Best soldering station UNDER $50?
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    I have a Weller soldering gun, NOT built for recapping. Too bulky, and not precise enough. On a tight budget(just did computer upgrades(over $500)), so I don't want to spend more than $50-$75 on one(if there even is one). Can anyone help me here? Thanks.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Best soldering station UNDER $50?
    Generic 40w soldering iron.
    • TechGeek
      Computer Geek
      • Jan 2015
      • 2254
      Generic???
      sigpic
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Literally yes, im not messing here. I have owned a maplin 40w no brand soldering iron for nearly 3 years now. Still heats fine, and im able to solder fine with the stock tip I have been able to solder Ic's woth alot of pins fine. Its more about your technique than the tool when it comes to soldering.
        • Sparkey55
          • Jan 2010
          • 1523
          Originally posted by TechGeek
          Generic???
          Only a poor carpenter blames his tools for shitty work.
          • dmill89
            • Dec 2011
            • 2534
            Under $50, Hakko 936 clone (or if you check Ebay you can sometimes find used "real" Hakko 936s for around $50, though $70-80 is more common): http://www.amazon.com/Aoyue-AO936-AO...ords=aoyue+936
            or for a little more ($60) a 937 (ESD safe and digital display)clone: http://www.amazon.com/Aoyue-937-Digi...ords=aoyue+936
            ~$100 will get you a "real" new Hakko FX-888D: http://www.amazon.com/Hakko-FX888D-2...5%3A2470955011
            • diif
              • Feb 2014
              • 6978
              • England
              I use a generic 40w fitted with a chisel tip. The only time it shows its cheapness is when heating something large and the heat it sucked away quickly.
                • 31015
                you can get a T12 clone for under $50 now.
                • comptek
                  • Aug 2013
                  • 606
                  • uk
                  i have one of these heats up really quick been good so far
                  http://www.ebay.co.uk/itm/SMD-Rework...0AAMXQlgtRoyOj
                  • bc989
                    • Oct 2015
                    • 21
                    • Asia
                    i'm also looking for below $50, these caught my eye for its apparent portability. anyone have tried?
                    http://www.aliexpress.com/wholesale?&SearchText=BK950D
                    • rievax_60
                      • May 2012
                      • 897
                      • australia
                      I have been using one like this for years. It is best to get the 936A version which has the Japanese heater.
                      http://www.ebay.com.au/itm/60W-SOLDE...kAAOSwd4tT0ytH
                      • TechGeek
                        Computer Geek
                        • Jan 2015
                        • 2254
                        Is this good?
                        http://www.xtronicusa.com/#!/X-TRONI...ion/p/46116629
                        sigpic
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          It is variable power, not temperature controlled.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Originally posted by sparkey55
                            only a poor carpenter blames his tools for shitty work.
                            +1
                              • 31015
                              a poor carpenter wont improve wih shit tools
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Im a poor carpenter but dont need to improve well not for the work Im doing Tv wise
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  I'd have to say that nichrome (typical heating element wire) has some implicit temperature control as long as you supply constant voltage like either plugged in or using a dimmer; however the design of the tip and how it thermally connects to the heating element makes a huge difference on how well it actually regulates heat. That being said, it's still no match for a well designed feedback control loop system.
                                    • 31015
                                    that is probably good, it uses T12 bits.
                                    check ebay, i'v seen them about and you may get a better price.
                                    i'v seen a kit without transformer, just iron and control board for about $18
                                    • kaboom
                                      "Oh, Grouchy!"
                                      • Jan 2011
                                      • 2507
                                      Exactly.
                                      Remember those awful "shipped with kit" soldering irons? With terrible tip-to-heater contact (setscrew, loose tolerances) and overpowered heater, that tip got blazing hot! And lost its temperature the moment you held it to a joint. If you did manage to "solder" with one of these, the joints were bad from overheating/oxidation. You'd actually see the tip oxidize away if you left it on for half an hour. Waaay too hot, which still didn't "make up" for the lousy thermal interface, not in the least.
                                      Should've been called "rip the traces off" irons...
                                      TG, scrounge a used Weller TCP from ebay. Proven design and tips a'plenty.
                                      "pokemon go... to hell!"
                                      EOL it...
                                      All style and no substance.
                                      guilty,guilty,guilty,guilty!
                                      guilty of being cheap-made!
                                        • 31015
                                        magnastat - eww nasty!
                                          07-01-2024, 06:34 AM
                                        • chth96
                                          What soldering station should I purchase for 900M-TJ-I tip?
                                          by chth96
                                          hello.
                                          A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
                                          https://ko.aliexpress.com/item/4001275635593.html
                                          Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
                                          Any reply would be appreciated.
                                          11-24-2023, 05:08 PM
                                        • caprider
                                          Recommendations of quality soldering station and (separate) hot air station
                                          by caprider
                                          Hey,
                                          I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
                                          I now have a TS100 and some soldering irons and looking for some better tools.
                                          1. Soldering station, budget around 200-240€
                                          JBC BT-2BWA seems to be a good product in the budget.
                                          2. Hot air station, budget around 200€
                                          Up to now I've found ATTEN ST-862D to be a good option....
                                          01-15-2022, 02:05 AM
                                        • mkbehbeh
                                          KSGER C245 Soldering station PSU 220V only?
                                          by mkbehbeh
                                          I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
                                          I am...
                                          04-17-2023, 03:11 PM
                                        • Peter_1402
                                          Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                                          by Peter_1402
                                          Hi Everyone,
                                          I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                                          1. Soldering iron works great
                                          2. There is a burnt mark on the hot air gun handle.
                                          I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                                          Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                                          Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                                          Reed switch tested ok with a magnet.
                                          From the above test, I can conclude...
                                          07-12-2025, 11:50 AM
