Transitor/ESR tester dead
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Transitor/ESR tester dead
    I found the same thing on AliExpress:
    http://www.aliexpress.com/item/10-Pi...rchweb201560_4
    I got my tester mounted in a metal half box that came from a dead TV that housed a G-Star decoder or some such thing. I put the battery clip on the back which props the tester up at a good angle.
      • 31255
      that's a nice fit.
      you should consider something to protect the display though - specially as the cable is exposed.
        • 31255
        decided to upstage your foto's with a couple of my programming connector.
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          That's very good.
          Yeah, I'm not completely satisfied with my box yet either, but it's ok for now. I wasn't planning on using a metal box, I just happened to find it in a junk box and it's the right size. I know the disp cable is exposed, the tape over it is already starting to peel off just from what little handling it's had.
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            Have you fitted the rotary yet? I'm about to order one. Also what programming interface are you going to use? I thought you posted some info about that device before but I can't find it.
            • SteveNielsen
              Retired Tech
              • Jun 2012
              • 2327
              Will this ISP programmer work?
              http://www.aliexpress.com/item/USB-I...rchweb201560_9
                • 31255
                that's exactly the right programmer.
                my rotary got delivered to a friends place, i wont be able to get it till later this week.
                i get parcels sent to a friend because he's always in to answer the door - it has it's bad points when i want something fast!
                about the programmer,
                you need to build of buy a 10pin to 6pin adapter.
                i built one with a 10pin socket from an old pc serial port and a 2x5 connector from an old pc case usb board.
                  • 31255
                  programmer software is here:
                  http://www.fischl.de/usbasp/
                  driver:
                  http://www.fischl.de/usbasp/usbasp-w...2011-05-28.zip
                  programmer soft:
                  http://download.savannah.gnu.org/rel....1-mingw32.zip
                  • SteveNielsen
                    Retired Tech
                    • Jun 2012
                    • 2327
                    Yeah I know I need a 6pin header, I'll dig one up. Thanks for the link but which software package to use under Linux, AVRDude or BASCOM-AVR?
                      • 31255
                      for Linux you just need avrdude - it should be in your distro repository.
                      what linux is it?
                      those links were for win users.
                      • SteveNielsen
                        Retired Tech
                        • Jun 2012
                        • 2327
                        Ubuntu 14.04.3 LTS
                          • 31255
                          check the software repositry's - i bet avrdude is in it.
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            Wow, I'm jealous, that tester is so clever!
                            I thought you'd need to use much more circuitry to measure ESR ... but this thing measures ESR and more, with less!
                            Though I did spot that it says:
                            "You should not expect very good accuracy of measurement results, especially the ESR measurement
                            and the results of inductance measurement are not very exact."
                            I also see that it doesn't use a frequency of 100kHz to measure the ESR.
                            Originally posted by stj
                            i keep the covers from old tuners for that.
                            LOL, I do that too!
                            I keep some RF shields as well. They can be soldered to (not aluminum!), and I have some shears to cut the metal into whatever size/shape I need.
                            -Ben
                            Muh-soggy-knee
                            • SteveNielsen
                              Retired Tech
                              • Jun 2012
                              • 2327
                              Yeah, it is not as accurate as a better ESR meter but it is close enough for my use. I really like mine.
                                • 31255
                                accuracy is improving,
                                there is a new calculation method being tested right now.
                                i'm not upgrading till they finish testing it though - i'm not their beta-tester!
                                also, you can change from an 8Mhz to 16Mhz crystal to improve test accuracy at the expense of battery life.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #76
                                  i wonder how accurate these ebay testers are the compared to a proper esr tester has anyone tried to find out i wonder.
                                    You can use for example 1% 0.1 Ohms resistor to see how close it is.
                                    http://www.digikey.com/product-detai...10CT-ND/596475
                                      • 31255
                                      i will do a test for everybody in the next couple of weeks, i know someone i can borrow a peak-atlas ESR-70 from.
                                        • 31255
                                        resistance is accurate to atleast one - maybe 2 decimal points.
                                        that's not the same as ESR though if the tester uses a different frequency from the factory making the datasheets - which is the case.
                                        • Per Hansson
                                          • Jul 2005
                                          • 5895
                                          • Sweden
                                          #80
                                          I've seen several of these testers that show they can be used as signal generators up to 2Mhz.
                                          Does anyone have any insight to why they don't measure ESR at 100Khz then, sounds like it should be easy to do...?
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • maleksa
                                            Korg Kross2 Service Manual and LCD pinout
                                            by maleksa
                                            The LCD on my Korg KROSS2 keyboard is cracked and needs to be replaced.
                                            However, the cost of a replacement LCD is almost the same as the price of a second hand Korg KROSS!
                                            Does anyone have a copy of Korg KROSS2 Service Manual? I want to see the PINOUT for the LCD connection. Perhaps I can find a compatible LCD screen and not have to spend a fortune on an original replacement LCD.
                                            From what I can gather, the LCD screen is a COG with serial interface (SPI). Is there any way I can ascertain (perhaps with the use of a multimeter or oscilloscope) the PINOUT by...
                                            10-11-2024, 05:54 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • zunasthegreat
                                            Chieftec GPS-450-AA with dead 20N60C3
                                            by zunasthegreat
                                            Hello everyone hope all doing well!
                                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                            09-01-2024, 07:12 PM
                                          • Beton
                                            Finding a dead short component
                                            by Beton
                                            Hi guys!
                                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                            I have a bench PSU and if I try to inject voltage the voltage...
                                            12-10-2021, 01:05 PM
