ANATEK Blue ESR Meter REV 1 PCB first build. Tips and component upgrade suggestions..
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: ANATEK Blue ESR Meter REV 1 PCB first build. Tips and component upgrade suggestio
    I just found this today..
    Brand new [released Aug 2010] LCR meter from BK that does ESR down to 4 decimal places.
    - - - Costs $299 though.
    https://www.badcaps.net/forum/showthread.php?t=12509
    Mann-Made Global Warming.
    - Dr Seuss
    • Agent24
      I see dead caps
      • Oct 2007
      • 4953
      • New Zealand
      I kinda hate to say it... but some of those ESR meters that you-know-who posted about claimed to measure values quite low.
      Do you think any of them could actually come through with that claim?
      -David VanHorn
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        I scarcely remember any good below 1 ohm except maybe some cheap Chinese models that I don't think would live up to the claims.
        Of course if I could read Russian that might be different.
        - Dr Seuss
        • Agent24
          I see dead caps
          • Oct 2007
          • 4953
          • New Zealand
          http://people.overclockers.ru/TerAbit/record7 mentions 0.0001 Ohm, but I think that is
          just accuracy.
          Can't see a display either, possibly he is using the oscilloscope to provide output.
          The rest of the designs don't seem any better than Bob's meter either.
          -David VanHorn
          • steve2
            • 121
            I just got my Blue esr kit today. Put it together in a couple hours while watching tv and it works great. I also had the 4 metal clips left over that I couldn't see any info for, so I was glad to look here and find out they are for holding 2 aa batteries. I just completely recapped a MB MS-7207 last week and saved all the old caps to test when the esr meter came. Only had one that read bad and sadly, the MB is the same as before. Boots perfect every other time. I have 2 of these emachines here doing the exact same thing. Every other boot is fine. Very strange problem, but thats a different thread.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4953
              • New Zealand
              #26
              Maybe it's some weird BIOS\incompatibility bug rather than a hardware problem.
              I had weird issues after upgrading a Duron 1.3ghz to an Athlon XP 2600+... It turned out my BIOS didn't support the new CPU properly and half the time it wouldn't POST and would do the RAM failed beep code.
              After upgrading BIOS to one that supported my CPU it worked perfectly.
              -David VanHorn
              • steve2
                • 121
                #27
                These both had the bios updated at the MSI site. Really can't remember if I did that before or after the problem started. Maybe I will look for the original bios and try it.
                • Freezer
                  • Jun 2010
                  • 124
                  #28
                  Recently I ordered a Blue ESR Meter kit and assembled it. Here's my story of assembly and testing.
                  I ordered directly from Anatek instead of one of the distributors. It took me about 1 week to assemble, which is a lot longer than most. The main reason it took so long is I'd come home after work, solder in about 5 components, then put it on hold until the next day (got to spend time with family not "playing" in the garage).
                  My kit did come with 4 extra 2.2 kohm resistors, hopefully this doesn't mean another kit was missing these 4 resistors. The only real problem I ran into was a one wrong resistor. I was missing a 220 ohm resistor and in it's place had an extra 180 ohm resistor. I both tested the extra resistor on my multimeter and used the color codes, it was clearly wrong. So I emailed Anatek and they quickly mailed me out the correct resistor.
                  I also had a little problem with the trim pot in VR2. The legs of the trim pot did not slide easily into the holes on the PCB. I probably could have pushed harder and forced it in, but I didn't want to break anything. So instead I used my Dremel to ever so slightly grind the sides of the legs down. After this the trim pot slid right into place.
                  I finished assembly and calibration last night. I've already found a bad capacitor from an LCD monitor. I'm looking forward to using this on many future projects.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    #29
                    Coming back to the high resolution meter thing - i may design and build a little something that connects to two cheapo DMMs if there's enough interest. Like Bob said, to measure milliohms accurately 4-wire measurements are a must.
                    Sure, it won't be as easy to read as you need to apply Ohm's law, but i don't want to use a microcontroller because i have no clue on how to program one.
                    A working TV? How boring!
                    • Bob Parker
                      Technician
                      • Feb 2007
                      • 182
                      Well done!
                      I hope it will pay you back in time it saves you.
                      It is a good shrubbery. I like the laurels particularly...
                      • Longbow
                        • Jun 2011
                        • 623
                        What would be the benefit of adding high resolution readings to the Blue Meter? For example, I just measured a Panasonic 47 uf cap with the Blue Meter and it displayed .22. What advantage would be gained if the meter read .2237? The best additional bucks you can spend on this excellent meter are for a nice set of needle probes.
                        Is it plugged in?
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Mobo caps in the range of .009-.005 ESR are now fairly common.
                          A meter with only two decimal resolution might read a good one as 0.00 which indicates a shorted cap.
                          [Especially when you consider meter tolerance and resolution.]
                          Now lets say you have a cap that is supposed to be .007 ohms.
                          That 2 digit meter is at .01 or bouncing between .00 and .01.
                          Is it good or at .015 ohms which is over 2x the rating?
                          You aren't going to get to 4 decimal places accurately with hand-held equipment.
                          [I used to measure thermocouples used in NUC plant temp detectors to calibrate the instruments and they were 4+ decimal place resistance measurements. It's a PITA.]
                          - Dr Seuss
                          • Bob Parker
                            Technician
                            • Feb 2007
                            • 182
                            To be honest, I designed what's now the Blue ESR meter for the general electronic servicing of TVs and VCRs etc I was doing at the time (1995) when nearly all the electrolytic caps causing problems were less than 1,000uF. I figured that a two digit display going down to 0.01 ohms should be adequate for checking the occasional linear power supply filter capacitor, though with very poor resolution. For that reason I'm the first to agree that it's not great for checking motherboards where you often find half a dozen low ESR caps paralleled. I'm giving this some thought in between moving houses.....
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              I'm aware of that. [Read some of your articles.]
                              Was not critizing the device you built.
                              It's usefulness far exceeds what you intended it for.
                              I think it may rival sliced bread... [Greatest thing since.]
                              I was just answering the previous question by showing examples where one more digit East of the decimal would be usefull to us low ESR folks.
                              - Dr Seuss
                              • Bob Parker
                                Technician
                                • Feb 2007
                                • 182
                                Thanks! I'm 100% agreeing with you that its limited resolution at the bottom of the lowest range isn't great for checking motherboards. I just thought I should explain to others here who don't know its background, why it's like that.
                                I'll keep thinking about it down here where it's winter and hard to get motivated....
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4953
                                  • New Zealand
                                  #36
                                  Wonder if it wouldn't be easier just to make an add-on circuit for your ESR meter that works as a kind of x10\x100 deal, changing your 0.007 ohm reading to .07 or even .7x ?
                                  Would be useful I guess as a lot of people already have your meter and probably don't want to have to get a whole new kit.
                                  Maybe you could even make it dual-purpose with an optional display for a standalone meter or just an output to the existing meter, selectable by a jumper on the board somewhere.
                                  -David VanHorn
                                  • cmj21973
                                    • 267
                                    My Blue ESR meter and Blue Ring tester would gladly welcome a new Blue kit for low ESR mobo caps.
                                    • Bob Parker
                                      Technician
                                      • Feb 2007
                                      • 182
                                      Sorry to be a disappointment, but it's not as easy as it sounds. If you multiply its sensitivity by 10, you multiply all the problems by 10 as well. Problems like varying readings caused by lead inductance, contact resistance and noise pickup. It also becomes even harder to protect such a sensitive device from 100uF capacitors charged to 330V as happens so often.
                                      To measure down to single milliohms would require a 4-wire measurement at the very least. I'm hoping that when I've finally moved to another house 400km away and get set up again properly, I'll be able to develop something. Maybe a simpler gadget which measures from 0 to 99 milliohms (0-0.099 ohms). Above that figure, the current meter should be quite adequate.
                                      • helion
                                        • Jul 2011
                                        • 10
                                        • India
                                        #39
                                        Originally posted by MegaOne302
                                        I've finally bought my first ESR meter kit. Wish me luck.
                                        Parts
                                        Front
                                        Back reads "Bob... Dec '07" lol
                                        Please note PCB images are for my reference.
                                        Originally posted by Bob Parker
                                        Good idea. There are better components available now, than when I designed the original meter. I'll need to put some serious thought into what would be the simplest & cheapest way to measure single milli-ohms, and how to display them. Thanks for giving me some possibilities to contemplate.
                                        I wonder if it is possible to integrate a lot many functions into one hand held device, since there are already small enough individual testing devices such as those as Peak.
                                        • chth96
                                          Is it possible to test small ceramic disc capacitor with analogue meter?
                                          by chth96
                                          I read EBOOK of Testing Electronic Component and found that
                                          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                          Is it really possible to test small ceramic disc capacitor with analogue...
                                          03-09-2024, 10:03 PM
                                          Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                          by sam_sam_sam
                                          I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                          I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                          12-31-2023, 06:04 AM
                                        • jorpec
                                          Changing the scale of an analog meter
                                          by jorpec
                                          Hi
                                          I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                          I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                          Thnaks
                                          01-23-2023, 10:37 AM
                                          How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                          by sam_sam_sam
                                          About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                          Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                          12-14-2023, 07:45 PM
                                        • novice1
                                          Acer Aspire E5-574G - Not Powering On
                                          by novice1
                                          Laptop name Acer Aspire E5-574G. Processor = i7-6500u. GPU = NVIDIA GEFORCE 940M. Motherboard Model = DA0ZRWMB6G0
                                          This laptop was not powering on at all so I started investigating. The blue light would come on for a second, and then disappear. Fan would sometimes turn on for a second and then shut off immediately, and at other times would not turn on at all.
                                          To start with, about 3 months ago I had no clue about soldering, motherboard schematics, board view, and then I stumbled about this forum and other stuff online. I have never done any of those before. But to ask...
                                          11-03-2023, 05:53 PM
