Where to buy solder?
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    For example, all the stuff at Amazon I found ships from China. I've been through that once, I never got the solder from China. Supposedly "lost" in customs. Ok, I can learn from that. So, where do you guys like to buy solder at?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Where to buy solder?
    Ebay or local electronics store.
    • SteveNielsen
      Retired Tech
      • Jun 2012
      • 2327
      There is no longer an electronics store around here. I'm suspicious of ebay but am now becoming suspicious of Amazon.
      I could order a roll from Kester for $20+.
      There's got to be a better route to go.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ahh right why are you suspicous ?
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          I am suspicious because I have been stolen from as a result of online purchases. However I don't think I am quite as vulnerable now because I use a prepaid debit card that has no connection to my main bank account and has no more money than I intend to spend using it. I suppose I shouldn't worry but I do anyway.
          • mariushm
            • May 2011
            • 3799
            Buy from Digikey, Mouser or Farnell (Newark.com in US)
            Digikey: http://www.digikey.com/product-searc...solder/1310838
            Newark : http://www.newark.com/solder-wire
            Mouser : http://www2.mouser.com/Tools-Supplie...der/_/N-b11qq/
            my recommendation from what i think is best to less best... multicore / kester / stannol/ mg chemicals/edsyn or if you're really cheap multicomp which is farnell's internal brand, it's often rebranded multicore or kester solder but must be careful, just compare datasheet layout with original multicore or kester datasheets. Maybe also alpha metals / aim but i have no experience with these brands as they're mostly us.
            63/37 or if you have money 63/36/2 which would have minimal benefits over 63/37, then 60/40 for plain bland generic good solder. No-Clean with 2-2.2% flux or more, but if there's no choice then RMA (rosin mildly activated) would also work, then RA (rosin activated). No-Clean and RMA in the large majority of cases don't require cleaning of the flux, RA is stronger than rma but may require cleaning the flux with isopropyl alcohol after soldering (more work for you). Stay away from solder with water soluble flux, the flux must be cleaned and it's harder than the title indicates, it's misleading.
            For diameter, if you have money go with 2 sizes, one about 0.7mm or thicker to feed lots of solder fast when you need to solder something thick, one 0.5 mm or smaller for small soldering jobs. If you're cheap, go with the thinner diameter, you can always bend the solder in two and twist the wires for thicker diameter.
            I personally use a 0.56mm no-clean multicore 63/37 with 2.2% flux (if I remember correctly).
            If you still have money, also buy a flux pen or bottle, adding a drop of flux before desoldering or resoldering something helps big time, even if the solder has flux included in it. See http://www.digikey.com/product-searc...emover/1311241 or http://www.newark.com/solder-flux or http://www2.mouser.com/Tools-Supplie...lux/_/N-b11wf/ with the same mention, stay away from water soluble flux, match it with your solder wire flux choice
              • 31196
              dont waste money on a flux pen, the ends get messed up and they hold almost nothing.
              you can get an industrial 500ml bottle of flux for less than a stupid pen.
              • mariushm
                • May 2011
                • 3799
                I bought a 100ml bottle for about 3$ from a local electronics shop. It's made in Poland by a company with decent local reputation.
                Flux pens are expensive for the quantity of flux they hold but if you only solder occasionally they good enough (as for ends getting messed up, as long as you store them as recommended, they'll be fine).
                The stores I mentioned above sell large containers but at steep prices, mostly because flux is considered dangerous to ship by air (it's flammable due to the isopropyl alcohol and other flammable chemicals inside it) so they're shipping them by rail or cars (in theory).
                Best deal would be to buy from local stores but you still have to be careful about brand and type of flux before buying. The quality can vary by huge amount between manufacturers.
                Desoldering braids for example are perfect examples for this... the flux the copper mesh is soaked in makes or breaks a desoldering braid. Use a good quality braid once and you'll want to throw away all the other braids you have.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  I've got enough solder to last me a lifetime I think (a bit less than a pound left now I think, ordered online probably from mcm or parts express or something), but if I had to go local, these stores probably have solder... may not be good solder but it will work...
                  Home Depot
                  Ace Hardware
                  Lowe's
                  Radio Shack
                  Harbor Freight Tools (oh no... shipped from China...)
                    • 31196
                    that's why i'm using this.
                    http://www.rapidonline.com/Tools-Equ...-500ml-85-6650
                    of course, if your oldschool and just want a bucket of rosin desolved in IPA they have this.
                    http://www.rapidonline.com/Tools-Equ...-500ml-85-6646
                    • clearchris
                      • Dec 2013
                      • 687
                      I got some kingbo flux off ebay (china or hk shipped) and it works great. I always clean off flux, usually with brake cleaner.
                      I ordered some solder off fasttech.com recently, if it arrives, Ill tell you if its any good. Also ordered a solder dispenser, hollow needles and some other soldering goodies. All in it was 20 something dollars.
                      • SteveNielsen
                        Retired Tech
                        • Jun 2012
                        • 2327
                        Thanks for the replies. I think we've got a Lowe's around here now (I hardly get out). I'm ok for flux, I made my own liquid flux out of rosin and IPA and probably won't ever run out. I put it in a dropper bottle but it is slowly eating away at the rubber of the dropper. I'll figure a different container for it.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          I'm shocked you went for the Lowe's/Home Depot/Ace Hardware route (they're hardware stores, so they sell general purpose solders, but mostly for copper pipe!) and not Radio Shack. Just make sure you get the "Rosin Core" or "Electrical" solder. Unfortunately they likely will sell you pretty thick solder, like 0.062", and you'll probably not be doing IC work with it unless you're real careful, and likely the rosin in it is pretty crappy. It's also the lead free junk, so expect a bit more heat needed.
                          It's a pity pretty much all the local electronics shops around here have pretty much dried up. Other options include Fry's (looks like it's over an hour away from Newport, your closest one is near Portland?).
                          I recall I may have ordered solder from Jameco Electronics which I think is quite reliable. They've been a mail order shop for many years (I've ordered from them many times) and their warehouse is in Belmont, California (I've visited their storefront once or twice too, alas, they will fill your order while you wait). You can get lead solder from them.
                          • SteveNielsen
                            Retired Tech
                            • Jun 2012
                            • 2327
                            Radio Shack no longer exists here. I haven't gone to anywhere yet, but thanks for the advice. I'll look at Jameco.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Looks like Jameco has switched over to 1-lb rolls of solder... I ordered 1/4 kg and 1/2 lb (by mistake, this was the 0.062" solder) rolls before and each roll is more than I could ever use.
                              Please research the different rosins (and solder formulations if needed) before ordering a big roll you'll hate I kept the 0.062 misorder because it actually had really good rosin in it as well as being eutectic, and I figure I'll have solder lugs to solder in the future anyway.
                              BTW I think:
                              0.5" - for solder pots
                              0.125" - For copper pipes
                              0.062" - for solder lugs
                              0.031" - for through hole PCBs/ICs
                              0.015" - for SMT repair...
                                • 31196
                                seriously?
                                i burn through a 250g roll of 0.7mm Sn99.3/Cu0.7 in under a year - and the quality stuff i use isnt cheap.
                                about $45
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  I don't have THAT many projects that need the solder... It's a hobby, not a profession =\
                                    http://www.all-spec.com/products/KW4415.html
                                    http://www.all-spec.com/products/KW4410.html
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      Well, since Radio Shack is closed now, there aren't many local stores to get (electronics) soldering supplies. That said, I am lucky since there is a Micro Center very near me. They carry all types of solders. I haven't bought any from them, though, since I still have a huge spool of lead-free plumbing solder and a jar of Kingbo paste flux. I use that stuff for almost everything that doesn't require leaded solder.
                                      My friend, however, swears by solder bought from China. He gets big 1 pound spools of leaded solder for very cheap. Not sure if it is from Alibaba or where exactly.
                                      Try eBay, then. It has has gotten pretty good in the last several years - at least for the buyer. Easy to get a full refund if your product never shows and seller doesn't care.
                                      I'm not sure if that is a good idea. Chlorinated chemicals aren't generally recommended for electronics.
                                      I use IPA only, preferably 90% or higher.
                                      Perhaps because all of those repairs you do with the lead-free solder break again and you have to redo them constantly?
                                        • 31196
                                        no, because i use it in conjunction with a temperature controlled iron.
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • corrize
                                          Best way to solder LVDS connector for beginner (and qfn) ?
                                          by corrize
                                          Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                                          I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                                          I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                                          See the test :
                                          https://youtu.be/bNAzC-EvqHs?t=1767
                                          With hot air from bellow the board, that's...
                                          03-09-2023, 02:57 AM
                                        • petemanuk
                                          BGA solder balls not connecting - help pls
                                          by petemanuk
                                          So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                          I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                          I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                          11-16-2022, 05:21 AM
                                        • myth77
                                          UV solder mask - high temp resistent, recomendation?
                                          by myth77
                                          Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                                          Is there any solder mask...
                                          03-28-2022, 04:04 AM
                                        • sircastor
                                          Solder not reflowing - what am I doing wrong?
                                          by sircastor
                                          I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                                          For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                                          03-03-2024, 02:44 AM
