Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
solid polymer electrolytic capacitor go boom?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8750
    Anyone had a solid polymer capacitor fail for whatever reason?
    How do they fail? Do they explode, go open, short out, ?
    How about for different reasons: forcing excessive ripple current, overheating, voltage too high, reverse voltage?
    Just wondering about the causes for a potential shorted solid polymer capacitor... trying to debug a board that has a ~4Ω "short" on a track... it may or may not be a capacitor but was wondering what if it were...
    • 31498
    Re: solid polymer electrolytic capacitor go boom?
    i watched a video of trying to fuck a bunch of them,
    guy ran them at rated voltage in reverse polarity, they went dead short and just cooked till the leads melted
    that said, there was a guy on another forum a few years ago, re-capped a mobo and put one in backwards, it exploded and put black tar-like goo all over the place.
    so it may depend on the internal design/manufacturer.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8750
      hmm...also curious what happens if they get overheated or overvoltaged. Unlike a "wet" capacitor, they don't have a liquid to boil off so I can't extrapolate a regular aluminum wet capacitor over. Reverse polarity it seems very similar to an aluminum wet, except that one case where the internal resistance got so low the leads were more resistive
        • 31498
        well given my previous post, i suspect they get very hot and then it's down to the specific design whether it stays in one piece or expands and blows the can off
        • AleXis6
          • Feb 2021
          • 69
          • Belarus
          I have several unbranded without any prints can do some experiments.
          what the design do you suggest?
          can try overvoltage or reverse polarity
            • 31498
            put a bowl over it or do it outside.
            you can thank me later!
            • PeteS in CA
              • Aug 2005
              • 3588
              • USA, Unsure of Planet
              I recently saw a polymer cap that had been installed reverse polarity. But for being inside the P/S case it would have launched. The case limited the height the cap attained.
              About 15 years ago (time's fun when you're having flies!) when I was torture testing lytics, I tortured a couple of polymers - probably ran them at ~8X rated ripple current - and the things just kept running. I don't remember whether, after several thousand hours, the things even reached double their initial impedance.
              PeteS in CA
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8750
                looks like reverse polarity has been well tested, and looks like high ripple current are even tolerated...
                wonder about overvoltage and high ambient heat now?
                • PeteS in CA
                  • Aug 2005
                  • 3588
                  Polymers don't have a liquid electrolyte that could cause venting or evaporate.
                  PeteS in CA
                    • 31498
                    you say that, but if the chemical outgasses or there is an air-pocket in the end of the can then expansion can still blow the can off the contents
                    • PeteS in CA
                      • Aug 2005
                      • 3588
                      Since in both polymer and liquid electrolyte capacitors the dielectric is aluminum oxide, not the polymer or liquid electrolyte, are the frequency characteristics for the two types substantially different? I couldn't find charts.
                      PeteS in CA
                      • MORETTIGIAN
                        by MORETTIGIAN
                        Title:
                        Description:
                        Procedure performed:
                        - Removed backplate
                        - Reapplied thermal compound
                        - Reassembled card
                        09-18-2025, 12:14 PM
                      • madscientist750
                        Replacing electrolytic caps by solid caps on old motherboards
                        by madscientist750
                        I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                        I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                        I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                        10-19-2025, 06:10 AM
                      • Perry Babin
                        How do organic polymer caps compare to liquid electrolytic for reliability
                        by Perry Babin
                        I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
                        If not organic polymer, what would be the caps that could take the most abuse?
                        08-18-2025, 04:04 PM
                      • cloudff7
                        Electrolytic capacitor leak in storage?
                        by cloudff7
                        there a risk of this aluminum electrolytic capacitor of electronic device long term storage opening and leaking acid and corroding the PCB board?
                        07-22-2024, 06:27 AM
                      • chth96
                        Should I replace polymer capacitor?
                        by chth96
                        a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                        I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                        Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                        Is this ESR value of polymer capacitor correct?...
                        11-18-2022, 04:22 AM
