electromagnetic field therapy
Re: electromagnetic field therapy
On all three 555's output pin?Never stop learning
at this point should i recap the whole machine?
there is no that much left to replace...the only thing left besides the resistors is: three small can transistor,4 of those square black things, one 555 timer, the choke and the other brown box (pulse transformer i think)....
replace already: all the cd4000 two 555 timers,electrolitic filter caps, big metal can transistor, both tantalum caps, some diodes.
any idea?Comment
What do you guys think about the pulse transformer driven by the metal can transistor?that pulse transformer drives the SCR gate, and that SCR gate is not getting any voltage.
following the traces, i'm almost sure that the pulse transformer is getting voltage. do they usually get damaged?
any way to test it?
You will need to find out how the primary is driven, may be by a transistor?Never stop learning
that transistor was replaced, so it's fine.
can i check if that transistor is getting voltage without messing up anything?Last edited by petit; 01-25-2013, 09:48 PM.Comment
You should be able to check the Voltage at the Base and at the Collector, I believe the Base should be driven by the 555 to produce the pulse. Need to find out where the trace from the Base goes to.Never stop learning
Testing the transistor i'm not getting voltage at the base. the trace comes from that CMOS, (CD4068BE) left corner of picture pin1.
That chip is getting voltage at VDD and after that, i dont know what to do.
That chip is new
.Comment
yes, i'm getting voltage at the base, mV, because of the resistor 2.7K next to base. now i'm lost after the transistor. after that it goes to the pulse transformer.
any idea testing that pulse transformer??Last edited by petit; 01-26-2013, 12:50 PM.Comment
Tracing out the board will be the best thing to do at this point.Never stop learning
If you take picture of both sides of the board, in Gimp or Photoshop mirror the PCB pic and then overlay on top of each other. Then it's easy to draw the schematic, and you don't have to keep flipping the PCB around and breaking wires.Comment
Pulse transformers rarely die. You can check with an ohmmeter, a low reading across the primary and then the secondary windings. The (pulse-xfmr) transistor will need >650mV on its base before it turns on. If you are getting much less voltage, then the fault is probably upstream.
In your picture, there is a white teflon sleeve connecting a part. It's looks kind of crappy, is the lead connected, with no shorts?Comment
This right here shed some light on the problem, but what it can be??? there is a trace coming directly from the chip...there is just a 2.7k resistor in that path...Comment
That is the typical way of interface the output of the Logic IC to drive the transistor. cd4068 is an 8-input NAND gate, you need to download the spec sheet and look at all 8 input pins to see what you have and how all 8 inputs are connected to.Never stop learning
by caspianDear members,
I have a linear variable power supply with unknown brand name that I used for voltage injection.
Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
In addition, I discovered that its zener diodes are defective.
I can replace the burned transistors.
But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
Therefore, I cannot replace the zener diodes.
I do not want to test the zener diodes in a test circuit to discover their model or value.
no schematics are available... -
This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-12-2024, 03:28 PM
by CG2OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by nev1001Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
I think an issue could be a zener diode (or capacitor) which has shorted out.
The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...-
- Loading...
