What soldering station should I purchase for 900M-TJ-I tip?
  • chth96
    • Nov 2022
    • 118
    • indonesia
    hello.
    A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
    https://ko.aliexpress.com/item/4001275635593.html
    Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
    Any reply would be appreciated.
  • redwire
    • Dec 2010
    • 3912
    What comes first to buy- the tip or the soldering iron?
    I don't have success with needle tips or conical tips, they are poor for heat transfer because they are so thin. They have to be copper as well, not steel. T12 JL02 is 0.2mm
    The Hakko 936 uses 900 tips, the Hakko FX-888 uses T18 that are a bit smaller ID for a tighter fit to the heating element.
    I do not know what Ali store has decent clone stations for those.
    • chth96
      • Nov 2022
      • 118
      • indonesia
      I have T12 ILS tip which is 0.15mm,But it is somewhat big for soldering 0.0x mm wire,because the gap between adjacent tracks is very very close to each other.So I think If I can make use of 0.1mm iron tip It would be much easier to soldering very tiny wire
      • redwire
        • Dec 2010
        • 3912
        I find that is a technical approach to fine soldering - a fine needle tip and do one wire/pin at a time. It didn't work for me due to not enough heat even when cranked up. Copper wire does take a lot of heat.
        Instead I use a knife tip and let the solder stick to the tip, do many pins at once. It doesn't bridge to adjacent pins if you drag it.
          • 31256
          yes, lots of flux and drag a ball of solder along what you want to solder lengthways.
          • Aliencomputres
            • Aug 2019
            • 218
            • România
            Use Hakko original 900M tip.
              • 31256
              900m and it's clones will NOT get the heat to the end of a 0.1mm tip.
              if you have a T12 iron then look on aliexpress, some companies are making tips for microsoldering that are smaller than the ones from hakko
                07-01-2024, 06:34 AM
              • caprider
                Recommendations of quality soldering station and (separate) hot air station
                by caprider
                Hey,
                I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
                I now have a TS100 and some soldering irons and looking for some better tools.
                1. Soldering station, budget around 200-240€
                JBC BT-2BWA seems to be a good product in the budget.
                2. Hot air station, budget around 200€
                Up to now I've found ATTEN ST-862D to be a good option....
                01-15-2022, 02:05 AM
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • rmjimenez455@gmail.com
                Sumsour station 8586D error H-E
                by rmjimenez455@gmail.com
                Hello everyone, next I have the following problem with the Sumsour 8586D 110v dual station I bought it a year ago and it worked wonderfully, now it presents the H-E error on the soldering iron side, the hot air side works correctly..... I disassembled the soldering iron head because the manual tells me that this error is due to ceramic resistance problems, in effect, I measured it and it is open, I bought a new one that is working verified in a soldering iron and nothing.... The same error continues, I proceeded to open the station and check visually, I found a totally damaged 1R00 surface mount...
                09-07-2024, 09:33 AM
              • mkbehbeh
                KSGER C245 Soldering station PSU 220V only?
                by mkbehbeh
                I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
                I am...
                04-17-2023, 03:11 PM
