ESR meter upgrades
This is a sticky topic.
    replied
    Re: ESR meter upgrades
    you need firmware that matches the crystal speed because there are time-constants in the software.
  • eccerr0r
    replied
    Ah so the actual value doesn't matter and you don't need to "enter" the value in...? interesting. I guess with accurate "T" and "R" you can still find accurate "C".
    Will be interesting to compare this to the Sencore.
  • redwire
    replied
    If the crystal does not match the MCU fuse setting, as well as the F/W- there are problems. Fast F/W with low crystal will read smaller C values I think.
    i.e. compiled F/W build is for 20MHz, crystal fuse 8MHz, C readings too low.
    TransistorTester with AVR microcontroller and a little more
    Version 1.13k Karl-Heinz Kubbeler
    replied
    a copy/paste from my old txt
    after programming, you need to calibrate the unit. (preferably twice)
    you need something to short all 3 inputs,
    and an accurate capacitor between 100n and 1uf - i recommend a 220n polyester cap.
    you also need a good stable capacitor between 10 and 30nF to calibrate the new small inductor mode.
    if you dont have one, just ignore the cal message till it times-out
  • eccerr0r
    replied
    How much calibration do these need anyway, these devices vary so much that we need 0.1% capacitors to calibrate them? Uhoh.
    2uF capacitor? (I've hated "mF" for uF even though they've done this in the past, grr. I don't like mmf for pf either. Make Money Fast!)
    0.022uF = 22nF = 22000pF = 22 x 10³ pF = code 223; 223j = 0.022uF±5%
    I don't think I have any accurate (i.e. not a ceramic) 0.22uF capacitor... needed for calibration?
  • sauna
    replied
    I will explain the test.what it should be.
    1. in the first stage, short circuit to 123
    2. the second stage I have a 2 mf capacitor
    3 .0.022 capacitor.this is 223j.this is 23nf
    or am I wrong?
  • sauna
    replied
    Thank you, stj.I've tried everything.at the last stage, he does not measure anything.
    as if stuck tightly.
    replied
    223 is 22nF
    you need 220nF (224)
  • sauna
    replied
    https://disk.yandex.ru/d/EWk4K3zB3bKl9w
    Hello.I have such Mega328 V 2,68 ESR-T4.
    https://de.aliexpress.com/item/10050...3bce0dd330da5b
    after the modified firmware I can not go self test at the last stage.as if stuck.for 1 and 3 times I tried a new 223j capacitor. This is the last stage of verification.I have already stitched 30 different firmwares with many firmwares. But alas, I can not pass the test. At the last stage, I did not save my own. It's a pity.
  • redwire
    replied
    I think Schottky leakage current is much higher.
    I tried a 1N459A silicon low leakage diode and Vf=761mV but no Ir measurement shows up on the display.
  • eccerr0r
    replied
    Hmm so it looks like it might sort of distinguish a germanium compared to a schottky actually... but it can't do it directly at least as of yet...
  • redwire
    replied
    I have a bunch of germanium diodes tried out, and not so impressed. Readings seem to be different every run. AY-AT and stj's F/W I think 20MHz:
    1N34A 371mV (DMM measures 317mV)
    1.6pF--1.2pF @0-5V
    Ir=74nA
    1N34A 376mV (DMM measures 317mV)
    1.8pF--1.2pF @0-5V
    Ir=61nA
    1N54 848mV (DMM measures 470mV)
    27pF--17pF @0-5V
    Ir=5.1uA
    1N54 846mV (DMM measures 482mV)
    11pF--10pF @0-5V
    Ir=2.4uA
    1N34A 380mV (DMM measures 313mV)
    1.7pF--0.72pF @0-5V
    Ir=46nA
    replied
    no, not seen one since i was small and had a radio-shack crystal radio kit!!!
  • eccerr0r
    replied
    hmm... I guess we'll find out regardless, provided it ships...
    If you're curious now, do you have any germanium transistors and just stick in two terminals?
    replied
    if i had a germanium diode i could tell you
  • eccerr0r
    replied
    speaking of which... can it tell the difference between a Schottky diode vs Germanium?
    replied
    well the tc-1 uses a 44pin atmega324,
    and there is a highland one with an atmega644
    probably others too
  • eccerr0r
    replied
    oh well pulled trigger on one, unfortunately it's a 32K flash limit, but nevertheless it still should work to test parts even if it cant take latest flash...
    just hope it knows how to detect germanium transistors/diodes and I couldn't care less if it could PWM or be a frequency generator, I have other tools for those functionalities...
  • clearchris
    replied
    Originally posted by stj
    i have no idea - first time i'v seen that.
    it looks similar to the one we call "AY-AT"
    if your thinking of buying it - dont.
    it has a 32pin cpu - so limited to 32k flash.
    you want one with a 44pin cpu so you can use upto 128k for maximum features.
    Do you have a suggested unit you like? It's time for me to get one of these...
  • eccerr0r
    replied
    How widespread are the "44 pin" units? Which specific microcontrollers qualify for these? Seen any specific models with them?
    Since it seems that there are so many mega328 units out there, wouldn't it make sense to keep trying to use these?
    Dang. I would rip out the PWM generator code, rather have a dedicated device to generate PWM and not sacrifice this unit to control something. Frequency counter... maybe keep. Signal generator... rip out, same issue/opinion as PWM code. *shrug* again just IMHO...
  • chth96
    Is it possible to test small ceramic disc capacitor with analogue meter?
    by chth96
    I read EBOOK of Testing Electronic Component and found that
    "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
    Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
    It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
    Is it really possible to test small ceramic disc capacitor with analogue...
    03-09-2024, 10:03 PM
    Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
    by sam_sam_sam
    I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
    I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
    12-31-2023, 06:04 AM
  • jorpec
    Changing the scale of an analog meter
    by jorpec
    Hi
    I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
    I wonder how i can accomplish this so the meter would be precise at any temperature ?
    Thnaks
    01-23-2023, 10:37 AM
    How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
    by sam_sam_sam
    About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
    Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
    12-14-2023, 07:45 PM
  • irepair559
    ps4 1215 model Changed port and encoder still no video?
    by irepair559
    hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
    Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
    ps4 seems to boot fine blue light then solid...
    01-01-2023, 12:41 AM
