Failed Power Strip
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Failed Power Strip
    At work this thing was functioning, but anytime it got bumped, even slightly, it would short out and cut power. Looks like a fire waiting to happen! I think this was because 2kW was pumped through this thing for short amounts of time, even against my recommendation. I guess that's what happens! It's over 20 years old.
  • SteveNielsen
    Retired Tech
    • 2327
    Re: Failed Power Strip
    I guess that circuit breaker was pretty useless.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      An old skool ROC-made power strip. Cool.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Is it really "old skool"... I think they still make them like that :o
        I opened up a recent ROC power strip and it looks just like that inside...
        Is that a MOV on the far end? Now that's really asking for it...
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          What would a breaker do?
          With poor connections and loose jaws, nothing!
          (Ok, ok. Once the plastic housing catches fire, the thermal-only breaker will trip.)
          Time for a nice Wiremold plugstrip- $$$! Or, make one out of a square box, raised cover plate, and two duplex receps...
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Yeah it's unfortunate for the race to the bottom. I still have a few power strips that actually have duplex receptacles in it - three to be exact. These are old old...
            Unfortunately one of them I have an issue with. Though it's rated for 15 amps, I plugged in a 1500W heater into it once and the power strip actually started heating up! Not a good sign. I will need to figure out what inside is heating, wonder if it's a bad outlet, wires too small, or something else...
            • SteveNielsen
              Retired Tech
              • 2327
              I also have a strip with the three dulex receptacles. It's seen 25+ years of use and the rocker switch finally wore out. I haven't taken mine apart yet.
              You're strip could also have some loosened connections at the duplex outlets. That would cause heat and seems fairly likely to me.
              • kaboom
                "Oh, Grouchy!"
                • Jan 2011
                • 2507
                If it's that old, it could even be oxidation on the contacts/jaws, in addition to loose contacts. IOW, they could heat up under load even if they "appear" to be tight. But after 25 years, unless it was a really good one, I'd think they'd be rather loose...
                When my grandmother was still living in the 1950's Nutley house and we'd stay over, my parents would sleep up in the finished attic.
                My grandfather finished, wired, etc, that bedroom and attic. I don't remember when that was.
                The old recepticals still were tight enough (back in 2008-09), but the plugs of space heaters and hair dryers would often heat up. Those same loads never had their plugs heat when plugged into much newer receps. I looked inside at the jaws of those old ones, and observed the typical brass/copper surface oxidation.
                As those receps were only used when there was "company" upstairs, perhaps the lack of use allowed oxidation to build up, since they weren't having things plugged/unplugged very often.
                EOL it...
                  That Black line solid should have been wrapped and then soldered, it looks like poor connection of the wire to the buss.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Fortunately it's real easy and cheap to replace the outlets unlike the "race to the bottom" power strips. I just need to go to the local Home Depot or Lowes and grab new ones...
                    Then again these "race to the bottom" power strips are lighter and smaller than the triple duplex power strips I have... metal chassis and all... I'm sure some people will prefer these MiT/MiC power strips.
                    (Where's the MiI power strips? Aren't they coming soon?)
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Incidentally that recent "MiC" power strip that I took apart, they didn't even solder the black hot wire to the bus...
                      They SPOT WELDED it...
                      I don't know if this is a sign of quality or cost reduction, but it looks like a good weld that will hold up...
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        The black wire solder joint on the buss appears to me to be where the heat started and travelled up the wire buring off the insulation, probably due to a bad connection at the buss as you noted and possibly a bad solder joint to boot. None of those solder joints look very good to me.
                        • kaboom
                          "Oh, Grouchy!"
                          • Jan 2011
                          • 2507
                          The only thing missing from that strip is this label:
                          EOL it...
                          • delaware74b
                            • Apr 2009
                            • 628
                            FPE = Fire Plus Electric.
                            Somewhere in my house I have and old mid-80's Radio Shack 6-outlet power strip. You could use that thing as a hammer! 2-piece heavy-gauge extruded aluminum housing with heavy-duty square-face outlets. Solidly soldered with good-old-fashioned 60/40 leaded solder. NO bad soldering and it was made in the US!!!
                            Stupidity should be a crime, especially for drivers. I have NO patience for them.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Made in China in all its glory?
                              This was made within the last two years I think. Is it Hazard Fraught?
                              It doesn't look way too bad except for GND IMHO...
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                let that mov eat a few spikes and you will have a glowing event.
                                • Pentium4
                                  CapXon Be Gone
                                  • Sep 2011
                                  • 3741
                                  Wow, that's terrible! Well....at least they used copper?
                                  The average persons' power supply knowledge "logic" applies to surge protectors as well: "I can buy this one for $5, why on earth would I pay $20 for that one? They do the same thing!"
                                  And meanwhile, the guys over at "SHENZHEN XINBING GONGYUAN LONG YING FENG CHUNGHAU ELECTRONICS ENTERPRISE COMPANY" are laughing
                                  • kaboom
                                    "Oh, Grouchy!"
                                    • Jan 2011
                                    • 2507
                                    ... Which can be summarized by the following ....
                                    Laser printer, two laptop supplies, some phone and "accessory" supplies, and a space heater. Water was thrown on the arcing (flaming?) heater plug when it was "discovered." Talk about an elephant in the room.
                                    Breaker wouldn't have tripped on the poor connection.
                                    Loose jaws/connections in the strip & plug as well as the recep it was plugged in to. Both jaws of recep bad, but "noodle" (ok, grounded as it's single-phase) was worse.
                                    [sarcasm]"I wasn't warning you for several months- I was being overly enthusiastic and talking for the hell of it."[/sarcasm]
                                    FWIW, they don't do the same thing- junkers catch fire while the goods ones do not.
                                    EOL it...
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      Here's the old 2x3 power strip. Much more expensive to make...
                                      Unfortunately I don't see a country of origin on it.
                                      And yes it's overheating somewhere with a 1500W resistive load.
                                      • goontron
                                        5000!
                                        • Dec 2011
                                        • 4108
                                        • US
                                        i should go dig up the pictures that skystormfucks put up...
                                        goddam, what did he take these with a shoe?
                                        Follow the white rabbit.
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
                                          HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:15 PM
