Init Paper Shredder sensor circuit
  • davg
    • Sep 2008
    • 536
    Re: Init Paper Shredder sensor circuit
    Originally posted by budm
    That cap is for the DC power supply for running the electronics on the board.
    So from the picture: This must be reverse-able motor.
    The Yellow and the Green wires are for the motor's brushes?
    The Blue and White wires are for the Stator motor winding?
    The slide switch on the board, is that for forward/reverse motor function if you have paper jammed?
    That is correct it is reversible? The slide switch is Auto - off - reverse. When set to auto the sensor starts the unit
    • 999999999
      • Sep 2006
      • 774
      lol, I am reminded how much of a headache I get trying to trace circuits from random pics. Can you trace the circuit back a bit and with power off, measure resistance with the slide switch flipped one way, then the other? Looking at the switch contacts as two columns in the picture of the back of the PCB, the first two rows of contacts in each column should read very near zero resistance between each other when the switch is flipped that direction, and vice versa for when the switch is flipped the other direction.
        That is common function for shredder, my has the same but it uses micro switch for sensing paper.
        Any how, you are reading only 57VAC on the brush connections? They may have the Stator and the rotor winding in series setup.
        That is why good clear pictures are important when you do not have the board right in front of you.
        • davg
          • Sep 2008
          • 536
          Forgive me put on the attached picture which contacts should be near zero resistance?
            Does the motor run the same speed in both direction? If it does, then that will eliminate the contact resistance problem.
            When the slide switch is in the left position (base on the picture with numbers)
            1 and 2 should be 0 ohm.
            5 and 6 should be 0 Ohm
            when move it all the way to the right position
            3 and 4 should be 0 Ohm
            7 and 8 should be 0 Ohm
            • davg
              • Sep 2008
              • 536
              The motor do run the same speed in both directions. The resistance is 0 ohms on these contacts with the switch in the designated position. Just to confirm; To supply 120 vac to the 120 volt motor, the yellow and the green is L1 and L2 with the Blue and White being the two field poles. How would I connect it to bypass the board?
              • selldoor
                Slow Learner
                • 7870
                #27
                When you say the motor runs slow what are you comparing it with?.
                How long does it take to shred a sheet?
                • davg
                  • Sep 2008
                  • 536
                  That is compared to when it worked properly. About 10 sec working properly to approx 40 sec now.
                  • selldoor
                    Slow Learner
                    • 7870
                    #29
                    ok i believe normal max is about 3meters per minute. Is there any detail on the motor that might help us find the specs for it?
                      Can you remove the motor from the assembly so you can run it without the load, and since it uses the gear reduction to run the shredder assembly, can you crank the assembly by hand using the same gear that the motor is attached to just to find out how hard it is to move the blades.
                      I believe the stator and the rotor windings are connected in series, and they reverse the direction by switching either the stator or rotor winding connection.
                      I still do have the time to draw up the wiring diagram yet.
                      • 999999999
                        • Sep 2006
                        • 774
                        He could also check voltage across a different combo of wires going to the motor to see if any combo is at ~ 120VAC. Since the cutters turn ok with the gear removed it seems as though either not enough voltage is getting to the motor or it has a short in the windings.
                        OR what I mentioned earlier, that the blades are really dull and it's choking on the paper which would make it run significantly faster with a narrow piece of paper vs a full width piece.
                          Good suggestion, 9999999.
                          • davg
                            • Sep 2008
                            • 536
                            Thanks all the motor runs the same with or without load. Gears removed or paper in? The problem is either in the motor or in the board. As soon as I can find a drawing to hookup the motor straight and bypass the main board I can narrow down the problem even further.
                              I am beginning to think the same as 99999 that the motor may have shorted turn in the windings.
                                By the way, that big white power resistor 0.6 Ohm is in series with the motor, can you check and see if it read less than 1 Ohm?
                                  OK, I figured out how it works, see simplified diagram attached.
                                  The Rotor winding is connected in series with Stator winding, depend on how you connect them together, you can make it run forward or backward by reversing the Rotor winding connection, very simple, as long as the two windings are in series, the motor will run.
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #37
                                    Have we mentioned checking the brushes are not too worn or are the slides clogged with dust so the brushes are not seating correctly. When it is running are there a lot of sparks from the commutator, I recall you did say you had cleaned the gaps.
                                    • davg
                                      • Sep 2008
                                      • 536
                                      Thanks for the drawing budm great job. Problem solved. The problem was with the motor as someone indicated (cheap motor). I removed the motor completely and dissembled it to find that the wire connection to one of the brushes was broken. and one of the bearings was worn badly. I can replace the brush but the bearings are actually bushings and finding a replacements could prove impossible? Cheaper to buy new.
                                        Well at least you know how it is wired up now, I thought you had check the brushes in post 9 and indicating that they were OK. Live and learn.
                                        • davg
                                          • Sep 2008
                                          • 536
                                          Thanks again and yes I did check but I only removed the one on top easy to get at?? (making to many assumptions) your are right "live and learn". That drawing is a useful thing to have around.
                                          • CapSnap123
                                            Sensor on Aurora AS1018CD paper shredder doesn't work
                                            by CapSnap123
                                            I'm getting frustrated troubleshooting a paper shredder. The way the shredder normally works is when you turn the power on, nothing happens until you insert a piece of paper. There is an IR shredder in the shredder and inserting the paper breaks the beam and starts the shredder motor. But now the motor runs constantly, even when no paper is inserted. I've replaced the photodiode and the IR emitter. Also the relay makes a nice clicking sound so I assume it is working too. I don't know what else to check. Here's a photo of the circuit board. The red and black wires marked IR - go to the...
                                            04-20-2024, 03:57 PM
                                          • CapLeaker
                                            AcuRite 5 in 1 temperature sensor replacement repair
                                            by CapLeaker
                                            Got a new victim:
                                            AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                                            A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                                            B: stuck at some temperature and maybe updating once in 12 hrs or so.
                                            Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                                            04-15-2025, 01:32 PM
                                          • Nevillet
                                            Simple PIR sensor circuit to drive a small motor
                                            by Nevillet
                                            Hi All,
                                            I'd like some help designing a simple circuit for driving a small DC motor.
                                            The PIR module is a HC-SR501 which runs on 6V supply and outputs 2.4V when triggered. (Datasheet attached)
                                            I'm not totally sure which motor I need yet but lets assume it'll be 12V and draw a maximum of 100mA.
                                            Can somebody design me a simple circuit for me using something like a 2N3904?
                                            I'm happy to include a relay if that makes sense.
                                            Many thanks.
                                            https://www.badcaps.net/forum/attachment.php?attachmentid=3...
                                            07-09-2023, 10:48 AM
                                            HP ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio ProDesk 400 i5-6500 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio boardview and ProDesk 400 G2 Mini + 2x Pro Slate 8 Paper Folio schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            09-12-2024, 03:28 PM
                                          • groomit
                                            Google Pixel 5 - Proximity Sensor Issues - Reflow/Replacement procedure tipps wanted
                                            by groomit
                                            I just replaced the battery on a Google Pixel 5.
                                            After that the proximity sensor isn't functioning properly any more. It is constantly activated. So when playing a voice message on Whatsapp, the Screen instantly turns off.
                                            Checking with a sensor app I can verify weird behavior of the sensor. It is triggered when nothing is near and sometimes works correctly when squeezing the phone next to the sensor hole.
                                            The rubber seal is on again (as mentioned in various suggestions in other forums).
                                            This smells like a cold or broken solder joint. So I'd like to reflow...
                                            06-11-2025, 02:21 AM
