Android Oscilloscopes , Cheap and good enough to test PSU ?
  • jarvis7
    • Feb 2015
    • 52
    • asasf
    Hello ,
    I found some of these videos on youtube , it seems like a super cheap way of making oscilloscope , with some old spare android device
    https://www.youtube.com/watch?v=xFA9CdusDWg
    https://retronics.wordpress.com/2012...-oscilloscope/
    i know they won't be super accurate but are these types atleast good enough to check Spikes and Ripple output of desktop PSUs to determine whether PSU is outputting Safe and stable voltage quality reliably ?
    any experiences, thoughts , comments ?
    Thank you ..
    • 31196
    Re: Android Oscilloscopes , Cheap and good enough to test PSU ?
    it's not about accuracy for most tests, it's about being fast enough.
    i would say you need 200-500KHz - preferably 500+ to check for ripple on a psu, because most run at 60-80KHz and you need 5x that to get a good capture.
    so it's going to depend on the maximum bandwidth of the phone you use.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Agreed. In general these "sound card oscilloscopes" are only good for ... sound.
      Therefore, good only for debugging audio problems, and possibly linear PSUs.
      Ugh, I can't believe that guy in the video that got rid of their bench scope "for bench space," must not be serious of an experimenter or assumes there will be an IC that will handle all the high frequency stuff...
      • clearchris
        • Dec 2013
        • 687
        When you need to get rid of your scope for "bench space" you need a bigger bench.
        • dmill89
          • Dec 2011
          • 2534
          ^This,
          I see the OP doesn't list a location, if you're in the US <$50 analogue scopes are pretty easy to come by (especially brands other than Tektronix and HP, you'll often need to add you're own probe, but the <$10 eBay/Amazon probes work fine), most you'll find in this price range are 10-30mhz, but that is more than enough for PSUs.
          There are also the $20-30 kits on eBay/Amazon/etc., though they're only rated for 200Khz (and often don't perfrom well above 100Khz) so still definitely on the low side for PSU ripple, but better than a sound-card based scope (most phone sound cards aren't going to handle anything above 20 KHz).
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            I was thinking about selling my old 20MHz scope, because I'm out of bench space
            ( but I can say that because I have two other 300MHz scopes...
            Alas, this 20MHz scope can run on 12VDC whereas the two Teks cannot without an external inverter...)
            • jarvis7
              • Feb 2015
              • 52
              • asasf
              So , not useful at all then for PSU..
              Thank you very much Stj , eccerr0r , clearchris , dmill89 sir
              • chth96
                How Can I test PWM DM0365R?
                by chth96
                Hello
                I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                06-18-2025, 04:14 PM
              • khelane
                test active pfc power with lamp test
                by khelane
                Hello
                I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                Is there a way...
                06-03-2025, 01:00 AM
              • Grut
                JVC LT-39CA120 - Vestel 17MB171 - Android boot loop
                by Grut
                My JVC (Vestel) LED TV is stuck on a Android boot loop when I switch the power on.
                Previously, I was trying to clean the storage memory (by deleting as many files as possible), I may have delete some start-up Android files.....so I screw it.🤡
                When I switch the power on, the initial JVC is shown. I have tried to run Android 9 from a bootable USB on the TV. It starts reading the USB but nothing happens and the JVC logo and Android boot loop keeps the same.
                Can anybody help me please finding the 17MB171 USB firmware to try to upload...
                11-15-2024, 03:12 AM
              • irepair559
                Ps4 1215a hdmi diode readings good everything good but no pic??
                by irepair559
                PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
                01-05-2023, 12:32 AM
              • Mgiffune
                by Mgiffune
                06-09-2024, 10:28 AM
