electromagnetic field therapy
  • petit
    • 119
    Re: electromagnetic field therapy
    Anybody?
    Thank you in advance
    • redwire
      • Dec 2010
      • 3910
      The pulse transformer only passes... pulses. The transistor must give 16V AC blips in order to get the signal to the SCR. If the transistor was on all the time, you would not get anything on the pulse transformer output- it does not pass DC. The transistor would get very hot too. The SCR only needs 0.6V to turn on but it is only on for the EMF pulse, which is fast and hard to measure. Two things you can do:
      Pretend the SCR is actually getting triggered, and check parts downstream, like the diodes, red transformer, red led, coils and wiring etc. The SCR should have voltage on its anode. You can use a couple 12V lightbulbs (#194) in series to emulate the EMF coil.
      2. If the SCR (gate drive transistor) is getting nothing, then I would guess one of the signals on the AND gate inputs is not working. The signal on "pin10: this one acts crazy between 1-5-14-and OL, 3.747hZ", I would trace that back.
      I also noticed the 6 bigger resistors (like blue-gray-blue-silver?) which is 68Megohms. I think with the 10uF film (green) cap, it makes for a very long timer. This thing has a session timer, like 30 minutes? What does the G knob do?
      • petit
        • 119
        Hi!
        correct me if i'm not understanding the purppose of the transitor NPN there,
        on the pulse transformer, the primary winding has voltage at pin 1-ground and voltage at pin2-ground (same at both 16V) and a frequency of 160Hz at the lowest frequency setting of the machine. collector of the transistor is also connected to pin1, emitter goes to ground and base goes to the AND gate, so i assume when the transistor is triggered pin1 is shoted to ground so there is a voltage between pin1 and pin2 that way the pulse is accomplished, because right now i dont get any voltage at pin1-2. it is that the way it works?
        SCR anode is conected to ground
        yeah i think that pin10 it's a little wierd too, maybe that one it's keping the transistor off being triggered right??? that pin goes to the frequency knob and also goes to one of the cd4013 that i really have no idea how they work i got to check those
        you're spot on regarding those resistors and the big cap, sesion timer is 30 minutes!
        the G knob is Gauss, intensity of the magnetic field from 40 to 100, but i dont know how it's that being regulated because i get 16V at pin1 and pin2 no matter where i set that knob
        i'm getting an oscilloscope that way i can troubleshoot better
        Thanks a lot for your help!
          SCR anode is conected to ground, are you sure?
          • petit
            • 119
            Pretty sure, check this pic, the trace is coming from toroid transformer
              If you look up the spec sheet, that pin on the bottom is Cathode (K), Middle pin is Anode, top pin is the Gate.
              http://pdf1.alldatasheet.com/datashe...LA/2N4444.html
              • petit
                • 119
                You're right, my bad. so anode goes to choke
                  Yes, the Gate has a 33 Ohms resistor to Cathode, and a cap in parallel, the Gate gets the drive signal through a diode, like I said before, you can manualy trigger the SCR by pulsing the Gate using resistor between Anode and Cathode by touching and un touching th resistor between Anode and Gate, you said it did not do anything last time, that because you did not know which pin is Anode or Catode. It is hard when we get wrong information.
                  See post 51 for the diagram by redwire.
                  • petit
                    • 119
                    nothing happens. 330 ohm resistor between gate and anode (middle pin)
                      What dc and AC do you have at these two points?
                      By the way, this your drawing also show which pins are A, K, G for the SCR that you had marked.
                      I see why it does nothing, the power from the power transformer red wires flow through the transducer to supply the voltage to the SCR, so you have to have the transducer connected to the jacks.
                      • petit
                        • 119
                        yes, i did it right in that pic, but in the schematic is backward.
                        Do you mean between those two point or at each point and ground?
                        thank you
                          Do you have the transducer connected? Just read between the two points as shown.
                          • petit
                            • 119
                            i tried with the transducer and without it. also in all settings. let me do that
                            • petit
                              • 119
                              56 VAC pad connected, 8VAC no pad 60hZ, 350mV vDC. in the backplate machine says ouput 2x24V
                                "56 VAC pad connected" OK, that sound about right, now you should be able to pulse the Gate by connecting/diconnecting resistor between Gate and Anode with pad connected and see what happen.
                                By the way check the AC voltage between A and K, it should also have about 56VAC (no pulsing with the resistor).
                                • petit
                                  • 119
                                  i already did like 10 minutes ago, with a 330 ohm resistor between gate and anode (middle pin) and nohing happened.
                                  i did test the SCR and it gets triggered, but not with the resistor
                                    with the pad connected? If that is the case, that SCR is not turning on. Also what AC do you get between A and K?
                                    • petit
                                      • 119
                                      nothing, .5 VDC and nothing AC. yes pad connected
                                        That means the choke has open circuit!
                                        • petit
                                          • 119
                                          i think you got it!
                                          • caspian
                                            What Zener Diodes on a Linear Power Supply
                                            by caspian
                                            Dear members,
                                            I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                            In addition, I discovered that its zener diodes are defective.
                                            I can replace the burned transistors.
                                            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                            Therefore, I cannot replace the zener diodes.
                                            I do not want to test the zener diodes in a test circuit to discover their model or value.
                                            no schematics are available...
                                            05-26-2025, 12:38 PM
                                            ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                                            This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 03:28 PM
                                          • CG2
                                            Janome DC3050 Sewing Machine Pedal Resistance
                                            by CG2
                                            OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                                            Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                                            04-14-2023, 07:53 AM
                                          • Soulzink
                                            Samsug washing machine. Power supply DC41-00189a board issue
                                            by Soulzink
                                            I am trying to fix a samsung washinmachine power supply main board.
                                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                            The power supply board reference is the following: DC41-00189a
                                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                            04-19-2025, 06:26 AM
                                          • nev1001
                                            What zener diode might fix the sound on Maestro Mayhem gaming chair?
                                            by nev1001
                                            Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                                            The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                                            It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                                            I think an issue could be a zener diode (or capacitor) which has shorted out.
                                            The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                                            04-17-2025, 05:09 PM
