I'm currently replacing the output capacitors in a LM2437 CRT driver circuit for a TV.
The datasheet is here:
https://pdf1.alldatasheet.com/datash...C/LM2437T.html
From the labels on the PCB of the LM2437 IC the input voltage is 80V.
Howewer, datasheets and original capacitors on the board suggest 1uF/160V as the output coupling capacitors for RGB signals.
Here:
Do you guys think that I can use 1uF/100V capacitors and the datasheet is overrating the voltage? I assume that the maximum voltage on the three lines would be no higher than 80V.
Here:
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
