ESR meter upgrades
This is a sticky topic.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #381
    Re: ESR meter upgrades
    Thanks for testing the files per hansson i wonder if its worth now updating the eevblog thread with the information and picture stj found regarding the screen and ribbon connections.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      #382
      Would be interesting if you could test them too, since we know your programmer works.
      As I don't have a working chip I obviously can't be 100% sure there isn't something else wrong with mine...
      Btw, you said you can't read the firmware from your working pre-programmed Atmega chip, but can you read how the fuses are set on it?
        • 31303
        i'm starting to wonder if they sent you a fucked chip rather than a blank one!
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #384
          i will give it a try and see if it says anything in the fuse settings
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #385
            ive just reinstalled the programmer on a new windows 10 install it still has no data when read all ff but in fuses says
            low f9
            high d9
            extended fuse ff
            lock bit byte fc
            and with two of your files ive tried so far stj just a blank screen on one and the text the same a per hansson with the other
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #386
              madires has sent this reply though eevblog
              Originally posted by madires
              Based on the picture of the LCD module it should be a ST7920, In Karl-Heinz' documentation the ST7920 is stated as "serial" with only three I/O pins (REST = PD0 / B0 = PD2 / EN = PD5). The ST7920 got Reset, CS, SID and CLK, but they got different functions in parallel interface mode. I think the best idea is to check the source code for the functions of the three I/O pins and then to adapt the port pins to match the hardware. You might need to add some code to drive the CS.
              so not sure if any of you guys can do the coding he mentions?
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                #387
                This firmware works but display is upside down and inverted:
                https://www.mikrocontroller.net/topi...270706#4270706
                This firmware works, display is also oriented correctly. But no MakeFile is included.
                https://www.mikrocontroller.net/topi...278544#4278544
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #388
                  i will copy this over too the eevblog thread and see if someone can modify them for us
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #389
                    im new to this coding stuff so i guess the makefile is what the tester can test and values etc?
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      #390
                      No it's just what is needed to know _why_ that specific firmware works.
                      I.e. it's the compilation options that the firmware is built from.
                      The source code itself is the same for all meters, it's just different options used in the makefile for what gets enabled, type of monitor, crystal, etc etc etc.
                      And of course the source code is constantly evolving, that's why new options etc can be added in later builds.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #391
                        Thankyou for explaining that at least your getting somewhere now in finding the firmware that works and at least it proves your atmega ic is good as its being programmed ok as you say its just finding the rite version etc but your making progress.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          #392
                          Which fuse settings are you using? i may try tomorrow to program mine just to see if i my programer is working ok.
                            • 31303
                            test this then.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #394
                              if per hansson dosnt try it before me i will try it in the morning stj thanks again for helping getting these testers working.
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                #395
                                I used the standard fuse settings: Low:0xF7, High:0xD9, Ext:0xFC
                                (I just wanted to test your original fuse settings on the "Original.zip" firmware the eBay seller sent me but it was just the same...)
                                Originally posted by stj
                                test this then.
                                It showed one scrolling line of text like your others, this time it was a bit better contrast and maybe thicker fonts, or just slower, difficult to say...
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #396
                                  Thanks i will try mine in the morning with the two links you posted earlier.
                                    • 31303
                                    then try both of these.
                                      • 31303
                                      vince - on your working one.
                                      hold the encoder down to get into the menu,
                                      then go to the contrast setting and find the best value for it.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #399
                                        40 shows the best imaage on the panel
                                        slightly of topic but whats the variable resistor on the pcb for?
                                          • 31303
                                          input sensitivity for the frequency counter mode.
                                          check page 13 section 2.2.4 of the pdf
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • Ryan Wurtz
                                            Lenovo Yoga C740-15IML 5V on usb meter.
                                            by Ryan Wurtz
                                            Hello. So I searched and didn't find any posts on this specific problem.
                                            When plugged in USB power meter reads 5v
                                            Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                                            Original mobo had a shorted cpu it seems.
                                            So I decided I need a new motherboard.
                                            Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                                            5v on the meter. Still won't charge. Can still charge the battery...
                                            11-24-2025, 01:08 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
