I'm currently replacing the output capacitors in a LM2437 CRT driver circuit for a TV.
The datasheet is here:
https://pdf1.alldatasheet.com/datash...C/LM2437T.html
From the labels on the PCB of the LM2437 IC the input voltage is 80V.
Howewer, datasheets and original capacitors on the board suggest 1uF/160V as the output coupling capacitors for RGB signals.
Here:
Do you guys think that I can use 1uF/100V capacitors and the datasheet is overrating the voltage? I assume that the maximum voltage on the three...
