Janome DC3050 Sewing Machine Pedal Resistance
  • CG2
    • Nov 2022
    • 37
    OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
    Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that the sewing machine is working.
    Turning to the pedal. This connects to the sewing machine via a small connector the size of an MP3 player headphone jack, but with just two connections. Internally it is a 200 ohm resistor in series with a sliding linear potentiometer. Unpressed it shows a resistance of c 25k, and this drops linearly when pressed to 200. The sewing machine does not respond to it. The pedal does however contain a trim pot, enabling the maximum resistance to be increased to about 45k, and when adjusted to that maximum the sewing amchine starts up straight away (at about half speed) with the pedal unpressed, then stops when it is pressed. I've tried to jerry rig random resistors, but had no success at getting anything to work.
    Does anyone have any ideas for what else I could try. It would be wonderful if someone had this exact model of sewing machine and could check the pedal resistances for me, but that is a very long shot. Of course that is assuming that the pedal works by resistance and not through some overcomplex active circuitry. Any suggestions would be gratefully received.
  • redwire
    • Dec 2010
    • 3912
    Re: Janome DC3050 Sewing Machine Pedal Resistance
    There's nothing for technical info about Janome 5V pedals out there.
    Looking at a picture of a Janome 21371 pedal cleaning (website closed) I see an electrolytic capacitor which might be your problem. Try adding a 10-22uF 16V across the potentiometer and tell us what the machine now does.
    • cind12
      GTX 1080 TI Gigabyte Aorus low resistance on vmem
      by cind12
      Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
      Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
      The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
      Resistance on 12V 4K ohms (Power present when on)
      Resistance on 12V PEX 4K ohms...
      12-08-2023, 09:09 AM
      ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
      This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      09-12-2024, 03:28 PM
    • Nagy Daniel
      Lowest possible resistance on laptop motherboard rail - Guide Table request
      by Nagy Daniel
      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
      So, I generated a table with AI so I can...
      03-04-2025, 08:24 AM
    • unimatrix93
      How to stabilize AC voltage to CNC machine
      by unimatrix93
      Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
      I have a CNC machine wired to 3-phase 230V AC.
      It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
      The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
      I contacted the electricity company but they refuse to help me solve this problem.
      So I started to look around for some DIY...
      03-17-2025, 05:52 AM
    • xdever
      820-01700 not booting, 4V PP2V5_NAND_SSD0 but 2.5V when the machine is off.
      by xdever
      I got a 820-01700 of a friend that doesn't turn on. I read that a typical issue with these boards is the TPS62180 generating the NAND voltages, so this is where I started looking. Sure enough, PP2V5_NAND_SSD0 is 4V when the machine tries to turn on (I try to determine this by measuring PP2V5_NAND_SSD1, which is 2.5V as it should in this case. The PP0V9_SSD0 and PP1V8_SSD0 power supplies for the SSD are on at the same time when PP2V5_NAND_SSD0 is 4V). The extremely weird thing is that when the machine is off (PP2V5_NAND_SSD1=0, PP0V9_SSD0=0 and PP1V8_SSD0=0), PP2V5_NAND_SSD0...
      01-15-2025, 08:44 PM
