electromagnetic field therapy
  • petit
    • 119
    Hi Guys,
    newbie here trying to help a friend out. i apolige in advance if i posted in the wrong subforum.
    I have here a PEMF (pused electromagnetic field therapy) machine from a good friend of mine, who use it to help horses to heal for tendon and bone problem.
    He bought this machine in Germany in the eighties, so there is no diagram available, I cant even find the manufacturer online.
    So anyway, the machine powers up and everything seems to work correctly but, there is no output signal to the pads.
    The machine is supposed to send electric pulses to the pads, the pad has a coil inside, so if a magnet is place next to the pad you can feel the magnet pulsating, but that is not happening.
    After some troubleshooting (i'm just a hobbyist trying to learn as much as I can about electronics) I found a bad zener diode mzp4732 conducting both ways, you can see the bad diode just on top the black cap.
    I ordered, replaced and when I hit the power switch the fuse blew .
    I did desolder the diode, got another one, put it with aligator clips and another fuse blew.
    then I put it in opposite direction trying to check all the possibilities and again another fuse. So for now i'm out of ideas, if anybody can help me with some ideas I would gladly appreciate it.
    Thanks in advance!
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: electromagnetic field therapy
    Moved from General computer discussion.
    sigpic
    (Insert witty quote here)
    • redwire
      • Dec 2010
      • 3907
      Are you sure this is a 110V or 220V device?
      The zener, (if it's between the two caps and the heatsink) is in series with the neighboring diodes. It seems to function as rectifier/power-feed for the UA78G voltage regulator (on the little heatsink). The diodes would lower the incoming AC to a voltage the Vreg can handle (max. 40V) and something the black electro's could take. What rating are the caps? A shorted zener might over-voltage them.
      With no zener, if fuses still pop, then you have a problem elsewhere.
      I would check all the diodes, by the black caps and the output? cable (gry/red/vio wires), and what is the big heatsunk part below the big red box (mains EMI filter?). It looks like an SCR or triac. They do short easily.
      Don't use the yellow metal C-clamp to hold down the toroid transformer if the center bolt is in. It can act as a shorted turn and make the transformer draw more current than usual.
      Hope this helps a bit.
      • Jack Crow
        It's a CLASOB!
        • May 2008
        • 823
        P
        You pick the winners don't you.
        I think we need more information and photos about this thing.
        Can you take good high quality close up photos?
        Sometimes a more experienced tech can see things a new guy would miss. It's happened here before.
        Don't forget to include images of these 'pads' you call out.
        If they are some kind of E/M transducer a shorted winding will do bad things to your generator.
        If it's a coil kind of device I can give you some basics on how to see if it's working or at least compare the two of them.
        (Im assuming two pads per generator.)
        Did you get an 'owners manual' with it?
        In English I hope.
        A careful read of it may shed some light on the matter.
        Same for your vet friend, have him write up the way it's used and post it here.
        Also what is a similar unit on the market.
        Might be able to glean some useful information from competitors write ups. Similar machines made for the same task.
        (Just for giggles I looked up electro convulsive therapy machines.
        Seems there are two vendors in the US and they trash each others products on the web sites!)
        Might also help to know just how it died.
        The truth, not the usual stories we get from clients.
        Did they do something stupid like trying to heat coffee with it?
        Leave it out in the rain, plug it into 220vac?
        You can usually get clients to tell the truth about equipment failure, if it will save them some money.
        It's a trick that will save you a lot of hours fooling with equipment.
        Some place in the world is someone who works on this thing.
        Might have to dig more and nose around a bit.
        Photos of the front panel, OEM's name and if there is a plate on the back with the tech data? Some have FCC ID numbers or UL data. Might be able to back into the service info that way.
        What concerns me is that ugly wire bridge on the bottom of the circuit board.
        Is that photo of the 'stock' condition of post repair?
        Can you test the zeners you tried? Are they blown too?
        That is as we say a clue.
        Also look around for schematics and service data on similar units.
        Might get a clue there as to what you have.
        You did get on the right board for this.
        Many members here live in Europe and may have a connection or know someone who 'worked there'.
        Give it a few days.
        Im going to flag this post with an 'e mail subscription' and wait for some answers.
        If all else fails, your going to have to check each part on the board.
        Some can be tested in circuit, some will have to be removed.
        Again good photography will insure you put everything back the way it was.
        I'm hoping your the first to look at it since failure, and not the last. Just fixed a car audio amp that someone else fixed and failed at. No joy there.
        Much luck
        Jack Crow in Virginia.
        "You are, what you do, when it counts"
        The Masso
        "Gravity, the quickest way down"
        Mayor John Almafi
        "You ever drop an egg, and on the floor you see it break?
        You go and get a mop so you can clean up your mistake.
        But did you ever stop to ponder why we know it's true?
        If you drop a broken egg you will not get an egg that's new?"
        MC Hawking
          Front panel pictures of the unit, back panel, how the transducer is connected to the unit. The board looks like home made board since there are no designators at all for the component on the board.
          Also pictures of how the wires from the Toroid transformer are connected to the board.
          • diodo49
            • Dec 2012
            • 17
            Home Made like tortillas? mmm...
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Looks homemade or given the vintage, a prototype/short run. The PCB layout was done by hand.
              Also a bit of bodge work... I see a lot "jimmied" components (axial parts soldered between component terminals, bare leads intentionally shorting pads, etc.).
              I kinda doubt you will find a schematic... unless, of course, it was out of a magazine or other publication.
              sigpic
              • petit
                • 119
                Hi guys,
                thank in advance to those who chimed in!
                i took some close up pictures this morning like Jack Crow suggested yesterday.
                Hi redwire, yes, it is a 110V/60 hz device
                the caps are 220 microF 40V, and yes, both zener are in series and both are 4732 4.7V. the next diode is a regular 4003. also what's up with those zener in the same direction and both being the same value? to me the second zener would only see the fixed voltage from the first, am i right?
                i have checked those three diodes around the black caps and the bad one was that one (the one on top of the black cap).
                i have also check those wires, it was the first thing i did because the only problem with the machine was not getting signal to the pads, everything works, even the led in the front cover blinks as fast as the pads should, that's why i though the problem was in the output.
                the diodes next to the red box looks fine, but the one next to the red box has the brigde under, so i dont know what they were trying to achieve there.
                in the big heatsink below the red box there is a 2N4444
                good catch! i didnt think about that!
                i attached a pic of one of the pad, the machine can work with one or two pads, in order to use two pads there is a extension cord with two outputs.
                In English I hope.
                no luck finding a manual or diagram anywhere
                there are some similar units on the market, in fact i own one machine, it's similar, it looks like an upgraded copy, it's not nearly as powerfull as his, but i can take a look inside to see if i can find any similarities.
                i dont know how it died, i can ask him, he just told me it stoped getting signal to the pads, i'm gonna ask him to see if he can elaborate more..
                P
                you have good eye! i have the same concern,i dont know what that bridge is doing there either! that is the diode next to the red box, it doesnt sound very smart putting a diode, and then make it useful soldering a bridge under.
                P
                the first zener i soldered blew, the second one i tried with alligator clips in series with the neighboring diodes, and this one survived. but the fuse didnt
                P
                That concerns me, i'm not the first one messing with it. he took this machine to some place to repair, and they refused to fix it, because it was manufactured by a competitor, they were not allow to touch it, so i hope they didnt damage the machine on purpose, just to make him buy one from them.
                he has another identical machine, so i think i'm gonna take some pictures of the working one to check discrepancies, i have been hesitant about start messing with the working one, because he makes a living with theses machines, so i cannot afford an accident that could damage that one.
                it really looks homemade, but he paid more that 4 grand in the 82 for it, just the machine with no pads, but he has helped hundreds of animals with it to recover from bone fractures, dogs and cats after being hit by cars...the machine really works.
                thanks a lot for your help!
                • petit
                  • 119
                  sorry, forgot the pics!
                  have a great day!
                    Is there any labeling on the Toroid transformer? I see two red wires and two black wire connected to the PCB, any info on the transformer as to what they are?
                    Also that red module, do you have the name and P/N on the top of it? I cannot see it clearly.
                    • petit
                      • 119
                      a picture is worth a thousand words!
                      yes two red and two black to the PCB
                      Thanks!
                      Ruben
                        OK, I am trying to draw up the diagram. Can you please circle the Zener diode you have replaced?
                        • petit
                          • 119
                          there you go!
                          thank you
                            Please the picture.
                            Hmm, I draw up the connection, that Diode should be regular rectifier.
                            The mzp4732 is printed on the Diode? How about the other 2 Diode closed by?
                            • petit
                              • 119
                              i didnt replace them myself,
                              that is why i think those people messed it up! i just spoke to my friend and he told me the machine was in their custody for some time and after that they refuse to fix it for him.
                              what do you think about that wierd bridge shorting that diode? (pic pemf11)
                              thanks a lot!
                              • petit
                                • 119
                                yes, mzp4732 is printed in both, the top ones are both the same in series, and the next one is a regular diode 4003 and after that split to the capacitor and to the voltage regulator
                                  OK, please look at my redlined based on how the two diodes are installed.
                                  That RED modue is slome kind of power suply module (not 100%) that are being fed by the second power supply.
                                  Did this unit work at all before you have done any repair to it?
                                  • petit
                                    • 119
                                    the machine powers up, and start the treatment, when i hit the start button, led diodes blink but nothing happen in the pads.
                                      But right now it is blowig the fuse? The same size anf type of fuse being used? since Toroid transformer has VERY high inrush current.
                                      • petit
                                        • 119
                                        Yes, right now blowing fuses, after i replaced the bad zener diode (the black one is the one that came, that i put back for the picture)
                                        i put a lower rating fuse, the original one is 1.25A, but couldnt find that one locally so i put a 1A. I have the 1.25 ordered. maybe that is a posiblle problem beside the diodes?
                                        • caspian
                                          What Zener Diodes on a Linear Power Supply
                                          by caspian
                                          Dear members,
                                          I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                          In addition, I discovered that its zener diodes are defective.
                                          I can replace the burned transistors.
                                          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                          Therefore, I cannot replace the zener diodes.
                                          I do not want to test the zener diodes in a test circuit to discover their model or value.
                                          no schematics are available...
                                          05-26-2025, 12:38 PM
                                          ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                                          This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                        • CG2
                                          Janome DC3050 Sewing Machine Pedal Resistance
                                          by CG2
                                          OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                                          Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                                          04-14-2023, 07:53 AM
                                        • Soulzink
                                          Samsug washing machine. Power supply DC41-00189a board issue
                                          by Soulzink
                                          I am trying to fix a samsung washinmachine power supply main board.
                                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                          The power supply board reference is the following: DC41-00189a
                                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                          04-19-2025, 06:26 AM
                                        • nev1001
                                          What zener diode might fix the sound on Maestro Mayhem gaming chair?
                                          by nev1001
                                          Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                                          The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                                          It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                                          I think an issue could be a zener diode (or capacitor) which has shorted out.
                                          The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                                          04-17-2025, 05:09 PM
