electromagnetic field therapy
  • petit
    • 119
    Re: electromagnetic field therapy
    Originally posted by Uranium-235
    I don't know if anyone has gotten around to this, but have you thought about replacing all the caps? if this thing was built in the 80's and hasn't been used, the caps might be completely dried out
    I skimmed the thread the best I could to see if there is any mention of cap readings but unless you take them out of circuit usually you aren't going to get a proper reading. and yes that goes for the green cap in the middle
    Hi Uranium,
    that might be a good idea, i've been hesitant to start replacing everything, because when i took this machine i tought it was something simple, because the machine stopped working suddenly, it's not that it was stored for years.
    First thing i found bad was the second zener in the string after the transformer, so i thought i had found the problem, but i didnt.
    do you think i should start replacing caps? which ones first?
    Thank you
    • petit
      • 119
      Hi!
      anybody know what is that part with 68nS printed?
      there are two of them after the SCR gate and before the choke that look pretty toast
      Thank you!
      • redwire
        • Dec 2010
        • 3907
        On the pcb I see a few of those oddball black square parts and guess that they are boxed MKT film capacitors 68nF Siemens? They are pretty reliable and look okay, no toast.
        I'm not sure what the unit is doing now? Is it still blowing fuses? Do you get +15V from the Vreg? You put in the bigger 5W zeners, changed a few cmos chips and I'm not sure where things are at.
        For the two blue blob capacitors (tantalum) can you read the #'s off, as they can short if over-voltaged.
        • petit
          • 119
          not blowing fuses anymore but still not working.
          last time i checked, after i burned the IC, i was getting 16V
          yes, i did put the one that was blowing all the time and no problems after that
          i change all of the cd4000, the last one i changed was the bad one, i also changed one of the 555, with no luck fixing the no output problem.
          also changed metal can transistor next to big red box.
          i ordered a replacement for the SCR 2n4444 but the one they sent has less lead spacing, so is useless.
          The big one says:
          +68
          +16V
          W Germ.
          The small one
          +6.8
          +25V
          Thanks a lot!
          • redwire
            • Dec 2010
            • 3907
            When you say it doesn't work - the red/green led's come on? (and) there is no pulses felt in magnetic coils?
            At this point, you have to poke around with an oscilloscope and trace the signals, or keep guessing and changing parts.
            • petit
              • 119
              Green light next to the control knobs come on, the red led next to the output doesnt (it's wired right to the output) and still no pulses in the magnetic coils.
              i dont have access to an oscilloscope, i have it in my wishlist!
              i'm going to change some of the capacitors and hope to get lucky...
              Thank you!
              • petit
                • 119
                Replaced blue tantalum caps and and filter caps next to Vreg and still nothing. i tested the old caps for capacitance with DMM and they gave the specs value. i replaced them anyway.
                do you guys think i should replace the SCR next to the output? it's like $20. expensive part for a guessing game.
                should i desolder it and test it out of the circuit?
                  I believe the LED should be blinking even if the SCR is not installed since it looks like the pulsing is done by the 555 Timer IC that I think I see on the board for the Hz SWITCH SELECTING circuits, please see if it has one. You can look for the pinout andfunction of the 555 to see if it is oscillating or not. Look at output 3 with your meter, the voltage should be swinging up and down at low frequency as set the Hz knob.
                  • petit
                    • 119
                    i can see 3 555 timers, one next to the speaker, another one next to the three red square caps on the left and another next to the big green cap.
                    The green strip blinks and the speaker change the beeping frequency when i move the HZ knob. that's why i think the timer in charge of the oscillating is working.
                    the red led is wire to the output with a resistor in series.
                    what about that choke box? and the brown box next to it?
                    Thank you!
                      "the red led next to the output doesnt " so this LED is connected to the output port that goes out to the magnetic tranducer? You should be able to see pulsing at the Gate of the SCR if it is being driven by the low frequecny.
                      • petit
                        • 119
                        Yes, Red LED is conected to the output
                        How do i check that? red probe to gate and black to catode? sorry for the newbie question but i dont want to messed it up again!
                        • petit
                          • 119
                          output side, grey/white wire goes to Red Led
                            Yes, per REDWIRE post51 drawing. I do not know where the transformer for the Gate drive is on the board.
                            • petit
                              • 119
                              SCR is working... i tested it out of the circuit with a "flashlight SCR tester".
                              any idea?
                              Thank you!
                              • petit
                                • 119
                                I was thinking maybe one of the 555 timers is damaged? the one that trigger the pulses to the pads?
                                the machine has three, one for the speaker, another one for the green LEd's and the other for the pads?????
                                  You can check at the output pin (pin3) to see any action on all of them.
                                  • petit
                                    • 119
                                    I just checked the 555 and the results were 16V in two of them and 3V in the other. is that possible?
                                      What DC voltage do you get at pin8? If you are seeing 16V at output pin 3, then the VCC on pin 8 must be even higher which means that the Voltage regulator IC is putting out too much DC, redwire had indicated that it should not be higher than 15V or 16v on thread 49
                                      • petit
                                        • 119
                                        16.19V on pin8 on all of them. i double check and still getting 3V in that one. could be that the problem? damage 555 timer?
                                          May be, it depends on how the 555 is set up to be, the one with 16V out put may not be setup as Oscillator. You can put your meter to AC mode and take the reading at the output pin of all 3 555 to see what you read.
                                          • caspian
                                            What Zener Diodes on a Linear Power Supply
                                            by caspian
                                            Dear members,
                                            I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                            In addition, I discovered that its zener diodes are defective.
                                            I can replace the burned transistors.
                                            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                            Therefore, I cannot replace the zener diodes.
                                            I do not want to test the zener diodes in a test circuit to discover their model or value.
                                            no schematics are available...
                                            05-26-2025, 12:38 PM
                                            ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                                            This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 03:28 PM
                                          • CG2
                                            Janome DC3050 Sewing Machine Pedal Resistance
                                            by CG2
                                            OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                                            Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                                            04-14-2023, 07:53 AM
                                          • Soulzink
                                            Samsug washing machine. Power supply DC41-00189a board issue
                                            by Soulzink
                                            I am trying to fix a samsung washinmachine power supply main board.
                                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                            The power supply board reference is the following: DC41-00189a
                                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                            04-19-2025, 06:26 AM
                                          • nev1001
                                            What zener diode might fix the sound on Maestro Mayhem gaming chair?
                                            by nev1001
                                            Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                                            The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                                            It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                                            I think an issue could be a zener diode (or capacitor) which has shorted out.
                                            The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                                            04-17-2025, 05:09 PM
