ANATEK Blue ESR Meter REV 1 PCB first build. Tips and component upgrade suggestions..
    Re: ANATEK Blue ESR Meter REV 1 PCB first build. Tips and component upgrade suggestio
    I just found this today..
    Brand new [released Aug 2010] LCR meter from BK that does ESR down to 4 decimal places.
    - - - Costs $299 though.
    https://www.badcaps.net/forum/showthread.php?t=12509
    Mann-Made Global Warming.
    - Dr Seuss
      I kinda hate to say it... but some of those ESR meters that you-know-who posted about claimed to measure values quite low.
      Do you think any of them could actually come through with that claim?
      -David VanHorn
        I scarcely remember any good below 1 ohm except maybe some cheap Chinese models that I don't think would live up to the claims.
        Of course if I could read Russian that might be different.
        - Dr Seuss
          http://people.overclockers.ru/TerAbit/record7 mentions 0.0001 Ohm, but I think that is
          just accuracy.
          Can't see a display either, possibly he is using the oscilloscope to provide output.
          The rest of the designs don't seem any better than Bob's meter either.
          -David VanHorn
            I just got my Blue esr kit today. Put it together in a couple hours while watching tv and it works great. I also had the 4 metal clips left over that I couldn't see any info for, so I was glad to look here and find out they are for holding 2 aa batteries. I just completely recapped a MB MS-7207 last week and saved all the old caps to test when the esr meter came. Only had one that read bad and sadly, the MB is the same as before. Boots perfect every other time. I have 2 of these emachines here doing the exact same thing. Every other boot is fine. Very strange problem, but thats a different thread.
              Maybe it's some weird BIOS\incompatibility bug rather than a hardware problem.
              I had weird issues after upgrading a Duron 1.3ghz to an Athlon XP 2600+... It turned out my BIOS didn't support the new CPU properly and half the time it wouldn't POST and would do the RAM failed beep code.
              After upgrading BIOS to one that supported my CPU it worked perfectly.
              -David VanHorn
                These both had the bios updated at the MSI site. Really can't remember if I did that before or after the problem started. Maybe I will look for the original bios and try it.
                  Recently I ordered a Blue ESR Meter kit and assembled it. Here's my story of assembly and testing.
                  I ordered directly from Anatek instead of one of the distributors. It took me about 1 week to assemble, which is a lot longer than most. The main reason it took so long is I'd come home after work, solder in about 5 components, then put it on hold until the next day (got to spend time with family not "playing" in the garage).
                  My kit did come with 4 extra 2.2 kohm resistors, hopefully this doesn't mean another kit was missing these 4 resistors. The only real problem I ran into was a one wrong resistor. I was missing a 220 ohm resistor and in it's place had an extra 180 ohm resistor. I both tested the extra resistor on my multimeter and used the color codes, it was clearly wrong. So I emailed Anatek and they quickly mailed me out the correct resistor.
                  I also had a little problem with the trim pot in VR2. The legs of the trim pot did not slide easily into the holes on the PCB. I probably could have pushed harder and forced it in, but I didn't want to break anything. So instead I used my Dremel to ever so slightly grind the sides of the legs down. After this the trim pot slid right into place.
                  I finished assembly and calibration last night. I've already found a bad capacitor from an LCD monitor. I'm looking forward to using this on many future projects.
                    Coming back to the high resolution meter thing - i may design and build a little something that connects to two cheapo DMMs if there's enough interest. Like Bob said, to measure milliohms accurately 4-wire measurements are a must.
                    Sure, it won't be as easy to read as you need to apply Ohm's law, but i don't want to use a microcontroller because i have no clue on how to program one.
                    A working TV? How boring!
                      Well done!
                      I hope it will pay you back in time it saves you.
                      It is a good shrubbery. I like the laurels particularly...
                        What would be the benefit of adding high resolution readings to the Blue Meter? For example, I just measured a Panasonic 47 uf cap with the Blue Meter and it displayed .22. What advantage would be gained if the meter read .2237? The best additional bucks you can spend on this excellent meter are for a nice set of needle probes.
                        Is it plugged in?
                          Mobo caps in the range of .009-.005 ESR are now fairly common.
                          A meter with only two decimal resolution might read a good one as 0.00 which indicates a shorted cap.
                          [Especially when you consider meter tolerance and resolution.]
                          Now lets say you have a cap that is supposed to be .007 ohms.
                          That 2 digit meter is at .01 or bouncing between .00 and .01.
                          Is it good or at .015 ohms which is over 2x the rating?
                          You aren't going to get to 4 decimal places accurately with hand-held equipment.
                          [I used to measure thermocouples used in NUC plant temp detectors to calibrate the instruments and they were 4+ decimal place resistance measurements. It's a PITA.]
                          - Dr Seuss
                            To be honest, I designed what's now the Blue ESR meter for the general electronic servicing of TVs and VCRs etc I was doing at the time (1995) when nearly all the electrolytic caps causing problems were less than 1,000uF. I figured that a two digit display going down to 0.01 ohms should be adequate for checking the occasional linear power supply filter capacitor, though with very poor resolution. For that reason I'm the first to agree that it's not great for checking motherboards where you often find half a dozen low ESR caps paralleled. I'm giving this some thought in between moving houses.....
                              I'm aware of that. [Read some of your articles.]
                              Was not critizing the device you built.
                              It's usefulness far exceeds what you intended it for.
                              I think it may rival sliced bread... [Greatest thing since.]
                              I was just answering the previous question by showing examples where one more digit East of the decimal would be usefull to us low ESR folks.
                              - Dr Seuss
                                Thanks! I'm 100% agreeing with you that its limited resolution at the bottom of the lowest range isn't great for checking motherboards. I just thought I should explain to others here who don't know its background, why it's like that.
                                I'll keep thinking about it down here where it's winter and hard to get motivated....
                                  Wonder if it wouldn't be easier just to make an add-on circuit for your ESR meter that works as a kind of x10\x100 deal, changing your 0.007 ohm reading to .07 or even .7x ?
                                  Would be useful I guess as a lot of people already have your meter and probably don't want to have to get a whole new kit.
                                  Maybe you could even make it dual-purpose with an optional display for a standalone meter or just an output to the existing meter, selectable by a jumper on the board somewhere.
                                  -David VanHorn
                                    My Blue ESR meter and Blue Ring tester would gladly welcome a new Blue kit for low ESR mobo caps.
                                      Sorry to be a disappointment, but it's not as easy as it sounds. If you multiply its sensitivity by 10, you multiply all the problems by 10 as well. Problems like varying readings caused by lead inductance, contact resistance and noise pickup. It also becomes even harder to protect such a sensitive device from 100uF capacitors charged to 330V as happens so often.
                                      To measure down to single milliohms would require a 4-wire measurement at the very least. I'm hoping that when I've finally moved to another house 400km away and get set up again properly, I'll be able to develop something. Maybe a simpler gadget which measures from 0 to 99 milliohms (0-0.099 ohms). Above that figure, the current meter should be quite adequate.
                                        Originally posted by MegaOne302 View Post
                                        I've finally bought my first ESR meter kit. Wish me luck.
                                        Parts
                                        Front
                                        Back reads "Bob... Dec '07" lol
                                        Please note PCB images are for my reference.
                                        Originally posted by Bob Parker View Post
                                        Good idea. There are better components available now, than when I designed the original meter. I'll need to put some serious thought into what would be the simplest & cheapest way to measure single milli-ohms, and how to display them. Thanks for giving me some possibilities to contemplate.
                                        I wonder if it is possible to integrate a lot many functions into one hand held device, since there are already small enough individual testing devices such as those as Peak.
