ESR meter upgrades
This is a sticky topic.
+ More Options
Posts
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #321
    Re: ESR meter upgrades
    Yes, especially since the seller has one for sale assembled aswell!
    I bought one too but I'm still waiting for it, so I'm very thankful for your work on this vinceroger
    Hi just wondered if you managed to build your tester kit? and did your atmega328p ic have data on it as mine did not.
      • 31044
      i dont know how that programmer works.
      but you only need the hex and eep files.
      try this one.
        • 31044
        mine was not a kit, it was the older version - 100% surface-mount and no rotary encoder.
        it was copy protected and i had to draw up a schematic and patch the code to match it.
        i also had to change the default contrast because initially the display looked blank!
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #324
          sorry stj i meant Per Hannson regarding the same kit he brought as me, its a good job stj you have experience in programing i have no idea but i am learning slowly i will try the above file and let you know thanks again.
            • 31044
            how does that programmer handle the 3 fuse bytes?
            you MUST set them with the values in the first archive.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #326
              dave from eeblog has a good you tubevideo on this programmer minipro tl866cs
              https://www.youtube.com/watch?v=FLG03f_ua5g
              i will take a picture of the screen now about the fuses etc
                • 31044
                what a pain.
                o.k.
                play with those tick boxes to get the low-fuse to F7
                and the high-fuse to D9
                and the extended fuse to FC
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #328
                  fuses was easy too set up as per your guide still scrolling display with one of your zip files and just a blank display with the other zip file
                  just a thought stj when adding your files i can add them as code memo or data memo which one is correct?
                    • 31044
                    hex is code, eep is data - you need both because the fonts are in the eep file!
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      #330
                      ok will try again lol as was putting both in code
                        • 31044
                        that explains it, you had the display but no fonts!
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          #332
                          Have not even received mine yet
                            • 31044
                            well vince can send you a 16MHz crystal for it - he had to buy 5
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #334
                              with all the settings as your instructions and tried the two diffrent zip files still no good one zip just blank screen other zip slightly diffrent scrolling data on screen in my picture of the fuses screen theres one section lock bit byte? ive got nothing ticked there.
                                • 31044
                                leave the lock bits.
                                50/50 this is because of the programmer.
                                try renaming the eep file - eeprom.hex
                                and the hex file - code.hex
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #336
                                  ok will give it one more try if it dosnt work it may find its way in the post too you.
                                  well that didnt work either just the backlight on untill auto switch off.
                                    • 31044
                                    well the header and usbasp programmer are the prefered method.
                                    was it the first file that gave some stuff on the display?
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #338
                                      yes top two rows lit very small symbols/writing scrolling left to right at the moment with the second zip files just back light on and stays on for about a minute.
                                      i would of thought with this programmer its the same really but your just removing the ic from the holder i have set the fuses as you have said thats easy to do im just looking at videos now to make sure im using the programmer rite.
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        #339
                                        Finally mine arrived too!
                                        I've got the same as vinceroger69, with the firmware from this post I get scrolling characters on the screen when I power on.
                                        With the other firmware from this post it is blank.
                                        The chip did contain a few bytes of code when I got it but for sure it was not a complete program.
                                        The programmer acted like it was empty; like vinceroger69 explained in this post. (I attached what was there in the rar file).
                                        With the scrolling text I can't do anything, if I press the encoder nothing happens, I need to remove the battery to power off.
                                        The LCD is marked LCM_12864_V1.30 2015.09.01
                                        I attached pictures showing the scrolling text and of the LCD backside.
                                        I used a Willem GQ-4X USB Programmer to program the chip and set the fuses.
                                        (I had to do a "Erase" first which I did not at first realize, took many attempts until I found out that was the problem because the program never got written properly, I did the programming in circuit.)
                                          • 31044
                                          o.k. i'l go look at the code.
                                          i think the pinout is o.k. or the display wouldnt be on.
                                          so probably a different chip in it.
                                          try this
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
