Replacing FZ78 with a solid capacitor
  • blazer249
    • May 2012
    • 6
    Can someone tell me what capacitors can I use for replacing the FZ78 (1000uF 6.3V) on my video card (Forsa Nvidia Geforce 9600GT)?
    Can I replace them with solid capacitors? If yes what models would you recommend?
    Thanks!
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Replacing FZ78 with a solid capacitor
    usually these
    https://www.badcaps.net/store/produc...roducts_id=134
    but tc's out right now
    You should have no problem using lytics though
    these should be fine
    https://www.badcaps.net/store/produc...products_id=43
    though i'm not sure what height/radius those on your card are. I bet they're under 14mm though
    • blazer249
      • May 2012
      • 6
      Hey,
      Thank you for reply but I've said FZ78 (1000uF 6.3V) :p
      Anyway I will wait for others tips.
      • mariushm
        • May 2011
        • 3799
        When you replace solid capacitors (polymers) with electrolytic capacitors, it's often recommended to go up a bit in capacity.
        Also, for the purpose that capacitor was used, going up in capacity a bit won't cause problems. The capacity needs to be just over a minimum value.
        So the 1500uF Rubycon capacitor that he recommended is a very good choice to replace that Sacon FZ.
        If you have to get 1000uF 6.3 here's what will work...
        ...but since you had to be a jerk and didn't enter the country you're in, i can only recommend alternatives for US
        http://search.digikey.com/us/en/prod...710-ND/2207246
        http://www.newark.com/nichicon/rl80j...-3v/dp/79R3100
        • blazer249
          • May 2012
          • 6
          I was thinking to use:
          http://www.ebay.com/itm/5pcs-Solid-C...item231d5391be
          OR this
          http://www.ebay.com/itm/8PCS-6-3V-10...item3a73fc5ebe
          • Scenic
            o.O
            • Sep 2007
            • 2642
            You kinda seem to forget that Sacon FZs are lytics.. :P
            No need for increased capacitance.
            I've attached the datasheet of those junk caps for specs comparison..
            • mariushm
              • May 2011
              • 3799
              No, I knew it's electrolytic. I clarified that through private messages, he contacted me privately.
              When this series was made, the specs were more or less in the polymer/solid capacitors range... nowadays those specs are achievable by some electrolytics, though kinda hard at that height...
              • c_hegge
                • Sep 2009
                • 5219
                If you're gonna use fleabay, only ever use sellers egekecu/PCMCS or Audjade. Many others sell fakes.
                As for your original question, use http://www.ebay.com.au/itm/4-Nichico...item45fdff1b5c to replace the FZs. The slight capacitance drop shouldn't be a problem.
                • selldoor
                  Slow Learner
                  • Dec 2010
                  • 7870
                  "As for your original question, use http://www.ebay.com.au/itm/4-Nichico...item45fdff1b5c to replace the FZs. The slight capacitance drop shouldn't be a problem."
                  If you were going there then they also have 6.3 v1000uF
                  http://www.ebay.com.au/itm/4-Nichico...item43aa87efbe
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    how about measuring the voltage at the caps you wish to replace?then i can suggest something based on my experience.something you can buy at the badcaps store and skip the ebay minefield.
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5042
                      • US
                      you can go up or down in cap within reason with polys. Actually i've seen people who replace 1500 with 330 or 560 16v caps on input vrms before with no problem
                      lytics are another story. Usually same or higher, but within reason
                      • blazer249
                        • May 2012
                        • 6
                        I've replaced the bad capacitors with original Panasonic 1000uf 16V.
                        The big thanks goes to Mariushm.
                        Anyway thanks for the answers people
                        • eccerr0r
                          solid polymer electrolytic capacitor go boom?
                          by eccerr0r
                          Anyone had a solid polymer capacitor fail for whatever reason?
                          How do they fail? Do they explode, go open, short out, ?
                          How about for different reasons: forcing excessive ripple current, overheating, voltage too high, reverse voltage?
                          Just wondering about the causes for a potential shorted solid polymer capacitor... trying to debug a board that has a ~4Ω "short" on a track... it may or may not be a capacitor but was wondering what if it were...
                          07-25-2022, 07:12 AM
                        • chth96
                          by chth96
                          12-22-2023, 04:34 AM
                        • chth96
                          by chth96
                          06-02-2024, 07:31 PM
                        • chth96
                          Is it no harm to replace with capacitor without ripple current rating?
                          by chth96
                          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                          Rubycon YK DataSheet (b...
                          04-19-2024, 05:19 AM
                        • cybernet3000
                          Replacing capacitor in Original Xbox Foxlink Power Supply
                          by cybernet3000
                          Hello all,
                          Got a bit of a noob question - I have an original XBox revision 1.0 with a Foxlink FTPS-0001 Rev B psu. I've already removed the infamous clock capacitor and I'm planning on replacing the caps around the big heat sink (Thanks to everyone who contributed to that massive thread for pointing me in the right direction) but I also noticed on the PSU there's one large cap that seems to be bulging a little. It is cap C19 and from my googling I've been able to determine it's a 2200 uF 10 V capacitor.
                          My questions are:
                          1) Can I just replace this with any...
                          12-01-2021, 12:05 PM
