ESR meter upgrades
This is a sticky topic.
Re: ESR meter upgrades
try this one.Attached Filesif you find these attachements useful please consider making a small donation to the site
Tried "testing-swap12.zip" but just like the others there was only backlight."The one who says it cannot be done should never interrupt the one who is doing it."Comment
shit.
have to think about this until vince pins out that display to the pinstrip on the backing board.
and the socketstrip on the mainboard to the cpu for that matter - his underside photo was not good enough to get that part.
what i have is this:
1 - gnd
2 - atmel pin 2?
3 - atmel pin ?
4 - atmel pin ?
5 - atmel pin 5?
6 - +5v
7 - gnd
8 - +v (led)
9 - gnd (led)
pin1 on the socketstrip is at the outer edge - can you trace/meter the atmel pins to the display connector?
i suspect the atmel is using pins 2,3,4 & 5Comment
I already did, back in this post I tracked the Atmel CPU to the pinstrip.
And it was exactly as the schematic I linked on the previous page."The one who says it cannot be done should never interrupt the one who is doing it."Comment
I will meter the pinout now bear with meAttached Filesif you find these attachements useful please consider making a small donation to the site
right the ribbon cable has 14 pads reading left to right
pin 1 nc
pin 2
pin 3 nc
pin 4 nc
pin 5
pin 6
pin 7 on ribbon cable to pin 7 on connector
pin 8
pin 9 on ribbon cable to pin 5 on connector
pin 10 on ribbon cable to pin 4 on connector
pin 11 nc
pin 12 on ribbon cable to pin 3 on connector
pin 13 on ribbon cable to pin 2 on connector
pin 14 on ribbon cable to pin 1 on connector
pin 8 and 9 on connector go to backlight
as per my above picture im classing pin one on the left hand side of picture.
anything else you need whilst my lcds apart just ask.Attached Filesif you find these attachements useful please consider making a small donation to the site
that incomplete schem does not even have the correct cpu pin labels!I already did, back in this post I tracked the Atmel CPU to the pinstrip.
i started drawing a new one.Comment
o.k., i need the track marked in green clarified.
where is it going on the pinstrip?
there is too much flux to see it clearly.
and i need the cpu pins traced - dont point me at a bogus schematic from china.Attached Filesif you find these attachements useful please consider making a small donation to the site
just cleaned board your highlighted track goes to pin 2 on connector pin 13 on ribbon cableComment
o.k., i now have a schem of the display board
and i have this pic!!!!!
so i need pins 2-5 traced to the cpu to verify which pins they go to.Attached Filesif you find these attachements useful please consider making a small donation to the site
stj ive used diode/bleep tests these are my results pin 1 on pcb/lcd connector im classing left had side of board
pin 9 goes to pins 22 and 8 gnds
pin 8 goes nc?
pin 7 goes to pins 22 and 8 gnds
pin 6 goes to pin 7 vcc and pin 20 avcc
pin 5 goes to pin 5 pd3
pin 4 goes to pin 4 pd2
pin 3 goes to pin 3 pd1
pin 2 goes to pin 2 pdo
pin 1 goes to pins 8 and 22 gnd
stj i hope that makes sence im learing as i going/testing etcLast edited by vinceroger69; 07-15-2016, 06:53 AM.Comment
try theseAttached Filesif you find these attachements useful please consider making a small donation to the site
Thanks stj i will try it as soon as im back home as just need to pop out, maybe per hansson can check this too as im still learning how to use my programmer so i would not want too say your file dosnt work when it does as im messing up my end programming it although i will try when im back home.Comment
soldering one on the pcb etc isnt the isuue its the learning of the programming side of things im reading up on and trying too learn, things it seems to take longer as you get older.Comment
You are correct they mislabeled some of the pins, but the layout seems correct.
As now verified by vinceroger69 as well
I now tried all firmwares in "testing-chips.zip"
The only one which gave scrolling text like with the previous files quoted below was the 7565 display firmware.
All others just had blank display with backlight lit.
Last edited by Per Hansson; 07-15-2016, 10:58 AM."The one who says it cannot be done should never interrupt the one who is doing it."Comment
by chth96I read EBOOK of Testing Electronic Component and found that
Is it really possible to test small ceramic disc capacitor with analogue...-
by sam_sam_samI have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery... -
by Ryan WurtzHello. So I searched and didn't find any posts on this specific problem.
When plugged in USB power meter reads 5v
Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
Original mobo had a shorted cpu it seems.
So I decided I need a new motherboard.
Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
5v on the meter. Still won't charge. Can still charge the battery... -
by jorpecHi
Thnaks -
by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer... - Loading...
