What are the best caps for AC coupling a video signal?
  • Y. Signal
    • Apr 2018
    • 77
    • Spain
    Hello.
    I'm currently using 6.3V 330uF Panasonic FC capacitors for AC coupling a 75 ohm impedance video signal coming from a THS7374. They work fine, but I like to improve my designs so I'm considering using better ones.
    I wonder if polymer capacitors would be better for my application. If so, I'd like to know what parameters I should look for to make a good choice.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Re: What are the best caps for AC coupling a video signal?
    "Improve" ?
    Left out too many details to make heads or tails of your query.
    Normally large electrolytics are used to decouple. The way I read your query you either overdesigned or made a serious design error...
    Schematic would be good.
      • 31283
      your blocking DC while allowing as much AC signal as possible,
      so as long as the cap has the bandwidth, the lower the esr the less losses you will incure.
      having said that, video signals dont have to travel far so minor losses arent important.
      • Y. Signal
        • Apr 2018
        • 77
        • Spain
        Thank you. My reason to replace aluminum electrolytics with polymers is reliability, endurance and lower ESR.
        My circuit uses the example in the THS7374 datasheet for AC coupled output (page 25): https://cdn.badcaps-static.com/pdfs/...7cc648ca74.pdf (330uF capacitors polarity is wrong in this schematic).
        • redwire
          • Dec 2010
          • 3912
          Polymer capacitors are used not for signal coupling because they have high dielectric absorption and non-linear behavior.
          You will find your video is distorted because of the polymer capacitors. This is also the case in audio use of polymer caps for blocking and AC signal coupling.
          • Y. Signal
            • Apr 2018
            • 77
            • Spain
            Thank you for the information. Then I'll continue using Panasonic FC.
              by momaka
              03-12-2025, 03:42 PM
              by momaka
              03-15-2023, 10:17 PM
            • benspawn02
              Anthem MRX500 - no sound. R2A15218FP issue??
              by benspawn02
              Dear Electronics Experts:
              I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
              08-12-2023, 04:46 AM
              HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
              This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
              09-12-2024, 02:00 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
