At work this thing was functioning, but anytime it got bumped, even slightly, it would short out and cut power. Looks like a fire waiting to happen! I think this was because 2kW was pumped through this thing for short amounts of time, even against my recommendation. I guess that's what happens! It's over 20 years old.
Failed Power Strip
Re: Failed Power Strip
At work this thing was functioning, but anytime it got bumped, even slightly, it would short out and cut power. Looks like a fire waiting to happen! I think this was because 2kW was pumped through this thing for short amounts of time, even against my recommendation. I guess that's what happens! It's over 20 years old.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"Β‘Me encanta "Me Encanta o Enlistarlo con Hilary Farr!" -MΓ mismo
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
What would a breaker do?
With poor connections and loose jaws, nothing!
(Ok, ok. Once the plastic housing catches fire, the thermal-only breaker will trip.)
Time for a nice Wiremold plugstrip- $$$! Or, make one out of a square box, raised cover plate, and two duplex receps..."pokemon go... to hell!"
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!Comment
Yeah it's unfortunate for the race to the bottom. I still have a few power strips that actually have duplex receptacles in it - three to be exact. These are old old...
Unfortunately one of them I have an issue with. Though it's rated for 15 amps, I plugged in a 1500W heater into it once and the power strip actually started heating up! Not a good sign. I will need to figure out what inside is heating, wonder if it's a bad outlet, wires too small, or something else...Comment
I also have a strip with the three dulex receptacles. It's seen 25+ years of use and the rocker switch finally wore out. I haven't taken mine apart yet.
You're strip could also have some loosened connections at the duplex outlets. That would cause heat and seems fairly likely to me.Comment
When my grandmother was still living in the 1950's Nutley house and we'd stay over, my parents would sleep up in the finished attic.
My grandfather finished, wired, etc, that bedroom and attic. I don't remember when that was.
The old recepticals still were tight enough (back in 2008-09), but the plugs of space heaters and hair dryers would often heat up. Those same loads never had their plugs heat when plugged into much newer receps. I looked inside at the jaws of those old ones, and observed the typical brass/copper surface oxidation.
As those receps were only used when there was "company" upstairs, perhaps the lack of use allowed oxidation to build up, since they weren't having things plugged/unplugged very often.Last edited by kaboom; 09-10-2014, 12:23 PM."pokemon go... to hell!"
EOL it...
That Black line solid should have been wrapped and then soldered, it looks like poor connection of the wire to the buss.Never stop learning
Fortunately it's real easy and cheap to replace the outlets unlike the "race to the bottom" power strips. I just need to go to the local Home Depot or Lowes and grab new ones...
Then again these "race to the bottom" power strips are lighter and smaller than the triple duplex power strips I have... metal chassis and all... I'm sure some people will prefer these MiT/MiC power strips.
(Where's the MiI power strips? Aren't they coming soon?)Comment
Incidentally that recent "MiC" power strip that I took apart, they didn't even solder the black hot wire to the bus...
They SPOT WELDED it...
I don't know if this is a sign of quality or cost reduction, but it looks like a good weld that will hold up...Comment
The black wire solder joint on the buss appears to me to be where the heat started and travelled up the wire buring off the insulation, probably due to a bad connection at the buss as you noted and possibly a bad solder joint to boot. None of those solder joints look very good to me.Comment
FPE = Fire Plus Electric.
Somewhere in my house I have and old mid-80's Radio Shack 6-outlet power strip. You could use that thing as a hammer! 2-piece heavy-gauge extruded aluminum housing with heavy-duty square-face outlets. Solidly soldered with good-old-fashioned 60/40 leaded solder. NO bad soldering and it was made in the US!!!Stupidity should be a crime, especially for drivers. I have NO patience for them.Comment
Wow, that's terrible! Well....at least they used copper?
The average persons' power supply knowledge "logic" applies to surge protectors as well: "I can buy this one for $5, why on earth would I pay $20 for that one? They do the same thing!"
And meanwhile, the guys over at "SHENZHEN XINBING GONGYUAN LONG YING FENG CHUNGHAU ELECTRONICS ENTERPRISE COMPANY" are laughingLast edited by Pentium4; 09-10-2014, 10:01 PM.Comment
Laser printer, two laptop supplies, some phone and "accessory" supplies, and a space heater. Water was thrown on the arcing (flaming?) heater plug when it was "discovered." Talk about an elephant in the room.
Breaker wouldn't have tripped on the poor connection.
Loose jaws/connections in the strip & plug as well as the recep it was plugged in to. Both jaws of recep bad, but "noodle" (ok, grounded as it's single-phase) was worse.
[sarcasm]"I wasn't warning you for several months- I was being overly enthusiastic and talking for the hell of it."[/sarcasm]
FWIW, they don't do the same thing- junkers catch fire while the goods ones do not.
EOL it...
i should go dig up the pictures that skystormfucks put up...
goddam, what did he take these with a shoe?Last edited by goontron; 09-10-2014, 10:58 PM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
by PantherDaveHi all!
I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. π
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 02:15 PM
- Loading...
