Extreme High Current & Low Voltage Short Killer ??
  • DynaxSC
    • Apr 2021
    • 540
    • Poland
    Hi Folks
    I'm looking for a extreme high current short killer solution for a reasonable cost.
    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
    After taking off the socket, the shorts dissappear again.
    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a sharpened screwdriver.
    The exchange of the socket, except of the two shorts, is OK, what I tested with a memory, DMI and PCIe test cards.
    I have already come to terms with the loss of this motherboard, but I would like to discover where the short circuit occurs.
    I tried to discover the location of the short using a chinese short killer with 30A max. current i parallel with two swithing power supplys, each 10A current, so the joined current was 50A, but completely nothing happened 😂, not even some temperature rise anywhere.
    So I'm looking for some tool or way how to generate a much higher current but with a low voltage (max 6.3V), which could burn through the short.
    Starting the board does not help, as the OCP gets activated, and board swithes on, but without both voltages (OCP).
    Looked on Aliexpress, but the strongest power supply with a resonable price I found was 70A, which will most probably still be too less, as motherboard VCORE PWM's are designd to withstand much higher amperage, like 250A I've seen on some schematics (max. PWM throughoutput).
    I'm thinking on a few solutions:
    1. Build a capacitor pack with a capacity of 200000uF (eg. 50 x 4700uF caps in parallel so internal resistance will be very low) or more which I could load with the short killer I have, discharging it could temporarilly generate very high current
    2. Building some dedicated regulated swithed power supply with voltage 0-5V and amperage 200-300 A - but I would need a good schematics for it
    3. Misusing a PC PSU 12V line, but altering the PSU so that the generated voltage is low (must be below 6,3 V, otherwise the MLCC and electrolytinc capacitor on the board will be demaged)
    4. Misusing another motherboard's CPU VRM with a very high amperage, and altering it so, that the volatge/ampearge could be regulated manually from 0 to a few Volts (some adaptation would have to be done)
    5. I'm also evaluating to make a X-ray examination of the board somewhere, just made an inquiry in my city, but I'm afraid this will be costly.
    If you have any good ideas how to continue with a solution for the issue, or if you know a specific device, or schematic or DIY kit for selfassembling for such a short killer (0-5V, 200-300A), I'd appreciate that very much.
    Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
    I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
    I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
    I tested the battery cells there are installed right now and they are testing good with no issues that I...
    02-04-2025, 08:08 PM
  • duwane
    MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
    by duwane
    Hi All.
    I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
    Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
    After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
    Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
    10-17-2023, 07:48 PM
  • kevin_allein
    CKV Short Killer
    by kevin_allein
    Hi, recently I found a lot of videos on YouTube regarding CKV Short Killer. All of those Videos seem to be from Asia (e.g. in Hindi). I could not find a single English Video. Translation on YouTube on those videos does not work well, so it is hard to understand details.
    Basically it seems to address the frequent problems of LCD panels, when CKV and CKVB lines have some short and the only fix is to cut those lines or use tape on the ribbon cable to the secondary scalar board of the panel.
    Does anyone have any experience with that ?
    02-07-2025, 07:03 AM
  • Boardview and Schematic Bot
    Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
    The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
    The bq24745 features dynamic power management...
    10-23-2024, 02:50 AM
  • feliks912
    ThinkPad T490 20N2000CSC NM-B901 no signs of life - short on 5V SMPS, ThinkEngine-3 hot - *speculations*
    by feliks912
    Attached schematic 🙂.
    Laptop gives no signs of life. No fan and no CPU heat.
    Think Engine BD4179MWV is hot on plugging in *AND* pressing the power button.
    Discovered short to ground on VCC5M power delivery IC NB690GRP (5 volt line, not the high current VCC5M_PD) which is one of the ways that chip is powered. I'm puzzled.
    Nothing else is warm on the board. CPU resistances are OK, 9V VSYS line is present from the BMIC. All misc and cables are disconnected.
    What do you guys think happened? I've got two theories:
    If the...
    I think ThinkEngine shorted first
    50.00%
    1
    I think 5V SMIC shorted first
    0%
    0
    I think something else happened
    50.00%
    1
    05-07-2024, 04:44 PM
