (Sorry search option not working on this PDF)
                                Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
                                06-02-2022, 05:55 PM
                              • chth96
                                How can I identify varistor which have been blew up?
                                by chth96
                                I mistakely pluged 100v japanese retro game console to 220v outlet.
                                So It seems that glass fuse and varistor have been blew up.
                                I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                                Is there any way to identify varistor type in my sega saturn PSU?
                                Any reply would be appreciated.
                                EDIT:
                                It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                                11-26-2023, 08:52 AM
                              • Use2bavolvo
                                Magic chef oven - thermistor ref voltage issue
                                by Use2bavolvo
                                I am having an issue with my wall oven temperature control is ~180f out of spec. The thermistor is measuring correctly but I noticed the ref voltage appears to be off. With the thermistor wires attached it's reading ~3.4vdc with the thermistor disconnected it's around I9.8vdc. my understanding is the temp is read off the resistance from the thermistor which leads me to believe the issue is with the ref voltage.
                                Another observation is the temp setting and readout at lower temps is way off meaning the oven thinks room temp is 300f and bake relay doesn't engage unless temp setting...
                                01-19-2023, 01:32 AM
                              • Quantum IC
                                Sony KDL-40BX450 LCD. Thermistor gets too hot 10 seconds after turning on the TV
                                by Quantum IC
                                Hello every one,
                                This TV came to me with the problem that it was totally dead.
                                The problem was the two MOSFETs and a fuse resistor in the power supply.
                                The original MOSFETs were KF7N50F and I repalced them with SLF65R700S2.
                                The original fuse resistor was 0.1 Ohm 1/2W. I didn't find a similar fuse resistor and I replaced it with 0.1 Ohm 5W ceramic resistor.
                                When I plug the TV the ST-BY LED turns on, when I press the power button on the TV, the ST-BY LED turns off and the TV doesn't turn on until the second time I press the power button is when the TV turns on,...
                                01-14-2022, 12:06 AM
                              • fab13
                                Thermistor exploded in two when turning on ps4 fat
                                by fab13
                                Hi there,
                                I have a fat PS4 with the fuse (5a) of the power supply which blows with each power on and there was a loud snap in the power supply and again the same problem after replacing the fuse.
                                I did not find a short circuit
                                The component that broke in two is an SCK 084 thermistor (See photo)
                                and measured at 11 ohm
                                So far I haven't received a thermistor.
                                Do you think that if I replace the thermistor and the fuse it should go away, because I have the impression that there is a strong current demand as soon as you press...
                                11-05-2022, 06:29 PM
