Google Pixel 5 - Proximity Sensor Issues - Reflow/Replacement procedure tipps wanted
This topic has been answered.
  • groomit
    • May 2023
    • 29
    I just replaced the battery on a Google Pixel 5.
    After that the proximity sensor isn't functioning properly any more. It is constantly activated. So when playing a voice message on Whatsapp, the Screen instantly turns off.
    Checking with a sensor app I can verify weird behavior of the sensor. It is triggered when nothing is near and sometimes works correctly when squeezing the phone next to the sensor hole.
    The rubber seal is on again (as mentioned in various suggestions in other forums).
    This smells like a cold or broken solder joint. So I'd like to reflow it. But the sensor sits on some sort of plastic socket and I'm not to sure it will resist the heat.
    I do have proper equipment and some experience in micro soldering.
    I'm interested in experience and tipps on how to approach this thing.
    Thanks an BR!
  • Answer selected by groomit at 06-11-2025, 01:09 PM.
    groomit
    • May 2023
    • 29
    An answer to myself for future reference:
    I just tried it with 300 °C with 50% airflow and it came off easy without melting. Reflowed it and now the sensor is working again.
    The "plastic" seems to be some sort of PCB-like material.
    • groomit
      • May 2023
      • 29
      • jasonr2000
        Macbook Pro 16" 2019 No Display After Lid Sensor Issue
        by jasonr2000
        hi guys i have the above MacBook pro 2019 16"
        i did some dust cleaning recently and i somehow damaged the lid angle sensor. so i purchased the nerdtool1 lid angle sensor calibrating tool and a new sensor.
        installed it and followed the instructions to program the sensor.
        and now im still getting no display out of the MacBook pro.
        its booting up ok ive noticed the keyboard and touchbar is all lighting up.
        it was also showing a display before i replaced the damaged sensor and now i cant get any display out of it.
        02-18-2026, 01:54 PM
      • CapLeaker
        AcuRite 5 in 1 temperature sensor replacement repair
        by CapLeaker
        Got a new victim:
        AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
        A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
        B: stuck at some temperature and maybe updating once in 12 hrs or so.
        Easy solution is to go to AcuRite website and purchase the sensor. Right?...
        04-15-2025, 01:32 PM
      • mitchw
        HP Victus 16 Hall Effect Sensor Problem
        by mitchw
        I am repairing a HP Victus 16 with black screen, blinking screen, etc. Quick googling provided me the answer that the lid detect hall sensor is the issue. Confirmed with disconnecting the IR board (that contains also the hall effect sensor). Laptop itself is just over a year old, but out of warranty.
        Apparently the sensor itself is a TCS40DLR, which fails after just months of use at elevated temperatures.
        Now which one is the best to replace with?
        Some suggested A1126LLHLT-T, but they had to modify the power supply to supply the 3.3V instead of 1.8V, as the sensor wasn't...
        02-12-2026, 11:33 AM
      • Gruvytune
        Projector focus motor sensor
        by Gruvytune
        Hi.
        I have a formovie xming v1 ultra projector.
        The focusing sensor circuit for lens travel position isn't working. It's a new unit and it goes to either end of travel and keeps clicking and won't reverse direction.
        The focusing itself works as long as it operates in the middle range of lens position.
        Here’s the siste summary
        • The Problem: The focus motor will not stop or reverse at the ends of travel. It stalls and clicks violently. This exact behavior happened on the original factory motor before it stripped, and it happens
        05-14-2026, 06:13 AM
      • Boardview and Schematic Bot
        HP Elite Slice G2 + Google Home Hub Elite Slice i5-7500T Specification for Upgrade or Repair
        This specification for the HP Elite Slice G2 + Google Home Hub can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Google Home Hub boardview and Elite Slice G2 + Google Home Hub schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
        09-12-2024, 02:20 PM
