High Pressure Sodium Yard light when air conditioner turns light momentarily turns of
This topic has been answered.
    • Jul 2011
    • 6024
    I have had these 70 watt high pressure sodium yard lights for many years now probably at least 15 years or more and there is a protection diode that after several years starts to go bad and when it does this it has momentarily shutting down the light and then a few minutes later it starts working again
    This about the forth time I have fixed this one and you can tell if it the diode or not if it lights up and it only shuts down when the air conditioner turns on then it is the diode
    If it cycling on and off constantly then it is the bulb itself that is the issue
    ( transformer failure )
    This is probably the last time I am going to be able to fix this one because sometimes when it starts up the transformer is vibrating a little bit and this is a sign that it having issues because the other one that I have that is what it started doing after I had replaced the diode the last time so I know I am on borrowed time with this one so it time to look for another one to replace it
    Actually I have some spare parts for them I might just replace the transformer with a old one that still works
    The part number is “K1200E70” Thyristor Surge Device 90 volts @ 20 amp 2-pin TO
    ( when I buy them I buy 10 at a time ) I still have 8 of them left I paid $9.00 plus $3.00 shipping 1-6-20
    I think that they were about to discontinue this part number when I bought the last set of them
    There is also a 220 volt version of this device as well I had bought some by mistake so I have both versions of it and if you are wondering if this version would work for 120 volts it will not become I tried it
    It is a long story about how I figured out when this diode is being to fail this was the very first time that it happened I took the starting board out and looked at it there is not much to it there is a small capacitor a choke and the diode and three wires one goes to the transformer the other goes to neutral side and the other one goes to lamp
    So when I saw this two pin device I googled the part number to find out what it was and what it is used for so I bought some and replaced it and started working like it was new for several years and slowly started turning off sometimes when the air conditioner would turn on every so often this would at the beginning as time goes on it started doing more often then it would basically do this each and every time the air conditioner would turn and if you do not replace it then it would start doing it when the air conditioner turns on and when it turns off as well and act like the bulb was going bad but this is not the case ( because I had let it get to the point that I thought it was the bulb that was causing the issue but after I put a new bulb in it was doing the same exact thing with the new bulb ) this was the first time when I googled the part number
  • Answer selected by sam_sam_sam at 11-30-2024, 08:33 PM.
    sam_sam_sam
    • Jul 2011
    • 6024
    Re: High Pressure Sodium Yard light when air conditioner turns light momentarily turn
    Buying LED modular lighting fixtures are hit and miss type of thing the problem is that you do not know if you are buying good quality ones or crap ones
      • 30937
      sounds like the problem is your AC or wiring,
      obviously there is a volt-drop/brown-out when your AC turns on and it's causing the lamp to restart.
      fix the volt-drop
        • Jul 2011
        • 6024
        fix the volt-drop
        I would agree with you however I have two of them on the same circuit branch and only one of them does this the other one does not do this but I am being to think that it might be that the bulb is being to fail because it starts lighting up the bulb better with the new diode but there is also a capacitor on this board and I going to have tested this capacitor and see if it is working correctly or not
          • 30937
          there is that, but also check the power connections at both ends for loose or corroded terminals
            • Jul 2011
            • 6024
            Will be doing this soon I going to take it down and recheck connections and the like and post the results once I figure out exactly what is the underlying problem with this particular yard light
            • redwire
              • 3900
              I thought it might not be the lamp at all. The air conditioner voltage sag might be restarting it. The sag gets worse with old wiring and breakers, A/C start cap and compressor aging, the daisy-chain or wiring. I wonder if you could look at MIN/MAX voltage with a multimeter and see how much mains sags when the compressor starts? Or if these are all on one phase, is this 120V or 220V lamp and A/C?
              K1200 is a Sidactor or Diac as I call them, triggers at 110-125V, 120V nominal. It is moreso a trigger diode to start the lamp, not a protection diode.
              How it works is, when the voltage across it is high enough say >120Vpk, the Sidac avalanches and dumps the start cap into an inductor (or a 2-turn tap on the main ballast inductor) to make the 3-4kV spike it takes to start a HPS lamp.
              Once the lamp is running, there ends up being insufficient voltage on the start cap (due to voltage drop in the ballast inductor) to avalanche the Sidac, and it just sits there off.
              They are not the strongest part, I would guess they can age and their firing voltage goes wonky but it might also be the lamp voltage (impedance) going high with age, or the start cap maybe.
                • Jul 2011
                • 6024
                Thank you for the explanation of how this device works that helps a lot for troubleshooting issues with this particular yard light
                I was thinking about the start cap might be some of the issues I have to install a different yard from what is there currently and I can dig deeper into what might be the issue because the other high pressure sodium yard light does not have this issue
                Also how would I look up the part number for the start cap on this starter board
                  • 30937
                  why not swap parts between the fittings to see which has an effect?
                    • Jul 2011
                    • 6024
                    I would do this recommendation however keep in mind that the spare parts are also very old as well this is the reason I asked about how you find the start up capacitor
                    If I remember correctly the starting board that is in there now is a used part because the one that was in there had some kind-a issue and burned up the board traces in one section that it was not easily repaired and sense I had a spare one I just repaired it and I was using for last couple of years now
                    • redwire
                      • 3900
                      If the start cap fails low value, I think it will just struggle or fail to start.
                      Most are like motor caps: film caps but I do see some oil-filled ones out there. But these ballasts run hot and might be hard on them.
                      I read "High pressure sodium lamps require approximately one minute to cool before restriking." I doubt it gets this with the A/C causing false restarts?
                      If the ballast is failing, it gives the tube excessive current so short life and blackened ends I think.
                      https://hid.venturelighting.com/Tech...eshooting.html
                      Newer ballasts seem to use an ignitor module: https://cdn.badcaps-static.com/pdfs/...4f590994c8.pdf but no idea what's inside, they are potted.
                        • Jul 2011
                        • 6024
                        I will post a picture of the inside of the starting board when I take it down from where it is now
                          • Jul 2011
                          • 6024
                          I would like to know what is the best way to check the start cap for this high pressure sodium lighting fixture ( ESR meter or UF meter or something else )
                          The issue is that there two of these light fixtures on the same electrical circuit on the same phase one works the way it should and it is the new one out of the two ( I also have a third one that does the same exact thing but it does even more so and not being used as of now )
                          I really would like to fix both of them that have this problem issue so any help would be greatly appreciated plus I think this might improve my understanding and troubleshooting skills
                          I have switched around the high pressure sodium light bulbs and in the newer one it works normally but the one that the issue still has the issue so I do not think it is the light bulb
                            • 30937
                            testing big can-caps for motors or lights can be tricky,
                            some have a built-in or soldered on discharge resistor
                              • Jul 2011
                              • 6024
                              https://www.ebay.com/itm/256137223968
                              Here is the replacement that has the ballast transform and igniter
                                • Jul 2011
                                • 6024
                                This will allow me to get this yard light working correctly again and be able to figure out what is exactly what wrong with the lighting fixture and repair hopefully anyway
                                  • Jul 2011
                                  • 6024
                                  Here is a pictures of the ignitor board and capacitor that are on this board
                                  I have never looked up these type of capacitors can you please tell how I would find them on Digit-key so I can order some of them and see if this helps it works correctly again
                                  This is a newer looking board that I got from the place that I used to work at before they closed and a few of these light fixtures were doing the same thing every so often cycling when something would turn on in the building and it was also doing this at my house as well
                                  Remember that these light fixtures are probably about 15 years old by now
                                  • Per Hansson
                                    • Jul 2005
                                    • 5895
                                    • Sweden
                                    Have you measured the capacitor and made sure it's bad?
                                    If so maybe this thread can be useful:
                                    https://www.badcaps.net/forum/showth...415#post922415
                                      • Jul 2011
                                      • 6024
                                      It measures around 0.31 but I am not sure that it good with a load on it so I would rather just replace them to rule out the possibility that this might be the issue
                                      This link does not work anymore
                                      https://www.codico.com/en/News/long-...from-kemet.htm
                                        • Jul 2011
                                        • 6024
                                        Would this be a good replacement capacitor for this high pressure sodium light fixture that I have been talking about in the post above #16
                                        Digi-Key Part Number
                                        495-76808-ND
                                        Manufacturer
                                        EPCOS - TDK Electronics
                                        Manufacturer Product Number
                                        B32922C3333K000
                                        Description
                                        CAP FILM 0.033UF 10% 630VDC RAD
                                        Series
                                        B3292*C/D - X2 Standard
                                        https://www.digikey.com/en/products/...33K000/3492448
                                        • redwire
                                          • 3900
                                          No. It's the wrong value at 0.033uF and your pic and measurements are 0.33uF or 10x bigger. The lead spacing I see 22.5mm for the old part and PC board, or it will accomodate 15mm.
                                          B32922C3334M000
                                          495-2321-ND
                                          CAP FILM 0.33uF 20% 630VDC X2 305VAC LS=15mm.
                                          But I think replacing the cap will change nothing because the lamp starts OK and its value is still in spec.
                                          You have to replace the trigger Sidactor D1. Board says "G080xx" what part number is there.
                                          Digi-Key still has the K1200 in many different packages too.
                                          • Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                            by Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                            03-15-2024, 09:37 AM
                                          • www
                                            LG L192WS-BN backlight turns off after 1 second
                                            by www
                                            I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                            I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                            03-24-2024, 05:26 PM
                                          • andrhouseolly
                                            Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                                            by andrhouseolly
                                            Hi.
                                            I kindly ask you to help me solve the problem.
                                            Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                                            The board turns on, there is no image.
                                            Read more. When the power supply is connected, the front panel indicators light up briefly.
                                            When you press the power button, the button indicator lights up. The board works
                                            there is no image, there is no matrix initialization, there is no image on HDMI.
                                            When turned on, the fans do not spin, but when they warm up they start spinning.
                                            When you turn off the button, the fans spin up to full speed for a short...
                                            05-11-2024, 03:14 PM
                                          • Egidio85
                                            Samsung UE55F8000SZ Turns on and off immediately
                                            by Egidio85
                                            good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                                            This defect happens continuously, hearing the classic click of the relay every time.
                                            Power supply board BN44-00636B
                                            disconnecting the mains and lamps from the power board always causes the same problem.
                                            Is it normal that without anything connected this power supply turns on and off cyclically?
                                            any suggestions on what to check?
                                            thanks in advance
                                            03-11-2025, 12:45 PM
                                          • mostachio
                                            Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
                                            by mostachio
                                            Hi Badcaps,
                                            I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
                                            TV Details:
                                            Model # - TH-65DX700Z
                                            Symptoms:
                                            The television turns on and displays a picture then makes a clicking sound and turns off.
                                            I haven't opened it up yet but...
                                            09-04-2024, 02:32 AM
