HP Pavilion dm4-1065dx long time to get the power led on
  • OscarAV
    • Sep 2024
    • Spain
    I just came here to see if someone has had the same problem I have, and if he or she solved It, to know how to do It.
    I have made a quick search for my laptop but I have not seen anything similar.
    I have an old laptop, an HP Pavilion dm4-1065dx which takes a lot of time to be ready to start if the laptop has been unplugged for a while. It has no battery. The battery failed long time ago. It needs to be plugged to work. But as I said, It can take a lot of time until the charging led gets on, and I can switch on the laptop. I am using an external monitor and an external keyboard too. I am using the original adapter, and I have checked that gives the proper voltage.
    There are many many components and I don't know what to check. Maybe some people have had the same problem, and if they managed to fix It, I can do the same to fix It too.
    Thank you very much for your attention.
    Regards​
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Make a request for clean me bios while posting your existing copy of bios in "Bios Section"
    This is the first step under such scenario.
    • OscarAV
      • Sep 2024
      • Spain
      Thanks a lot. I went to the BIOS section, and read the guides there, but just to be sure before I post anything there. I downloaded two files, a BIOS configuration utility, sp143621.exe, and a HP UEFI Support Environment, sp61101.exe.
      When I run the configuration utility on the cmd,
      It gives me an error, system not supported, unable to connect to HP WMI namespace:'root\HP'
      Then, I tried to install HP UEFI Support Environment, but It asks me to do a partition, and before accepting, I want to ask.
      I changed the original hard drive to an SSD one.
      I believe that at some point I updated the BIOS. In any case, in System Information on Windows 7 64 bits, the BIOS information says
      BIOS Version/Date Hewlett Packard F.27, 21/12/2011
      SMBIOS Version 2.6
      I don't know if I could post this right on the BIOS section, so just in case I post It here before.
      Thank you very much.
      • sssssssssssssss
        Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
        by sssssssssssssss
        I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
        Symptoms:
        • Laptop powers on but no display at all (completely black screen)
        • Caps Lock blinks twice with a pause, then repeats continuously
        • F12 LED stays on permanently
        • No POST, no boot sequence, nothing on screen
        Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
        What I've tried:
        • Hardware reset (battery removal, power
        09-04-2025, 06:45 AM
      • iZakre
        HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
        by iZakre
        Hello everybody!
        To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
        The thing is that I had installed TeamViewer and could log into the computer...
        02-19-2023, 02:27 PM
        by Vesko356
        08-11-2023, 03:27 AM
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • zenius
        by zenius
        12-08-2024, 06:13 AM
