Killing multimeters...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    I can't believe I have yet to destroy a multimeter after all these years...
    The only ways I've "abused" a meter was having the cheap probes break. Once I had one (small analog) meter I left the probes plugged in and threw into a backpack with other stuff in it, and cracked the probes. Once the probe got overstretched and broke the wire inside of the insulation. And many times the wires broke at the probe, needing it to be resoldered or something.
    But I have yet to fry a meter electrically...
    One of my meters, the old Eico 555, the Rx1 resistor was burned out when I salvaged it, which is typical of trying to measure voltage in the resistance range I find. I'm glad I've yet to destroy one this way...
    So how have you killed your multimeters?
  • SteveNielsen
    Retired Tech
    • 2327
    Re: Killing multimeters...
    I've only killed two but the same way. Slipped probes when taking shunt plate current measurements on tube guitar amp output tubes. The milliamp scale doesn't like 400vdc. I learned and stopped doing it that way too.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      I have burned out fuses before (a 2A on my Viz and a 500mA on a pocket (not freebie) HFT meter), both due to leaving them in current mode when trying to measure low voltage DC. This is clearly a "fail" but the meters are still fine after replacing the fuses.
      After rereading my post I guess it wasn't too clear, that Eico 555 I had posted a while ago I got it when someone abandoned it since it was broken. I don't know why I just could not think of how someone could burn that resistor until it somehow dawned on me how to do it.
      The next thing that I had a "whudunit" situation when I rescued a vacuum tube voltmeter that had multiple failures. Two of which - a bad connection and a shorted probe jack - made sense (cold solder joint, and water/condensation) but the third one - a fried probe resistor - didn't. But that shorted probe jack and trying to measure a high voltage might actually explain how that resistor got fried...
      • retiredcaps
        • Apr 2010
        • 9271
        Just yesterday ...
        https://www.badcaps.net/forum/showpo...39&postcount=1
        I have never fried a meter or blown a fuse, but I have fixed a lot of meters and helped others online fix theirs after an "oops" moment.
        --- begin sig file ---
        --- end sig file ---
        • Agent24
          I see dead caps
          • Oct 2007
          • 5037
          • New Zealand
          Haven't so far, luckily.
          My cheap DSE meter (an 830 based model) did have self-destructing probes though.
          -David VanHorn
            • 31199
            the few times a meter died on me it was the rotary switch.
            my current one is starting to go, i feel a UNI-T coming soon!
            probes/cables are another matter - they will go in one way or another.
            you can pay anything from 1$ to 20$ for a basic probe/cable set or as much as 70$ for a full-kit from Keysite (Agilant)
            • CapLeaker
              Leaking Member
              • 8327
              13 years ago my Voltcraft DMM died. Ever since I got Fluke and Agilent. 2 Years ago my then new (1 year old) U1253 Agilent DMM went crazy. Sent it back and got a brand new one with calibration. woot! None of the Fluke's have died, but one casing replaced.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5037
                • New Zealand
                The good ones last a bit longer than several weeks....
                -David VanHorn
                • delaware74b
                  • Apr 2009
                  • 628
                  I killed my last multimeter, a Craftsman $40 one with 400 amp clamp. Dropped it 12 feet onto concrete floor. Failed miserably as the clamp shattered internally. I replaced it with a $90 Southwire version from big blue. The amp clamp portion reads up to 400 amps both ac and dc. Great for checking alternator output current as well as volts.
                  Stupidity should be a crime, especially for drivers. I have NO patience for them.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    Never killed one but a cheap CHY 17 multimeter I forgot outside for a few days after having worked on my car.
                    It rained heavily on it, but after disassembly/cleaning and new battery it still works to this day
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      I have yet to drop a multimeter, or they have survived the drops...
                      Yes I did see that other post from Goontron alas I didn't want to derail his post with horror stories
                      The two meters that I burned fuses on are my two "worst" meters in terms of "user interface" - That is, it's not obvious from a distance what mode the meter is in. The 2A was in my Viz (and it's no wonder why RCA no longer makes meters) and the 500mA was in a HFT meter. If only that select switch was more clear what mode it's in, I've even left it on and killed its battery (and it uses those A23 batteries... ARGH!)
                      As for probes, the probes on my Fluke are indeed very good and don't know when if ever they'll break. My "more expensive" HFT meter (which is actually a Mastech) also has very decent probes, but the cheaper ones are indeed very crappy. Most have plastic wire, but the Fluke feels like rubber. The "more expensive" HFT almost feels rubbery but not quite...
                      • larrymoencurly
                        • Oct 2004
                        • 960
                        Fluke versus Harbor Freight multimeter at high voltage (about 5 minutes in): https://www.youtube.com/watch?v=OEoazQ1zuUM
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5037
                          • New Zealand
                          Good video for all those who complain Fluke et al are expensive... cheaper than skin grafts!
                          -David VanHorn
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            TLDW...
                            How much damage from measuring 700VAC in the 10A current range?
                            Yes, the freebie/less than $6 HFT meter doesn't even have a fuse... though I don't think I want to even test my Fluke in current mode on 12VDC...
                              • 31199
                              the probe-cables are the fuse.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                That, or the weak PCB tracks/solder joints inside the meter are the fuse!
                                I was appalled when I opened the meter, the 10A range "daughter board" was connected to the main board by two solder bridges...
                                • yz7myg
                                  YU2MYG
                                  • Feb 2007
                                  • 18
                                  Dead Fluke
                                    • 31199
                                    metal oxide everywhere - that must have gone up like a flare!
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      Not even between the high current terminals...I wonder what caused that failure?
                                      I think I threw out the dead resistors that I've replaced in my salvaged meters, but true, rather a dead resistor than a flaming meter.
                                      • TechGeek
                                        Computer Geek
                                        • Jan 2015
                                        • 2254
                                        How'd that meter go up?
                                        Permanently Retired Systems:
                                        Kooky and Kool Systems
                                        sigpic
                                        • JimBanville
                                          MOSFET mystery
                                          by JimBanville
                                          N channel mosfets testing as P type?
                                          Working on a smps.
                                          Using Fluke 115. Red probe in red socket. Black probe in black/common socket. Meter set to diode mode.
                                          Removed a pair of mosfets marked 1L02AB FDP
                                          26N40 from the circuit.
                                          The pair of Mosfets are still screwed to the single heatsink. Mosfet printing facing me.
                                          I did the test where I short the left and center pins. I put black probe on right pin and red probe on center pin. I get OL. While keeping black probe on right pin, I put red probe on left pin and get OL. After a few seconds I move red...
                                          09-14-2023, 04:22 PM
                                        • echothegamer
                                          Macbook A1466 dies when charger disconnected
                                          by echothegamer
                                          Hello all,
                                          Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
                                          Details:
                                          Macbook 13' A1466
                                          Board (820-3209-A)
                                          Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
                                          Pictures below of Boardview and schematic...
                                          I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
                                          It's an older model and it is very likely that battery has become...
                                          10-28-2023, 12:00 PM
                                          Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                          by sam_sam_sam
                                          I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                          I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                          12-31-2023, 06:04 AM
                                        • jorpec
                                          Changing the scale of an analog meter
                                          by jorpec
                                          Hi
                                          I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                          I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                          Thnaks
                                          01-23-2023, 10:37 AM
                                        • chth96
                                          Is it possible to test small ceramic disc capacitor with analogue meter?
                                          by chth96
                                          I read EBOOK of Testing Electronic Component and found that
                                          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                          Is it really possible to test small ceramic disc capacitor with analogue...
                                          03-09-2024, 10:03 PM
