High Pressure Sodium Yard light when air conditioner turns light momentarily turns of
This topic has been answered.
    • 31262
    Re: High Pressure Sodium Yard light when air conditioner turns light momentarily turn
    these look well designed - but they are directional - ok for high-bay lamps but not for side-reflector housings
    https://www.youtube.com/watch?v=IjCYtJ9k2Y4
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      I've got 2 ceiling light fixtures that are identical housing 2 bulbs each. Now in one light fixture one certain A19 holder eats LED bulbs for breakfast. I put a old CCFL back in and no problems at all. Go figure.
      I had the same problem with the fart fan over my shower. LED bulb, lucky to get a week out of it. CFL or Incandescent, no problems.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
        • Jul 2011
        • 6070
        Buying LED modular lighting fixtures are hit and miss type of thing the problem is that you do not know if you are buying good quality ones or crap ones
          • Jul 2011
          • 6070
          Well just recently I had another issue with my high pressure sodium light by the street this one has worked for several years with out any issues until it just would not turn on
          You can hear the transformer humming a little bit but it was not lighting up at all at first I thought it was a bad transformer but I put a different one in there and it still did not work transformer still humming a little bit so I changed the circuit board that fires the light bulb and that did not help either it turns out that the bulb had some type of issue that I had not seen before because I put bulb in my other fixture and it would flicker a few times and has a strange blue color and then flicker again a few times and even in this fixture the transformer was humming a little where as the original bulb works with out the transformer humming
          I just replaced the transformer and the circuit board that fires a metal halide bulb that is 100 watt version only because I had a new transformer and circuit board for I just need a bulb for it
            • 31262
            well i just replaced the led lamp in my hallway for the second time this year.
            plastic, aluminium, tin, copper etc to the landfill and it cost 3x the price of an incan.
            but i'm saving the enviroment if you believe the fucking politicians!
              • Jul 2011
              • 6070
              I have come to the conclusion that the high pressure sodium yard light that was cycling when the air conditioning would turn on well turned out that there must be something wrong with the transformer because I found the other new transformer with the new ballast ( in one of the storage containers ) and used an old bulb that the fixture would cycle of when the air conditioner would come on it does not do this now not only that but the bulb gets bright faster than the old transformer and ballast plus if you unplug it when it gets to full brightness then wait a minute and plug it back into power again it gets bright very fast the other on would flicker a bunch of times and maybe restart again
              I know that this is an old post but because of me getting home when it is dark again I need to get this light fixture working again
              I had time to find it because I been off from work since Thursday for thanksgiving and will go back to work Monday morning again
              One note the florescent light that has the electronic ballast the bulb went out twice in very short time so who knows what is causing this situation I sure would like to know because I have two of them that are exactly the same one of them work great the other one is a problem child I will have to investigate this more thoroughly when I put the high pressure sodium light fixture back out there and take the fluorescent light fixture back off again
                • Jul 2011
                • 6070
                Well I finally put the light fixture together but decided not use the low profile yard light because it close to the street and other one that is close to the street is the same style so they complement each other plus the tall version has the external photo eye that is electronic version I just have to replace the light pole that I have the fixture because it has rotated away and I do not want to have to do this twice
                  • Jul 2011
                  • 6070
                  I took a look at florescent​ controller board the main filtering capacitor had popped up the top of the capacitor I will have to see if I have a 47uf@250 volt one that will fit in the space that is a lotted for the capacitor in question other wise I will have to purchase some when I place a Dig-key order for some other parts for other things that need to be repaired
                    • Jul 2011
                    • 6070
                    This project was a success I now have a very good working high pressure sodium yard light that I rebuilt so hopefully it will last for at another 5 years or more I hope it will
                      • Jul 2011
                      • 6070
                      I took a look at florescent controller board the main filtering capacitor had popped up the top of the capacitor I will have to see if I have a 47uf@250 volt one that will fit in the space that is a lotted for the capacitor in question other wise I will have to purchase some when I place a Dig-key order for some other parts for other things that need to be repaired
                      Well I installed the new capacitor and there was a pop noise and it blew the main fuse on the board it going to be used as parts for the remaining board that is in service now
                      Not worth the time to investigating what has happened to it no real obvious damage that could see I might look at it again with a magnifying glass and see if I find anything doing this
                      • spleenharvester
                        Whirlpool PACF212HP W portable air conditioner, upper fan only turns slowly.
                        by spleenharvester
                        I just acquired this portable aircon, history unknown. Its behaviour is quite strange:
                        • When turned on and placed into cooling mode, the upper fan (cold air out) just spins slowly. The compressor and lower fan do not run.
                        • If the device is then placed into heating mode and then back into cooling mode, the lower fan and compressor kick in and start cooling, but the upper fan still only spins slowly.
                        • If the device is placed into fan-only mode, the upper fan does not respond to low/medium/high speed toggles - just keeps running slowly.
                        • Display and buttons all behave normally aside from the
                        06-27-2025, 07:49 PM
                      • Stephen
                        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                        by Stephen
                        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                        03-15-2024, 09:37 AM
                      • www
                        LG L192WS-BN backlight turns off after 1 second
                        by www
                        I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                        I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                        03-24-2024, 05:26 PM
                      • zklgfs
                        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                        by zklgfs
                        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                        08-11-2025, 02:14 PM
                      • andrhouseolly
                        Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                        by andrhouseolly
                        Hi.
                        I kindly ask you to help me solve the problem.
                        Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                        The board turns on, there is no image.
                        Read more. When the power supply is connected, the front panel indicators light up briefly.
                        When you press the power button, the button indicator lights up. The board works
                        there is no image, there is no matrix initialization, there is no image on HDMI.
                        When turned on, the fans do not spin, but when they warm up they start spinning.
                        When you turn off the button, the fans spin up to full speed for a short...
                        05-11-2024, 03:14 PM
