electromagnetic field therapy
  • petit
    • 119
    Re: electromagnetic field therapy
    Originally posted by budm
    If the output did not go high (close to the VCC level of the IC), then that IC has to be bad, the out put of the IC should be able to easily drive 2000 Ohms load without any problem at all.
    i was thinking about the posibility of a shorted component stressing the output of the IC. i dont know if that is posible.
    i the same thing happened to the vreg, a IC was shorted and it was stressing the Vreg to the point that i was getting just 2V at the output, after i replaced that IC the vreg went back to 16V
      The load on the output of the 8-input AND gate is only about 2700 Ohms that you have verified.
      • petit
        • 119
        Yeah, there is a 2.7K resistor between the output pin and the base of the transistor, but i also noticed that before the resistor, that trace splits and goes to the left side of the board to feed a 555 and another small chip, that i think is in charge of the led strip under the knobs.
          That trace must be feeding some components, what ever they are, lift one of the legs up so the output of the AND gate will no longer drive it, you will have draw up that circuits to see how it is hooked up.
          • petit
            • 119
            i'm trying to draw that part of the circuit right now.
            the first thing i find when that trace split to the left is a 27k resistor, so if i lift that resistor and the gate wont longer drive that part of the circuit, it would be safe to that? i dont want to burn anything else!
              You will not be driving anything, that 27K load should not cause the output of the AND gate to be low, way too high load resistance to cause that problem.
              • petit
                • 119
                ok, let me lift that resistor to see what happens
                • petit
                  • 119
                  still no output, output gate still low
                    Something is being overlooked on this simple AND gate, are you sure that ALL the input pins are HI, what is the reading on each input pins?
                    • redwire
                      • Dec 2010
                      • 3907
                      Hey one thing I noticed - some CD4068's do not have pin 1 connected. They are only a NAND gate without the dual (NAND/AND) outputs. Check the exact part data sheet.
                      • petit
                        • 119
                        Hi!
                        in this one pin1 is AND (the one in use) and pin 13 is NAND (not in use). i'm getting between 10 and 16V at all of the inputs
                        • petit
                          • 119
                          working on the schematic
                          • petit
                            • 119
                            i just short the emitter and collector of the transistor, that would be like turning the transitor and the beep stutters.
                            i corrected the diagram, the transistor is npn, i had it as pnp
                            • petit
                              • 119
                              i lifted the resistor going to the base of the transistor and the speaker turned off. still getting around 300mV. it looks like that transistor also drives the speaker, but i get lost looking at the schematic.
                              These are the values at the CD4068:
                              Vdd: 15.62
                              pin1: 362mV pulsing 176Hz
                              pin2: estable 10.16V
                              pin3:6.67-8.59V pulsating same frecuency as beeping
                              pin4: 5.59-9 pulsing 7.5Hz
                              pin5: 12.28 estable 60hz
                              pin6; nc
                              pin7:Vss
                              pin8:nc
                              pin9:7.76 estable 30Hz
                              pin10: this one acts crazy between 1-5-14-and OL, 3.747hZ
                              pin11: 15.54V estable
                              pin12:15.59 estable
                              • petit
                                • 119
                                any idea why the machine sound like there is a short somewhere when I short collector and emitter of the transitor driving the SCR?
                                • redwire
                                  • Dec 2010
                                  • 3907
                                  The SCR gets a fast pulse to turn it on. So the transistor driving the pulse transfomer only turns on for little blips. If you short the transistor C-E the pulse transformer gets too much power and overloads the power supply and the beeper stutters.
                                  Do you get any signal between A-K on the SCR?
                                  Does the LED bar graph do anything?
                                  Remember the pulse is fast, so your multimeter will not see all of it.
                                  I think it's best to finish the schematic, then it is much easier to troubleshoot.
                                  • petit
                                    • 119
                                    when i was shorting C-E i was expecting at least get the red led ON for a little showing output signal but nothing happened
                                    nothing there
                                    LEd bar graph works perfect
                                    i really dont understand how that transistor is working, i though it's supposed to drive the pulse transformer???? but is the one driving the speaker trough base-emitter
                                    all the output side is done. i'm not sure about the choke pins, but everything else is fine
                                    • petit
                                      • 119
                                      this morning i as checking frequency and voltage at pin1 of the AND gate.
                                      The frequency increase if I adjust the frequency knob.
                                      at lower setting it was 160Hz, next setting 320Hz, next 640 and at the higher setting 1280Hz.
                                      also checking voltages i was getting almost 4V at higher setting at pin1, but still mV after the 2.7K resistor R9.
                                        The output at pin 1 AC pulse which is now make sense since some of the input pins are pulses not steady DC. The pulse at the other end of the resistor will be about 0.6~0.7V maximum bude to Base-Emitter junction voltage. If you look at the Base-Emitter voltage, you will see 0.6~0.7v pulse.
                                        • petit
                                          • 119
                                          I wish i was getting that at the base! at full power setting i'm getting 234mV after the resistor, not enough to trigger.
                                          i think i dont understand how that gate work. i tough i was supposed to get full voltage at pin 1 when all of the inputs are HI???
                                          how is that outout voltage being regulated?
                                          are the inputs capable to regulate the output pin?
                                          • caspian
                                            What Zener Diodes on a Linear Power Supply
                                            by caspian
                                            Dear members,
                                            I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                            In addition, I discovered that its zener diodes are defective.
                                            I can replace the burned transistors.
                                            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                            Therefore, I cannot replace the zener diodes.
                                            I do not want to test the zener diodes in a test circuit to discover their model or value.
                                            no schematics are available...
                                            05-26-2025, 12:38 PM
                                            ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                                            This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 03:28 PM
                                          • CG2
                                            Janome DC3050 Sewing Machine Pedal Resistance
                                            by CG2
                                            OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                                            Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                                            04-14-2023, 07:53 AM
                                          • Soulzink
                                            Samsug washing machine. Power supply DC41-00189a board issue
                                            by Soulzink
                                            I am trying to fix a samsung washinmachine power supply main board.
                                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                            The power supply board reference is the following: DC41-00189a
                                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                            04-19-2025, 06:26 AM
                                          • nev1001
                                            What zener diode might fix the sound on Maestro Mayhem gaming chair?
                                            by nev1001
                                            Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                                            The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                                            It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                                            I think an issue could be a zener diode (or capacitor) which has shorted out.
                                            The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                                            04-17-2025, 05:09 PM
