B&K releases new ESR meter.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Yes it's expensive and so here mostly for drool factor..
    In August 2010 B&K Precision released two new LCR meters. - The 878B and 879B
    http://news.bkprecision.com/2010/08/...cr-meters.html
    The 878B doesn't do ESR.
    - But -
    The 879B measures ESR down to 4 decimal places and the intro price is $299.
    - That's a bunch but it IS around $200 less than their previous model that only did ESR down to 3 decimal places.
    http://www.bkprecision.com/products/...asurement.html
    Specs:
    UPDATE YOUR CHRISTMAS LISTS QUICK!!
    - Or win the lotto...
    Many places including Digikey and Mouser have them listed but no stock.
    As these appear to be brand new models my guess is they simply haven't received their initial stocking orders yet.
    Mann-Made Global Warming.
    - Dr Seuss
  • Agent24
    I see dead caps
    • Oct 2007
    • 4951
    • New Zealand
    Re: B&K releases new ESR meter.
    Looks very nice and the price isn't too bad either. Although still too expensive for me...
    -David VanHorn
    • mockingbird
      • Dec 2008
      • 5484
      THIS is what I would buy if I was buying an ESR meter. I would like to see the innards of this thing.
      • Krankshaft
        • Jan 2007
        • 2328
        An Extech LCR in the same price range gets taken apart:
        http://www.youtube.com/watch?v=zEA5MfllPdg
        and the review:
        I think the price point is right on I paid about that much for my 87-5. LCR meters are a real niche market so it seems prices are locked at 200 dollars minimum.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          and the review:
          What I don't like about that one is that it does not have a 100kHz test frequency.
          For most low ESR caps 100kHz is the standard used in data sheets.
          If you test ESR at other than 100kHz then you have to do the math using the conversion factors given [hopefully] in the cap's data sheet.
          IOW the numbers on the meter screen don't mean anything in the data sheet without breaking out the calculator - for EVERY cap you measure.
          That would get old REALLY quick around here.
          The Bob Parker based meters all use 100kHz for the test frequency so it's not like it's difficult to achieve.
          IMHO, here in 2010, if an LCR meter doesn't have a 100kHz test signal setting it should be grouped with the cheap Chinese junk meters.
          - But that's just this Grump's opinion.
          - Dr Seuss
          • Agent24
            I see dead caps
            • Oct 2007
            • 4951
            • New Zealand
            Why do they test at a different frequency in the first place?
            -David VanHorn
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Not every cap goes on a mobo or in a PSU.
              Low ESR caps use 100kHz because it's mid/ball park what SMP noise is.
              Other applications and other kinds of caps see other frequency ranges.
              I'm not an audiophool so I'm not sure, but given the audible range is around 20Hz-20kHz I imagine they'd want to know ESR at like 10kHz if it has to do with speakers.
              Caps that aren't intended for SMPS use at all are often spec'ed at 120Hz and although they [usually] don't list ESR in data sheets it's still a valid check to test the cap.
              - Dr Seuss
              • Krankshaft
                • Jan 2007
                • 2328
                Dave at the EEVblog just released a video of the BK 879B LCR meter and cracked it open. It has a very nice SMD design.
                Unfortunately at least on his unit the MIN / MAX / AVERAGE record function wouldn't work.
                http://www.youtube.com/watch?v=H4TP0i917Ro&feature=sub
                • japlytic
                  • Oct 2005
                  • 2086
                  Four decimal places?
                  I think that would be useful for motherboard capacitors (especially polymer) and very high value units e.g. beercans.
                  • smason
                    • 1652
                    Crikey! That was quite a review.
                    • chth96
                      Is it possible to test small ceramic disc capacitor with analogue meter?
                      by chth96
                      I read EBOOK of Testing Electronic Component and found that
                      "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                      Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                      It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                      Is it really possible to test small ceramic disc capacitor with analogue...
                      03-09-2024, 10:03 PM
                      Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                      by sam_sam_sam
                      I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                      I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                      12-31-2023, 06:04 AM
                    • jorpec
                      Changing the scale of an analog meter
                      by jorpec
                      Hi
                      I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                      I wonder how i can accomplish this so the meter would be precise at any temperature ?
                      Thnaks
                      01-23-2023, 10:37 AM
                    • Stephan Mathers
                      EDMI ATLAS MK10 Electronic Meter Discussion
                      by Stephan Mathers
                      Greetings, new guy here but always interested in the crazy universe of modding
                      We just finished construction of around 25 vacation houses, all inside the same private area.
                      Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                      The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                      Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                      05-20-2025, 09:09 AM
                    • eccerr0r
                      lowest current galvanometer/analog meter (passively powered!)
                      by eccerr0r
                      Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                      On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                      04-16-2025, 12:41 AM
