Its pretty hard to ID them, most T3 google images show the battery cables under the LCD, but there are still a couple of differences to mess it all up.
Anyhow, great! I'll likely test with the 8MHz first. And while waiting for the rotary encoder, can I go ahead and flash the test file first? Will basic functions still work with the std button?
Just in case, I need to revert or reflash back to recover... are there any dump of the original factory default software/firmware that came with these T3/T4?
you can put a header on with jump wires - unfortunatly they didnt route the tracks to any pads for one.
i'v said this to people before, but put a good 16MHz crystal on it.
you will increase the accuracy, and enable the crystal/resonator tester.
(needs a software upgrade.)
Before I reprogram my T3, I traced the programming pad and found the RESET pad is not connected to the atmega328 reset pin. Instead it goes to pin 30 (rxd/pcint16/pd0) see attached pic.
Shouldn't the programming pad RESET be connected to pin 29 (RESET)?
can you double-check those pads, they use that to program them after assembly.
about that video - NEVER BEND THE FUCKING WIRES OVER.
it makes stuff much harder to remove again without damaging the pads.
damn i hate these amateur video's teaching people bad stuff.
and make sure you use 99% IPA to remove all the flux afterwards.
it may not seem important usually, but on something like this, it can effect the readings!
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
ps4 seems to boot fine blue light then solid...
