That's exactly what i was thinking ....
Identifying a CPU killer (ahead of time) help
Re: Identifying a CPU killer (ahead of time) help
The top 3 caps plus 2 at the bottom look like they are bulging ...Leave a comment:
That board doesn't even have synchronous rectification!I usually power the board up without any proc. The i grab a voltmeter and measur either on the backside on the big caps if any Vcore like voltage is there. Or i put on probe to a ground point (e.g. a circle around a screw ) and put the other probe to the legs of those rectangular transistors or diodes. Usually on of those pins is on 5v or 12v, one is on 10v and one is on Vcore. Se atachement for an example. The layout of a Vcore circuit can differ, but they are always the same basic shematic. There are usually on every board an inputinductor, the input caps and hte o/p section. It is not hard to fifure it out.
PS: mesuring the o/p for short with 5v or 12v line to ground can be misleading. On any of my recapped boards, i have always measured a short with my ohmmeter (may be due to the small supply current of the DVM and the high capcitance of the caps). But all of them are working fine.
ECS...Leave a comment:
There are also special cards you put in the CPU socket with LED's on them that will show if it is working or not, like this one for example...
http://cgi.ebay.com/940-CPU-Socket-p...item3364f38245
You need a different one for every type of socket of course...Leave a comment:
This is exactly what i want.
Thank you guys.Leave a comment:
If you have seen once, you know them all
VRM and orange "Blob" are always the indicators.. lolLeave a comment:
Yeah, the VRM layout looks similar to my K7SEM (M810*) which once ate up a nice Thoroughbred B due to bad caps. If you've lost 8 CPUs this year, check the PSUs first for bad caps.Leave a comment:
Haha MD, me too. Heatsink's a dead giveaway.
Nice pic, anyway, Gonzo.
Edit: 250? Dang.Leave a comment:
Knew it was an ECS without even zooming in on the picture.. lolLeave a comment:
Wow thats awesome,
Thank gonzo0815 your pic is exactly what I needed.Leave a comment:
PS: mesuring the o/p for short with 5v or 12v line to ground can be misleading. On any of my recapped boards, i have always measured a short with my ohmmeter (may be due to the small supply current of the DVM and the high capcitance of the caps). But all of them are working fine.Attached Filesif you find these attachements useful please consider making a small donation to the site
check vcore by reading across one of the group of large caps close to the cpu.
vdimm across the lytics nearest the dimms.Leave a comment:
Great,
Now I need to know exactly how this is done. My background is computer hardware and IT not electronics. I suppose I'm coming at the field of mainboard repair from a disadvantage.Leave a comment:
When testing a board in unknown state, I do this:
1. Check (by using ohm meter) that there is no short between 12V, 5V, 3.3V and GND
2. If all caps are present and none of them is bulged, power it on without anything installed and check DIMM and CPU voltagesLeave a comment:
Hi guys,
Can anyone tell me how to know if a board will be a CPU killer before I pop in a CPU. To this point I've just chalked it up to cost of business and I use the cheapest athlon socket A chip I can find. I've probably fried about 8 in the last year and I would love to stop frying them.
Can anyone help?Tags: None
by titomno2Hi guys,
I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
Then the screen won't work for a long period of time.
If I wait 1 or 2 hours it work again most of the time.
When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated... -
by flat-eartherI have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
I have opened the camera and I think there is enough room to add something inside to accomplish this:
The camera is powered by a 3.7V nominal single cell lithium ion battery.
So I need to connect another battery in... -
by OscarAVHello,
I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
I have made a quick search for my laptop but I have not seen anything similar.
I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor... -
by BigOofI have a pair of Pioneer RM-07 monitors that I bought a while ago. When I was testing them I noticed that one speaker would cut out and I thought it was just a bad cable connection. At the price they were being sold for I was willing to take a risk on them. However, 6 months later and the one monitor still has the same issue. Most of the time it works, but there are times that the power LED is on but I get absolutely no sound. I can hear the relay clicking on/off sometimes and then it will/won't work depending on what it feels like. I've tried XLR and RCA inputs with the same issue. There's no...
by DynaxSCHi Folks
I'm looking for a extreme high current short killer solution for a reasonable cost.
I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
After taking off the socket, the shorts dissappear again.
The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...10-15-2024, 10:13 AM - Loading...
